09-01-2000, 03:27 PM | #1 |
Member#: 745
Vehicle:2004 STi Java Black Pearl |
i wish i could do an oil change,, but
the drain pan screw has fused itself to the oil pan. I tried it when the engine's cold, and I still can't get it off. Am I just weak? or what should I do?
Don
09-01-2000, 03:35 PM | #2 |
Member#: 647
You know I have that problem everytime I do an oil change, so you're not alone. Trying getting a bigger bar and the end of the handle to get it off.
BrianR |
09-01-2000, 03:38 PM | #3 |
Member#: 2245
Vehicle:2000 2.5RS 2DR BRP |
The first time my RS got an oil change I had to put the car on blocks to get more levarage. The screw was super tough to get off! When I put it back on I left it really loose in comparison, no problems yet...
Just make sure you get a well fitted wrench so you don't strip it, otherwise, it might as well be fused on! Good Luck! |
09-01-2000, 03:38 PM | #4 |
Member#: 1730
If it is your first oil change this is not uncommon. If not, get the washers from your dealer ($.65 EA) and don't tighten the drain plug down so much... it isn't going anywhere. As a general rule of thumb only tighten it as tight as you can with your hand at the head of the socket wrench.
-p |
09-01-2000, 04:05 PM | #5 |
Member#: 1135
BAIC
Vehicle:2005 WRX WAGON Silver |
I used a hammer to knock it off the first time. Now I have a futomovalve so I never have to bust my knuckles getting the damn thing off! Best $22 buck I spent. And they are considered SOA.
www.fumotovalve.com [This message has been edited by HomerJay (edited September 01, 2000).] [This message has been edited by HomerJay (edited September 01, 2000).] |
09-01-2000, 04:10 PM | #6 |
Moderator Member#: 922
Vehicle:16 WRX (white) 04 FXT (red) |
I got one of the oil drain valves as well and it works fantastic! No leaks, no problems, and oil changes in < 5 mins!
09-01-2000, 05:39 PM | #7 |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
I had the same problem recently. I did a search here and I also wacked a box end wrench with a hammer. Piece of cake. Think I'll have to get the fumoto too.
Dennis |
09-01-2000, 05:41 PM | #8 |
Guest
Member#:
Hey that drain sounds like something I need. My drain bolt also takes a lot of leverage to loosen. My biggest problem, however, is that once the bolt is off, the oil comes out faster than my drain funnel can handle. Oil winds up on the parking lot and out comes the kitty litter!
09-01-2000, 06:03 PM | #9 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
I like being a tech, I get to use my lift hehehe. No problems with getting my drain plug loose. Try getting a longer wrench or put a piece of pipe longer then the wrench over the wrench for more leverage.
09-01-2000, 10:37 PM | #10 |
Member#: 1426
NESIC
Vehicle:'07 335xi,14 Tundra 848 Evo Race Bike |
Subaru paints/undercoats their cars after everything is assembled... so...what you're trying to do isn't just loosen a bolt, you're breaking the layer of paint that has cured around the edge as well.
Fitz |
09-01-2000, 10:55 PM | #11 |
Member#: 745
holy Cow. No wonder. I tried and tried and as hard as I could, the damn bolt wouldn't budge. Good Lord!!
Don |
09-09-2000, 04:10 PM | #12 |
Techno Sapien
Moderator Member#: 449
Vehicle:2019 Impreza Sport Lithium Red |
Got one of those Engine Oil Drain Valves from Fumoto for each of my Soobies. I installed one of them today. They are very handy. It will make oil changing a snap. I've got some closeup pics for anyone interested. E-mail me direct,the zip is small.
Peaty Thanks Homerjay |
09-09-2000, 04:58 PM | #13 |
Member#: 1135
BAIC
No Problemo! It's great to take engine oil samples from to and I manage to stay cleaner and not use as many rags! Most importantly, you never have to buy those blasted nylon washers again!
09-09-2000, 06:05 PM | #14 |
Member#: 1436
Vehicle:'00 RS '03 LLBean, '05 B4 |
I have a front skid plate installed. Anyone knows if the fumotovalue fits with the skid plate?
09-09-2000, 06:22 PM | #15 |
Techno Sapien
Which skid plate do you have? I have a pic of the valve on the OEM one for the legacy and I'm waiting on my plate from Draken. I don't think there will be a problem with it fittin, but I can report back.
If you want I can measure how much it will stick out. Do you want one with the nipple or the regular one (why does that sound dirty?) Peaty |
09-09-2000, 07:51 PM | #16 |
Member#: 1410
Vehicle:2011 X5 Diesel Space Gray |
I don't knoa about you guys but isn't the first oil change on the house...???
09-09-2000, 09:35 PM | #17 |
Member#: 1110
Vehicle:1999 RS Silver |
So what if it's on the house?? I still wouldn't let them touch my car. I'm sure we could spend days having everyone relate all the horror stories about what happens when lube shops / dealers / anyone who is being paid by the hour do oil changes, but let's just say that I threw that coupon away.
It is quite possible to strip the threads in a drain pan. You really need a torque wrench to do to job right. The torque spec on the drain plug is only ~28 ft-lb. This is about as tight as I can possibly get it with a small 1/4" ratchet. I'd be worried about one of those drain valves developing a leak. Tightened correctly, with a fresh crush washer, the drain plug will never leak. |
09-10-2000, 06:15 AM | #18 |
Techno Sapien
Had one on a previous car and it never leaked on me. HomerJay, ever have a problem?
The quality on these are very top notch. Plus they are approved by Subaru. Check out the link. Peaty [This message has been edited by Peaty (edited September 10, 2000).] |
09-10-2000, 07:52 AM | #19 |
Gone... But not forgotten
Member#: 92
Vehicle:1999 2.5RS Coupe Blueish Kind of |
If you use the stock drain plug, get the drain plug crush washers from the dealer. When you tighten the plug back up, just tighten the plug so that the crush washer is fully crushed and then stop. You can feel it crushing. This is an ingenius way to make sure you don't overtighten the plug. Also at your next change you will notice a bit of effort to brake the plug loose (a standard 3/8" drive ratchet is all you'll need), then the plug is loose enough to get with your fingers. I read about some people re-using the washers. IMO DON'T DO THAT!! These washers are CHEAP only a couple bucks for a bag of 4 or 5 at the dealership. They are cheap insurance that you tighten your drain plug just enough. I've done all 5 oil changes on my car and the only time I had a leak was the first time when I tried using a universal drain plug washer from Pep Boys because I couldn't be bothered to go all the way to the Subaru dealership. So I did two first oil changes and will never make that mistake again!
Fred Edit: HomerJay, What nylon washer? The washers I got are some kind of alloy. Were you using an aftermarket washer or something? [This message has been edited by Fred Zaplitny (edited September 10, 2000).] |
09-10-2000, 09:40 AM | #20 |
Member#: 329
Vehicle:1995 325i Arctic Gray |
I changed the oil on 2 Hondas, & I reused the washers on both of them because they weren't a crush-type. I always replace the one on my RS, although the factory had forgotten to put one on when I took delivery of the car.
09-10-2000, 03:55 PM | #21 |
Member#: 1135
BAIC
Sorry Fred I meant crush washers! Hey Slamck , I have the Primitive front and it's not a problems.
09-10-2000, 04:35 PM | #22 |
Member#: 1503
South East
Vehicle:2012 2012 WRX Sedan Silver |
Too bad that I can't use the valve because I have a Oil Temperature sensor there and my nut is 22 mm!!!
09-10-2000, 08:28 PM | #23 |
Member#: 2253
Vehicle:2000 2.5 RS Red |
The first time you remove the oil plug is always a pain. If you can not remove it with a box end wrench and a hammer, try to heat the area of the oil pan around the drain plug with a propane torch while keeping the plug cool. This allows the hole to expand while plug stays the same size. Don't over do it with the heat.
09-10-2000, 08:54 PM | #24 |
Member#: 1436
Yeah, I have the Primitive front skid plate also. I am going to order the Fumoto plug oline for both my RS and Outback
Now, if someone tell me how to change the oil filter without making a mesh... |
09-10-2000, 08:55 PM | #25 |
Member#: 1436
oops, I mean a mess...
While doing an oil change, decided to pull out the camera :) | blue blurr | Member's Car Gallery | 28 | 01-16-2006 02:31 PM |
problem while trying to do an oil change | sti101 | Service & Maintenance | 11 | 09-07-2004 09:59 PM |
Any Last Tips before doing an Oil Change? | JDMTEG98 | STi Forum Archive | 46 | 09-08-2003 01:59 PM |
Who do you trust for an oil change? | meebs | North West Impreza Club Forum -- NWIC | 12 | 12-08-2002 11:56 PM |
saw a Porsche cruise - wish we could do that! | Mike Smith | General Forum Archive | 3 | 10-10-2000 12:25 AM |
