08-09-2009, 03:02 AM | #1 |
Member#: 212790
Vehicle:2002 Built WRX World Rally Bule |
Car wont run with Utec... :(
I just recently installed a Utec in my '02 WRX. Since then my car will not run.
I am running firmware version 5.8 with turboxs's stg.1 and stg. 2 maps and perameters for stgs. 1-3. I am 100% sure that I have every thing connected right. Would my Cobb tune that I had before be the problem? What do you guys think?
08-09-2009, 06:51 PM | #2 |
Member#: 212790
...Anyone?
08-09-2009, 07:07 PM | #3 |
Sammo Hung
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
the cobb map in your rom file should not be an issue.
but not installing the utec correctly could. did you secure the little ground wire for utec? |
08-09-2009, 07:31 PM | #4 |
Member#: 211850
SWIC
Vehicle:03 WRX Midnight Black Pearl |
where did you get the utec? were you able to make a connection when uploading the maps through hyperterminal? i assume you have a utec that took a permanent dump, or something with your connections... read the manual again and do what jax says...
08-09-2009, 11:06 PM | #5 |
Member#: 212790
I have the ground for the utec connected to the xframe as the manual calls it.
The odd part is, when I have the utec's map selecter set to map 0 (stock) the car runs fine. If I have the selecter set to map one it doesn't run at all. |
08-09-2009, 11:11 PM | #6 | |
Member#: 212790
I got the utec on NASIOC from a seller with a good rep. I was also able to connect and download maps to my utec. |
08-11-2009, 12:43 AM | #7 |
Member#: 212790
Has anyone had any problems with the utec like this before?
08-11-2009, 05:12 AM | #8 | |
Sammo Hung
South East
or totally borked.. what mods are on your car? can you down load maps off utec? do you want me to compare them to the utec maps I have? |
08-11-2009, 10:47 PM | #9 | |
Member#: 212790
I haven't tried to download maps off my utec but I can upload them off my computer to my utec. The maps I'm using are the ones off of turboxs's website. I was using turboxs's stock map and stage 2 map. |
08-15-2009, 01:11 AM | #10 |
Member#: 212790
bump
anyone??? |
08-17-2009, 01:05 PM | #11 |
Member#: 214832
SWIC
Have you called TurboXS yet?
08-20-2009, 07:28 PM | #12 |
Member#: 73755
Vehicle:05 STI |
I think map 0 disables injector scaling, while map 1 and up use it. Is the utec scaling your injectors improperly? You say you picked this up from a previous owner? Did you walk through all the settings and make sure they were set for your car and not the previous owner's?
08-29-2009, 05:35 AM | #13 |
Sammo Hung
South East
read manual about maps..0..1..2..3..4..
0 is factory ecu controls...so you right about disabling injector scaling. down load your map & i'll compare them to the tuned ones I have.. |
09-01-2009, 01:12 PM | #14 |
Member#: 222355
NESIC
Do you have the right Utec for your car? I can't remember which ones, but with the first Utec's they were year specific. Call TXS with your Utec revision # and see if it right for your car.
09-02-2009, 11:36 PM | #15 |
Member#: 147598
Vehicle:95 Impreza 2dr Black |
check your parameters.. im sure the problem is in there..
CAr wont run | Jaships | Newbies & FAQs | 9 | 02-20-2005 12:08 PM |
Car wont run with BOV installed | 03WRXMA | New England Impreza Club Forum -- NESIC | 11 | 07-07-2004 04:32 PM |
HELP car wont run right I'm out of answers | fatray | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 05-28-2004 04:56 PM |
My new car wont run, possibly not all cylinders working??? | grundig5 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 26 | 04-22-2004 01:25 PM |
just installed dr500 fmic ...car wont run! help! | slaterdrew | Texas Impreza Club Forum -- TXIC | 21 | 04-13-2004 01:07 AM |
