04-14-2013, 03:09 PM | #676 |
Member#: 155696
Vehicle:2007 BLK STI Dom3XTR 415/405 Precision Tuning |
That is just ridiculous. I really love ur build dude. It's so sick
04-14-2013, 03:15 PM | #677 |
Member#: 193757
Vehicle:2006 XTI Limited OBP, Junior tuned 573WHP |
Thanks Slim! I was not too surprised from how she feels, this and 3900-7600 is the meat of my power curve so it pulls hard there! I bet it helps to get a little run at it like starting from 2500 or so like I did on this pull. Junior backed off the boost a little bit from the dyno tuning session so that's why I'm only making 25 psi on this pull in 3rd. I make around 26ish in 4th. My car's not very light either it's a Limited with the big azz sun roof, heated leather seats and I've sound insulated most of the car.
04-14-2013, 04:16 PM | #678 |
Member#: 183480
South East
very nice man...holdin it down for the FXT's
I finally started switching mine over to stage 2 on E85 last week. It is intercooler limited to 17psi right now (too scared to push any further on the plastic end tanks). It is definitely a torquey SOB with that TD04 on there even with just 17psi. I was literally home for a week before I got sent back out of state again, so...once I get back, I am going to finish up the tune hopefully and get a 50-100 video uploaded. |
04-14-2013, 04:44 PM | #679 | |
Member#: 193757
I have a bunch of take off stuff I'm going to put up for sale on here. STI TMIC, VF48, Cobb SF SRI, GMS TIH, GS PnP'd stockers and more. Let me know if you would like any of it. PM me and we can discuss. The TMIC has a Y pipe, stock BPV, silicone elbow, ready to go!! |
04-14-2013, 05:05 PM | #680 | |
Member#: 183480
South East
Unfortunately, because of the redesign for the 09, the parts that I would want (tmic and intake) won't fit. I have to have either 08+ wrx or 05+ lgt parts in order for them to work. There are a few parts that fit from other models, but for the most part engine wise, I am limited to those models only. Really appreciate the heads up. If I come across anyone looking for parts I will send them your way . |
04-14-2013, 05:28 PM | #681 |
Member#: 193757
I forgot you bought an 09. I think if you swapped in the VF48, then you could go with the STI top mount. Not sure what TMIC brackets you have though?
Thanks I'll get them posted up this week, all in good shape, I have good photos of all of it as well! |
04-14-2013, 09:30 PM | #682 | |
Member#: 193757
04-14-2013, 09:53 PM | #683 |
Member#: 258009
Vehicle:04 sti wrb |
I believe they have vf52... The 08 had te flanged td04
04-14-2013, 09:54 PM | #684 |
Member#: 258009
04-15-2013, 12:09 PM | #685 |
Member#: 219492
Vehicle:17' 5mt XV & 02 WRX @comrad |
my brz.
stock motor. perrin catback. coilovers and 265's all around. **** took forever i'll update as i mod. |
04-15-2013, 12:30 PM | #686 | |
Member#: 290307
04-15-2013, 12:34 PM | #687 |
Member#: 219492
can't use a turbo in corners
04-15-2013, 01:17 PM | #688 | |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
04-15-2013, 01:40 PM | #689 | |
Member#: 183480
South East
see above this is a statement only accurate when talking about big turbos and small engines. Small turbos on smaller engines or medium turbos on larger engines will give plenty of boost at a low enough rpm to be useful in a corner. |
04-15-2013, 01:41 PM | #690 |
Member#: 290307
04-15-2013, 03:48 PM | #691 | |
Member#: 155696
04-15-2013, 05:05 PM | #692 | |
Member#: 261612
Vehicle:2002 WRX - 750WHP 9.5s @ 150mph |
I'm not doubting it, I'm just saying it's hard to be accurate with that few data points. You should try it when only logging time, RPM, boost and vehicle speed (unless your calculating that anyways). You should get a lot more points and a lot more accurate graphs. For VD it should really be a 4th gear plot (mine usually look super smooth like that in 3rd gear too, because it goes by too quick to get enough points). Or grab a speedo vid. I like those better anyways Also, your gearing and powerband is the reason no one else uses 50-100, lol. It helps the time a lot only using 1 gear (assuming you're making reasonable power the whole time). I just picked this range because it's easy to hit in a sub-250WHP car. 60-130 is not feasible for most people on stock or Stage 2 power. But on a larger turbo it's a much better measure than 50-100. My last setup and current setup are the same way (3rd gear pulls all in one gear are the fastest 50-100mph). With the right powerband it is close to 1/2 second faster than with 1 shift and nearly 1 full second faster that people who shift twice. I still need to watch this one! |
04-15-2013, 06:01 PM | #693 | |
Member#: 193757
I really think the speedo thing is inaccurate with angle of view and vagueness of an analog speedometer! It's no more accurate than what I sampled and probably less accurate! I think a better method would be to video a GPS set up on a digital speedometer view. Of course a V-Box is the best but I really can't believe that no one has developed a good app for the iPhone or android to log time to speed and better yet to be able to log the time to a speed range that you could select. My power band and gearing like yours is pretty broad and is conducive to less or no shifts with this stuff like this. That is the type of power band I was after with my build and why I run such tall tires! I do understand why you've picked the 50-100 time with the Subaru community, it allows most everyone to get into the game!! I may do another 50-100 pull sometime but not sure when, I really need to behave behind the wheel! What disappointing news today about the bombing at the Boston Marathon, very sad for sure! Allan |
04-15-2013, 06:25 PM | #694 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
dynolicious?...
A V-box is to expensive, best price I found so far 550... If I could get it for 400 I will buy one. |
04-15-2013, 06:47 PM | #695 |
Member#: 193757
I agree on the V-Box price, just too steep! Someone needs to design a V-Box type app for our GPS enabled smart phones.
I've downloaded most all of the free ones for the iPhone, dynobox, dynolicious, gps speed, speedbox speed tracker and they all are lacking! |
04-15-2013, 10:21 PM | #696 |
Member#: 261612
Yeah, a cheap, high data rate GPS logger would solve a lot of problems. I agree that speedo vids aren't any more accurate (other than the higher "data" rate), but they're more fun to look at!
I didn't realize that plot was from VD. I think that's a feature that may be in development. I'd just throw it into Excel and plot out the relevant things. Just put RPM on the secondary axis and it should all scale pretty well. VD plots with more data points and/or in 4th gear would be interesting to see. In 3rd gear my car consistently shows 600WHP at 30psi with power flat or increasing to 8k. In 4th there is a bit more resolution and it always shows a little drop in power up top. |
04-16-2013, 12:15 AM | #697 |
Member#: 32669
SCIC
Vehicle:2007 2.34LR, EFR7670 LINK G4+ hybrid STi |
04-16-2013, 01:14 AM | #698 |
Member#: 219492
04-16-2013, 02:02 AM | #699 |
Member#: 299169
W. Canada
Vehicle:2002 Wrx/JDM STi v.7 Dirrrty |
04-16-2013, 12:21 PM | #700 |
Member#: 133146
I just spend some money on some goodies... I will let you know when I am ready. I need to get some kind of speedo for sure because my speedo doesn't work since I swapped a 2011 STi trans
Similar Threads | ||||
NASIOCers!! Starter mods list | Daniel son | Legacy Forum | 4 | 11-21-2006 03:56 PM |
50 cent listings on eBay motors | plunk10 | Off-Topic | 7 | 10-17-2006 12:15 PM |
Official NASIOC OT C List | dr_wheel | Off-Topic | 25 | 02-22-2006 05:41 PM |
NASIOC GMail Invite List | AVATAR-X | Off-Topic | 458 | 05-21-2005 10:04 AM |
Japan's Top 50 car list | Tragedy | Off-Topic | 5 | 07-29-2003 11:49 PM |
