04-14-2008, 08:48 AM | #1 |
Member#: 15359
Wheel Bearing Grease
Looking for any recommendations on what grease to run in the wheel bearings. I've been using the stock grease, and replacing the bearings twice a year, however have been wondering if it's worth repacking them.
thanks Duncan
04-14-2008, 09:10 AM | #2 |
Member#: 4830
SCIC
Vehicle:2015 Alfa Romeo 4C Rosso Competizione |
I have heard good things about Redline grease.
http://www.ogracing.com/catalog/2-Ca...NTHETIC-GREASE |
04-14-2008, 09:25 AM | #3 |
Member#: 127041
Vehicle:02 WRX Midnight Blue Pearl |
Huh? Twice a year??? I did one a few weeks back and it made me never want to do it again.
04-14-2008, 12:52 PM | #4 |
Member#: 65206
SCIC
Vehicle:1986 Brat Red |
I use the Neo HP800 high temp wheelbearing grease, seems to stay in the bearings longer than the stock stuff. Rated to 800*F. Soak out the stock grease with mineral spirits and repack by hand. A tub costs about $30 and is good for at least 10 bearings, possibly more. Messy but a good idea if you get high brake temps and heavy loads from sticky tires.
http://www.allraceoil.com/neolubricants.html http://www.allraceoil.com/neohp800bearing.html The Neo CV grease is a good idea as well. |
04-14-2008, 02:17 PM | #5 | |
Member#: 7492
South East
Vehicle:No race cars www.tomhoppe.com |
-Tom |
04-15-2008, 02:05 AM | #6 |
Member#: 29201
Vehicle:BMW M3 Honda S2000x2 |
I use Amsoil Series 2000 racing grease. I also used to pack a spare set of knuckles when I ran a 5x100 hub.
When you say 'stock grease', do you mean the little dabs that come in a new set? |
04-15-2008, 03:44 AM | #7 |
Member#: 29757
South East
Vehicle:06 STI White |
I also used to have to replace my front wheel bearings about that often in my wrx, about every 3 or 4 track days. I switched to Neo HP800 and it made a HUGE difference. I think I had to replace them like once more since I switched to the new grease. I really recommend it, and yea replacing and re greasing them is a huge pain, so its definitely worth it.
04-15-2008, 12:17 PM | #8 |
Member#: 58865
RMIC
Vehicle:2004 WRX 99ESP - Drew =) |
What parts should I looks for if I want to have some "spare" wheels bearing setup? Just knuckles and hub?
I'm assuming I'd need to do an alignment after installing new ones right? |
04-15-2008, 02:01 PM | #9 |
Member#: 14987
International
I use the ART front bearings which last longer than OEM. They look to be packed with the red Redline bearing grease. I go through a set of front hubs/bearings each season.
04-15-2008, 02:21 PM | #10 |
Member#: 15359
Where can I get ART bearings?
Duncan |
04-15-2008, 02:34 PM | #11 |
Member#: 83044
South East
Vehicle:04.5 blue STi 97 miata, 93 miata turbo |
^^^what he said
04-15-2008, 03:08 PM | #12 |
Member#: 15001
Vehicle:STi V8 Spec C Power NESIC TrackH0z # 10 |
I used to eat bearings like mad (and crack rotors) until I switched to Stoptechs - now I replace the bearings usually once a year, just as insurance. I carry a spare set of spindles with me as well.
-Keith- |
04-15-2008, 04:18 PM | #13 |
Member#: 14987
International
http://www.appliedracingtechnology.com/
but they only make em for Miatas. I should have been more specific but I think that if Redline grease is good enough for ART hub/bearings then it would probably work well for STI bearings too. |
04-16-2008, 04:05 AM | #14 |
Member#: 29757
South East
Yea just a spare set of knuckles and hubs, and that should be it. You shouldnt NEED a spare set as long as you replace the bearing as soon as you feel it is loose. If you wait too long to replace it you risk damaging the inner hub, which is easy to do actually. And by switching to the Neo grease you will be replacing the bearing much less often and negate the need to have a spare set.
04-16-2008, 04:07 AM | #15 | |
Member#: 29757
South East
Lol, why mention it then? Go with the Neo grease. |
04-16-2008, 12:42 PM | #16 |
Member#: 29201
04-16-2008, 12:48 PM | #17 |
Member#: 29201
Yes, just a knuckle and hub. I went to a pick and pull junkyard and got a set for $30. They came in very handy at the next track day. One of my friends lunched his right wheel bearing and I gave him one. Then I had a ball joint go bad on the left side and had to swap the whole knuckle since I couldn't separate the ball joint from the knuckle.
04-16-2008, 02:14 PM | #18 |
Member#: 15359
I bought a spare set recently. They'd been sitting outside for awhile, so I need to disassemble them, knock the rust off, paint and then reassemble. After that I'll just store them in the trailer until they're needed.
Duncan |
04-24-2008, 08:02 PM | #19 |
Member#: 15359
When you repack the bearing, do you take out the plastic retainer and remove the inner races, or can you just pack the bearing as a unit. I've soaked them in mineral spirits to remove the factory grease.
thanks Duncan |
04-24-2008, 09:19 PM | #20 |
Member#: 65206
SCIC
I pull them apart and clean them up thoroughly. I use a screwdriver and my fingers (wear gloves) to really clean everything out well. There is a lot of grease that doesn't come out unless you do that. Not sure how the two different greases would interact. Some don't like each other and turn sticky. Better to be safe than sorry, the two halves go back together pretty easily. You also need to repack them separately or there just won't be enough grease up in where it needs to be. I'm sure there is a bearing packing process somewhere online, doesn't need to be subaru specific, a wheel bearing is a wheel bearing.
04-25-2008, 07:27 AM | #21 |
Member#: 15359
thanks,
Duncan |
04-26-2008, 01:34 AM | #22 |
Member#: 14311
Vehicle:2010 GTI White |
04-26-2008, 09:14 PM | #23 |
Member#: 29549
TXIC
Vehicle:2003 WRX WRB |
so redline or neo - any opinions on which is better? I really like the idea of the spare knuckles. I need to look into that - pick and pull here I come lol
04-27-2008, 12:05 AM | #24 |
Member#: 29757
South East
With the neo grease I used to push the grease in from one side until all the other grease was out. The oem grease is white while the neo is blue so its easy to tell one from the other. Its not necessary to clean off all the old grease first.
Similar Threads | ||||
wheel bearing grease ? | jsin93816 | Brakes, Steering & Suspension | 20 | 02-15-2010 12:25 PM |
FS: Wheel Bearings w/seals. Prepacked with Neo HP800 Bearing Grease | Gro Harlem | Suspension/Brakes/Handling | 9 | 03-04-2009 10:35 AM |
wheel bearing grease | DJ_STI | Newbies & FAQs | 8 | 01-17-2005 10:10 AM |
which wheel bearing grease ? | JasonE | Brakes, Steering & Suspension | 3 | 06-08-2003 11:15 AM |
Wheel Bearing Grease | BG5 | Service & Maintenance | 4 | 12-07-2001 03:25 AM |
