Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 05-19-2012, 12:40 AM   #1
eastvanscreen
Member#: 320609
Default My first Loyale and ticking noise
I just purchased my first subaru- a 1990 Loyale from the original owner with 49 000 miles on it. When the car warms up and idles, their is a ticking sound. it seems to go away when i drive. Any ideas of what this might be- the car was owned by an 83 year old lady and only putted around her neighborhood- i am wondering if an oil change and a high rpm highway drive might help.
eastvanscreen is offline   Reply With Quote
Old 05-21-2012, 01:45 PM   #2
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
It might.... its known as the tick of death or TOD. Often resealing the oil pump will fix it if a good long drive does not.
Flowmastered87GL is offline   Reply With Quote
Old 05-27-2012, 07:48 PM   #3
moosen
Member#: 313040
2003 Wrx Hybrid
Have you timed your car?
moosen is offline   Reply With Quote
Old 06-01-2012, 02:18 AM   #4
TurboneX
Member#: 21676
RX 02Foz,05OB
If it was timing it would tick all the time, warm or cold.
Run a bottle of Seafoam or Marvel Mystery Oil thru it, that might free up the sticky lifters.
TurboneX is offline   Reply With Quote
Old 06-15-2012, 05:53 PM   #5
wrxblue03
Member#: 293735
2003 wrx vf39 swap
blue
I work on subarus I you look at the timing covers and pop out the rubber plugs on both sides loosen the too blots on the tensioners through the holes that the plugs were in and it'll take up the slack from the timing belts an that will resolve the problem if it is your timing. If that does not work its a lifter.
wrxblue03 is offline   Reply With Quote
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 01:48 PM
My first subaru and first brand new car Rabidsquirel Newbies & FAQs 15 11-02-2011 02:07 PM
sudden FLASHING cel and ticking noise from left bank.. rolzrex Factory 2.5L Turbo Powertrain 7 06-25-2009 08:49 PM
help! rough/shaky idle and ticking noise from engine resideinva Factory 2.0L Turbo Powertrain 10 05-15-2008 09:57 PM
Pulley squeking and ticking noise from the cabin S-WRX Service & Maintenance 1 07-23-2004 02:18 PM
Message Board Statistics All times are GMT -4. The time now is 06:01 PM.
