06-23-2006, 06:39 PM | #1 |
Vendor Sales Rating: (65)
Member#: 23216
Vehicle:2006 949-457-1234 949-457-1234 |
As always, the *BEST* pricing on ACT and Exedy. Kartboy and STi mounts in stock too.
Hey all,
As usual, we still have the best pricing on ACT and Exedy. If you don't believe us take a look around and compare pricing. Don't be fooled by terms such as Stage 1 or Stage 2; make sure you know exactly what you're getting. If you find better pricing, let us know and we'll beat it. If you don't see a particular combo or item you're looking for, please PM us. Chances are we still have it or can get it. Accessories: Kartboy Short Shifter and Shifter Bushings Combo 02+ WRX - $119 shipped 04+ STi - $175 shipped These components replace the stock shift lever and shifter mount bushings in 1998-2005 model year Subaru Impreza vehicles, including the WRX, Outback Sport, Legacy and Forester. Overall shift throw is decreased by 40% while also eliminating excessive play in the system for a more solid gearchange. This provides a noticable difference and a solid feel. Constructed of CNC'd and TIG welded 4130 Cr-Mo steel and 95A durometer polyurethane. Installs with simple mechanic's tools in under 30 minutes. Goodridge SS Clutchlines - 02+ WRX - $59 shipped The Goodridge SS Clutchline (teflon coated) will improve the feel of your clutch. The stock line is made of rubber and is prone to flexing under hard use. This translates to soft and inconsistant feel in your clutch. The Goodridge line will insure that your clutch feels consistant and firm, even under extreme use. JDM 5th and 6th Gear Close Ratio Conversion Kit - 04+ STi - $319 Shipped for 5/6th Gear Conversion The USDM 6-speed transmission was compromised by stringent US regulations for cruising fuel efficiency. Sacrificed was the close ratio gearing of the JDM 5th and 6th gears. This kit includes a shorter 5th and 6th gears to convert your taller USDM 6-Speed Transmission to a true close ratio JDM STi spec gear box. Professional installation is recommended. Ratios: -5th Gear - 1.062 (0.971 stock) -6th Gear - 0.842 (0.756 stock) Clutch and Flywheel Combos: 1) Exedy Organic Clutch Kit and ACT Steetlite Flywheel (Stage 1)- 02+ WRX -Clamp Load: 2300 lbs/ft. -Pressure Increase: 44% over stock clutch. -Weight: clutch - 14.3lbs, flywheel - 13.9 lbs. -Ideal for VF series, 16g, and 18g turbos. $750 Shipped $1175 Installed!!! 2) ACT HD Street Disc Kit and Streetlite Flywheel (Stage 1) - 02+ WRX -Torque Capacity: 411 lbs/ft. -Pressure Increase: 32% over stock clutch. -Weight: clutch - 17lbs, flywheel - 13.9 lbs. -Ideal for VF series, 16g, and 18g turbos. $649 $1100 Installed!!! 3) ACT HD Street Disc Kit and Prolite Flywheel (Stage 1+) - 02+ WRX -Torque Capacity: 411 lbs/ft. -Pressure Increase: 32% over stock clutch. -Weight: clutch - 17lbs, flywheel - 9.6 lbs. -Ideal for VF series, 16g, and 18g turbos. $699 Shipped $1119 Installed!!! 4) Exedy Hyper Single Clutch/Flywheel Kit (Stage 3)- 02+ WRX -Clamp Load: 2655 lbs/ft. -Ideal for 20g and GT30r turbos. $PM FOR BEST PRICE!!! 5) Exedy Twin Plate Clutch/Flywheel Kit (Stage 4)- 02+ WRX -Clamp Load: 2205 lbs/ft. -Ideal for 20g and GT30r turbos. $PM FOR BEST PRICE!!! --------------------------------------------------------------------------------- 1) Exedy Organic Clutch Kit and Steetlite Flywheel (Stage 1) - 04+ STi -Clamp Load: 2300 lbs/ft. -Pressure Increase: 44% over stock clutch. -Weight: clutch - 14.3lbs, flywheel - 15.4 lbs. $925 Shipped!!! $1350 Installed!!! 2) ACT HD Street Disc Kit and Steetlite Flywheel (Stage 1) - 04+ STi -Torque Capacity: 475 lbs/ft. -Pressure Increase: 32% over stock clutch. -Weight: clutch - 17lbs, flywheel - 15 lbs. $855 Shipped!!! $1275 Installed!!! 3) ACT HD Street Disc Kit and Prolite Flywheel (Stage 1+) - 04+ STi -Torque Capacity: 475 lbs/ft. -Pressure Increase: 32% over stock clutch. -Weight: clutch - 17lbs, flywheel - 11.1 lbs. $879 Shipped!!! $1299 Installed!!! 4) Exedy Hyper Single Clutch/Flywheel Kit (Stage 3) - 04+ STi -Clamp Load: 2655 lbs/ft. -Ideal for 20g, FP Green, and GT30r Turbos. $PM FOR BEST PRICE!!! 5) Exedy Twin-Plate Clutch/Flywheel Kit (Stage 4) - 04+ STi -Clamp Load: 2205 lbs/ft. -Ideal for FP Red, GT30r, and GT35r Turbos. $PM FOR BEST PRICE!!! 6) ACT HD 6 Pad Race Kit and Prolite Flywheel - 04+ STi -Torque Capacity: 608 lbs/ft. -Pressure Increase: 35% over stock clutch. -Weight: clutch - 17lbs, flywheel - 11.1 lbs. -Ideal for FP Red, GT30r, and GT35r Turbos. $819 Shipped!!! $1239 Installed!!! Thanks, Mark Phone: (510) 783-5300 We Accept Paypal! Paypal: [email protected] When ordering w/ paypal, please include the following: product name: XXXX sales rep: Mark Price including shipping: $XXXX Shipping address. *CA Residents please include the necessary sales tax (7.25% or 8.75% for Alameda County)
07-03-2006, 07:58 PM | #4 | |
Member#: 23216
Cheers, Mark |
07-17-2006, 06:14 PM | #10 |
Member#: 23216
It should be around the 1st week of August but as usual, most of them are already presold. I'll shoot you a PM.
Thanks, Geoff |
Similar Threads | ||||
STi 6 Speeds! STi Mounts! *BEST* pricing on ACT, Exedy! | Gruppe-S | Drivetrain | 7 | 07-31-2006 06:41 PM |
RA Gearsets, Bushings, Mounts, guaranteed *best* pricing on ACT, Exedy!!! | Gruppe-S | Drivetrain | 5 | 05-04-2006 09:28 PM |
RA Gearset for WRX and Exedy Twin Carbon STi Clutch IN STOCK! MUST GO NOW! | Innovative Tuning | Drivetrain | 3 | 01-06-2006 10:35 AM |
The best pricing on Exedy and ACT. New products for all you Motorsport junkies!!! | Gruppe-S | Drivetrain | 6 | 11-15-2005 03:46 PM |
Looking for the best price on an exedy clutch/flywheel for a 2002 wrx | mrtrex | Private 'Wanted' Classifieds | 2 | 10-09-2003 05:40 PM |
