01-19-2014, 09:37 PM | #26 |
Member#: 99569
Vehicle:2006 WRX JDM STI V7 OBP |
01-24-2014, 05:47 PM | #27 |
Member#: 340807
NESIC
Vehicle:2007 WRX Limited Black OBP |
I read your review and I ordered one. It showed up cracked and doesn't look to be of great quality. I'll let you know how the customer service is...
03-05-2014, 05:48 PM | #28 |
Member#: 99569
I ordered one as well and just like the guy above me mentioned, it came cracked. There was pieces shaking around inside of it and both ends where cracked at the seam. Hopefully Advanation's customer service will be of help. Im glad I didn't install this pile of garbage. Its looks like hard plastic covered with CF vinyl then finished with a clear coat. So its clearly not real CF. If it broke that easily even before it reached me then who knows what would happen after its already on the car.
Heres a picture of the crack. |
03-05-2014, 06:13 PM | #29 |
Member#: 270965
Vehicle:2007 WRX Black |
Just my .02 to throw in, I picked up an ebay roof vane from mbnational and it was good quality as well. Well packed, well made, good fit.
03-05-2014, 09:33 PM | #30 |
Member#: 328769
NESIC
Vehicle:2005 WRB WRX 2007 UGM 2.5i |
I've been looking into these as well, wasn't sure how good they would be compared to OEM. thanks for the feedback, I'll most likely try and source an OEM one..
03-06-2014, 07:39 AM | #31 |
Member#: 90608
South East
Vehicle:2005 STI, '08 3.0R 05 2.5RS, 92 Legacy L |
this is a straight forward install, but it is time consuming, especially with these one piece vane spoilers. the oem ones have removable feet and are easier to line up the mounting hardware.
you need to remove the back of the headliner to install, that means dome light, and c pillars, and rear seat belts out at the minimum, to gain access to the hardware and drilling. there are 3 layers of metal you will need to drill through, it is time consiuming, and they are at a weird angle, so take your time. the hardware will go up through the pillars from the inside of the car into the bottom of the spoiler. I used some silicone before cranking the hardware tight. not too tight, the pillars are soft and if you over tighten it will crease the metal. after using the provided templates, I marked the holes and drilled. drilled out bigger to accommodate the hardware from the inside. installed. I painted the ends of mine for a more oem look... now just reinstall your interior bits. |
03-10-2014, 05:59 PM | #32 |
Member#: 328769
NESIC
Wow does that look amazing. Thanks for the tips!
03-13-2014, 08:27 AM | #33 |
Member#: 99569
03-13-2014, 10:45 AM | #34 |
Member#: 354873
Wish this worked on the hatch - I would put it on there in a heartbeat.
03-13-2014, 02:04 PM | #35 | |
Member#: 340807
NESIC
Thanks |
03-13-2014, 03:09 PM | #36 |
Member#: 375133
Vehicle:2002 Impreza Outback Red |
Has anyone put this on a wagon before? I want to see how it would look on my 2002 Impreza Outback Wagon
