02-08-2008, 10:52 PM | #1 |
Member#: 168099
South East
Vehicle:2004 impreza sti wrb |
can i zip tie second o2 sensor and put wideband o2 in that spot?
I got my car stage 2 and i would like to pull out the existing o2 sensor and put my wideband there and i'm trying to not have to take the down pipe off again.. i read from the notes the map for stage 2 will remove CEL for o2 sensor. does that mean i can simply pull it out and zip tie it to something?
Thanks, Sid
02-09-2008, 12:40 AM | #2 |
Member#: 123347
Vehicle:1993 POS burgandy legacy |
yes ,but you car will run a bit rich ,mine idled about 14.0 to 1 when I did it
02-11-2008, 06:18 PM | #3 |
Member#: 106582
South East
Vehicle:2002 Suspension mod Siegel Tuned FP GREEN |
Don't do that. Just pull the downpipe out. It takes 30min. Its only 7bolts. If you take out the second o2 the ecu will hang at 13.5 a/f for sometime before it goes back to 14.7. It has to do with some sort of delay table.
Just do the job right. It will make it easier for a tuner if you get tuned. |
Similar Threads | ||||
Wideband O2 sensor and separate wiring/gauge | elislider | Engine Management & Tuning | 3 | 05-18-2010 05:33 PM |
FS: (FL) PLX Wideband O2 sensor and wiring | javasti | Engine/Power/Exhaust | 2 | 03-18-2010 02:14 PM |
WTB: Knock Link with sensor, and a wideband o2 sensor with monitor | SolidSnake | Private 'Wanted' Classifieds | 2 | 05-04-2006 09:30 AM |
Wideband O2 sensor and Helix V2 dp | JDM 3SGTE | Engine Management & Tuning | 7 | 03-03-2005 09:24 AM |
ne1 here has a deltadash and/or wideband o2 sensor? | Benjamin Tang | Vancouver Impreza Club Forum -- VIC | 4 | 11-18-2003 04:37 PM |
