01-25-2012, 10:11 AM | #1 |
Member#: 292300
TXIC
Vehicle:01 GC8 blue |
Boost question
Ok so I have a 01 rs 2.5 coupe with a 95 jdm sti swap. Need to know if motor can handle 18psi. currently running 15psi
01-25-2012, 10:22 AM | #2 |
Member#: 228784
Vehicle:2004 wrx black, stage 2+ |
why dont you do a ocmpression/leakdown test and you tell us if it can based off those results......
01-25-2012, 10:26 AM | #3 |
Member#: 292300
TXIC
The motor has about 45,000 miles. Its been taken care of. What does the test do exactly?
01-25-2012, 10:37 AM | #4 |
Member#: 181298
Vehicle:2019 KUV 21 Crystal White |
Tells the health of the motor internally... You should talk to a tuner btw.
01-25-2012, 10:39 AM | #5 |
Big Ron
Super Moderator Member#: 18062
Vehicle:on car parts so PM me b4 j00 buy |
You should be talking to a tuner, NOT the internet. You don't just turn up boost on Subarus without knowing engine management, whether your motor is good, what turbo you have, knoweldge and use of air fuel ratio equipement, etc.
01-25-2012, 12:22 PM | #6 |
Member#: 301549
Vehicle:2005 banging one aspen white |
Test it and boost it!
01-25-2012, 12:58 PM | #7 | |
Member#: 292300
TXIC
01-25-2012, 01:07 PM | #8 | |
Member#: 292300
TXIC
01-25-2012, 01:11 PM | #9 |
Member#: 205324
Vehicle:2002 Impreza wrx midnight blue pearl |
dont the jdm sti's boost 18-19 from the factory?
01-25-2012, 01:15 PM | #10 |
Member#: 129833
Vehicle:2005 Forester XT Obsidian Black Pearl |
It should be able to handle 18 psi at least for long enough to break something. How do you plan on increasing the boost? If you are going the MBC route, at least find out what your A/F ratios look like at 15 psi. Increase it by 0.5 psi increments at a time. Then report back when you've blown a piston.
01-25-2012, 01:15 PM | #11 | |
Member#: 292300
TXIC
01-25-2012, 01:26 PM | #12 | |
Member#: 292300
TXIC
01-25-2012, 01:36 PM | #13 |
Member#: 129833
The reason why everyone is giving you a hard time is because it's nearly impossible to say whether it can handle it or not, given the age of the engine. Also keep in mind that JDM engines are made to run on higher octane fuel than we run here. Do you have any way to monitor A/F ratios, knock, and EGT?
01-25-2012, 01:47 PM | #14 |
Member#: 292300
TXIC
No I dont. What would be a good but lower cost way to do so?
01-27-2012, 01:01 PM | #15 |
Member#: 205324
if the wastegate actuator is the reason your gonna be going to 18 psi then either buy something that can monitor data, or turbosmart just came out with an internal wastegate for subaru's that has different springs so you could just put in the 15psi spring. there's probably many other brands that offer wastegates that do the same thing sorry if giving you info. is being an a$$ then you shouldn't have asked a question.
01-27-2012, 01:20 PM | #16 |
Member#: 129833
Since it's JDM, and pre-1996, I'm not sure any OBD II readers are going to work on it, so you probably need to install hard-wired gauges to read that information.
01-27-2012, 03:29 PM | #17 | |
Member#: 292300
TXIC
Similar Threads | ||||
Just installed boost guauge, have a boost question? | RS 1986 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 1 | 06-22-2010 07:22 PM |
newb boost question....how do you turn up the boost | Meat Supply | Newbies & FAQs | 9 | 03-16-2009 07:25 PM |
I just installed a boost gauge and I have a boost question... | Hokie-wrx wagon | General Community | 12 | 08-28-2005 01:58 PM |
Boost Question. | S Leung | Vancouver Impreza Club Forum -- VIC | 9 | 06-07-2001 12:03 AM |
Boost question | Tensecgn | Normally Aspirated Powertrain | 0 | 03-11-2001 02:32 PM |
