03-23-2005, 10:49 PM | #1 |
Member#: 26315
BAIC
Vehicle:07 Outback Silver/Silver |
Little UTEC help please
Code:
3035 -11.4 2.4 14 00 00 +44.7 8.0 ECU. +0.5 ECU. 2.1 14.61 3049 -10.4 2.4 15 00 00 +45.5 9.0 ECU. +0.5 ECU. 2.1 14.08 3033 -9.4 2.4 15 00 00 +46.1 9.6 ECU. +0.5 ECU. 2.2 14.45 3052 -7.9 2.4 16 00 00 +45.9 11.1 ECU. +0.5 ECU. 2.2 14.87 3075 -7.1 2.6 22 00 00 +46.0 12.1 ECU. +0.5 ECU. 2.3 14.15 3112 -5.9 2.9 30 10 00 +44.9 13.9 +33.0 +0.1 500.00 2.6 13.84 3150 -4.0 3.0 52 10 00 +42.2 17.4 +33.0 +0.1 500.00 2.7 13.72 3217 -1.8 3.1 85 10 00 +39.5 20.2 +33.0 +0.1 500.00 2.8 14.05 3284 +0.0 3.4 100 20 00 +38.4 23.0 +24.0 +0.1 500.00 3.0 13.87 3373 +2.3 3.5 101 20 00 +36.5 25.6 +24.0 +0.1 500.00 3.0 12.78 3472 +3.9 3.6 101 30 00 +33.9 29.5 +17.9 +0.1 500.00 3.2 11.96 3512 +5.5 3.7 101 40 00 +30.7 34.8 +18.0 -0.1 500.00 3.3 11.39 3663 +8.2 3.9 101 50 00 +24.2 38.5 +17.0 -0.1 500.00 3.5 10.86 3757 +10.6 4.0 100 70 00 +21.8 44.1 +15.5 -0.3 500.00 3.6 10.62 3849 +12.7 4.1 100 70 02 +21.3 45.1 +11.5 -0.3 500.00 3.6 10.62 3944 +14.9 4.1 100 80 00 +21.6 45.0 +9.5 -0.4 500.00 3.6 10.65 4089 +15.7 4.2 100 80 00 +22.2 45.9 +9.6 -0.5 500.00 3.6 10.59
03-24-2005, 08:25 AM | #2 |
Member#: 54597
Vehicle:08 'Busa, 08 ML63 10 Multistrada, 996 Targa |
It's pretty rich for only 5-12 psi. I would pull a little timing to get rid of the knock for now, and then lean it out in that area. You might find that you can bump the timing back up then.
03-24-2005, 08:41 AM | #3 |
Member#: 56414
Vehicle:2018 FXT-T CWP/SBL |
Looks to me like your timing is too high. take out 1/2 degree of timing from 60-80 load at 3750 rpms.
03-24-2005, 09:08 AM | #4 | |
Member#: 37731
03-24-2005, 09:33 AM | #5 |
Member#: 26315
BAIC
Thanks for the input. I'll knock out about .5 degree around the knock are and lean out the lower load sites.
03-24-2005, 10:58 AM | #6 |
Member#: 16876
Vehicle:2002 Impreza WRX WR Blue |
Are you sure it's too much timing? It looks like not enough timing. In my experience, the 7th column from the left is the amount of advance the ECU would be running if it were in control, and the 9th column from the left is the amount of advance you have programmed into your timing map. From 2 psi on up, you are running anywhere from 6 to 16 degrees LESS advance than the stock ECU would be happy with.
I would lean out the AFR a bit and try and get advance to be more in line with what the ECU likes. YMMV. |
03-24-2005, 11:11 AM | #7 | |
Member#: 56414
The reason why the timing is lower than the factory ECU wants to run is because with Utec we are running considerably leaner than stock plus running higher boost levels and if we were to leave timing stock with as lean as we are, then we would be knocking all over the place. factory ECU runs about 9.5:1 afr. Also he's on 91 octane which requires lower timing. |
03-24-2005, 11:55 AM | #8 |
Member#: 37731
argh. if you look at that log, and then ALSO look at the maf that the stock ecu sees, you will see why the stock ecu wants to run so much more ign adv. given the accurate readings, your stock ecu would not be wanting to run those values.
03-24-2005, 12:14 PM | #9 | |
Member#: 56414
Lemme see if I grasp this right...given the fact that we've changed values from stock...IE: altering fuel, boost, and timing The ECU is getting different readings than it would stock so that ignition timing is not really what the stock ECU would be giving? |
03-24-2005, 12:21 PM | #10 |
Member#: 37731
yes.
given these 2 lines: Code:
3373 +2.3 3.5 101 20 00 +36.5 25.6 +24.0 +0.1 500.00 3.0 12.78 3663 +8.2 3.9 101 50 00 +24.2 38.5 +17.0 -0.1 500.00 3.5 10.86 |
Similar Threads | ||||
A little utec help.. | kokob | North West Impreza Club Forum -- NWIC | 2 | 12-04-2008 07:21 PM |
A little song help please... | BigWrecKs | Off-Topic | 5 | 05-11-2006 01:51 AM |
A little UTEC help, please. | StiDreams | Engine Management & Tuning | 7 | 07-06-2005 12:41 PM |
a little Utec help | WrXaWd | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 03-24-2005 03:43 PM |
I feel stupid...little Cisco help please | JGard | Off-Topic | 28 | 02-09-2003 03:15 PM |
