01-14-2004, 04:55 PM | #1 |
Member#: 47261
W. Canada
Spark plugs and wires
So here I am. I need a new ignition coil, wires, and I might as well change the plugs while I'm in there.
I am getting the coil from the dealer under warranty, so they are putting that in. I am getting new wires because they are not covered. What brands are good and is silicone better than stock (copper I am assuming)? As to plugs I bought NGK Irid.s and it says not to gap them. So who do I believe? Book or NGK? I looked around and couldn't find anything on this subject so help would be great. PLease?
01-14-2004, 06:03 PM | #2 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
i run OE as my engine/internals are not modified.
why spend extra $$ on something that is not going to help your car... (bling factor?!?) when you can get a set of OE wires MADE SPECIFICALLY for your Subaru for about $30?? i use OE coil/plugs and wires as it makes sense to do so. spend the $ saved on other 'better' mods. cheers Jamie www.subiegal.com |
01-14-2004, 06:11 PM | #3 |
Member#: 47261
W. Canada
One problem there Gal...
Up here in the great white north it costs 120 bucks for the OE wires. I know the exchange is bad... but not THAT bad. I can get a set of lite something or other (basicly bosch) for 95 or I can get specially made ones for about 110. Other than that I'm stuck ordering from the US, and that will cost anywhere from 90-300 bucks anyway. 300 bucks being for from a site I wouldn't trust anyway. |
01-14-2004, 06:19 PM | #4 |
Member#: 20444
Vehicle:2006 Outback 2.5 XT Garnet Red Pearl 5MT |
I really would stick with the stock wires if at all possible. Aftermarket wires like the Magnacores have a long history of problems with the 2.5 RS and there are very few enthusiasts that I know of who have them and have not had at least infrequent trouble with them popping off, causing misfires, etc.
I would stick to what NGK says about the spark plugs, after all, they make them. Let's say that you buy a set of the Iridiums for the 2.5 RS-- they should come pre-gapped and should work right out of the box and you should not have to gap them again. However, it wouldn't hurt to double check what NGK says the gap is to make sure that it fits the stock specs. |
01-14-2004, 06:22 PM | #5 | |
Member#: 47261
W. Canada
I know they have that sort of history. If I stuck with the same brand as my plugs, shouldn't it work properly. I'd assume so since I'd assume that they'd test it on their own products and not the stock products. I may get them custom made and that would save me 10$. I don't have a lot of money, and therefor need cheaper alternatives.
01-14-2004, 07:11 PM | #6 | |
GC84Ever
NWIC
OE wire sets here for example ....better than $110 for some aftermarket junk that you'll be replacing in a few months as they keep popping off your coil pack Jamie |
01-14-2004, 08:34 PM | #7 |
Friendly Neighbourhood
Moderator Member#: 269
VIC
Vehicle:2005 ABP LGT LTD BP6 00 Impreza RS GM6 RIP |
Ah, but being from Canada, we have to deal with the exchange rate (which isn't that bad right now), then shipping, and then duty, and then our lovely taxes on top of that!!!
Sometimes what's a steal in the states, becomes a nightmare when it gets shipped up to Canada. LaterZ! Darren!! |
01-15-2004, 01:43 AM | #8 | |
Member#: 47261
W. Canada
On that note - Any thoughts on Silicone wires? Worth it or not? |
01-15-2004, 07:05 AM | #9 |
Member#: 17252
Vehicle:'06 WX8 59E |
For plugs & NGK wires, Canada has its own and very best clubplug.net.
01-15-2004, 07:12 AM | #10 |
Member#: 1415
RMIC
Vehicle:2015 F150 3.5EB 2014 Jeep GC |
You could get some MSD wire and do what someone did on Scooby Mods by making your own wires. I forget the total cost though.
Bosch makes a decent wire, so does AC DELCO (the orange ones) and of course the OEMs are nice as well. |
01-15-2004, 07:38 AM | #11 |
Member#: 4830
SCIC
Vehicle:2015 Alfa Romeo 4C Rosso Competizione |
"On that note - Any thoughts on Silicone wires? Worth it or not?"
The OE wires for the Subaru are silicon. |
01-15-2004, 10:41 AM | #12 |
Member#: 18074
Vehicle:2008 Speed3 Black |
I think you can trust Jamie. Not like you can't find a place to bitch at her if something goes wrong, and not like she won't make it right.
As for seeing what you're getting, if you get stock replacement stuff, look at the ones you have. Imagine them without dirt on them and, voila, you see what you get! |
01-15-2004, 11:33 AM | #13 | |
GC84Ever
NWIC
so true..... Jamie |
01-15-2004, 12:28 PM | #14 |
Member#: 47261
W. Canada
Well after all this talk, I'm wondering...
Just because the dealer says they need to be replaced, do they???? The mechanic only looked at the posts on the coil. I'm assuming that he assumed that the wires are bad too. Is there an easy check if the wires need to be replaced? Also, lately I've noticed that if I let my revs get even close to 3500 the cockpit starts stinking like somethings burning. I did smell fuel the other day too. I don't have a CEL at all, and the car seems to work fine other than gas mileage being off. Quarter tank for about 60miles (100KMs) seems a little off. I'm pretty sure it should be more than that. I'm not driving it hard other than the ocassional burst when some moron is tailgating. I have a CAI and I know my O2 sensor is good cuz I made him check it when I had it in to look at the coil. Any thoughts people? I am changing my plugs after I get the car back from the coil swap. |
01-15-2004, 12:55 PM | #15 |
Member#: 18074
You can test the wires. Procedure's in the service manuals. Don't have it handy, though.
01-15-2004, 12:55 PM | #16 |
GC84Ever
NWIC
it's always a good idea to replace the wires
when you replace coil/plugs not a NECESSITY per se... but it sure is the smart thing to do... example? #3 coil was looking pretty corroded i cleaned (wire brushed) it thoroughly, replaced wire #3... and the issue has not resurfaced. just a good idea to keep it all on an even par if you replace one, why not replace the others as well? cheers Jamie www.subiegal.com |
01-15-2004, 12:58 PM | #17 |
Member#: 18074
Hey Jamie, you have a PM on the way. SImilar topic to this.
01-15-2004, 03:15 PM | #18 | |
Member#: 47261
W. Canada
So with that being said... I'm told that the stock wires ARE silicone. Aren't silicone good for life? I think I read that somewhere in the forum. Someone said that they've had the same wires on their car for 3 1/2 years. Is that right? If so, I shouldn't NEED to change the wires. I want to becuase I would like brand new nice shiny blue ones but if I don't need to fork the cash... then why? Basicly I'd like the wires but I don't wanna fork over $100+ that doesn't need to be changed. Last edited by soccer_freak_m@hotma; 01-16-2004 at 11:28 AM. |
01-16-2004, 03:13 PM | #19 |
Member#: 47261
W. Canada
GREAT! (I'm adding this a couple days later) NOW the stupid dealer is telling me that the warranty is NOT going to cover my ignition coil. Total BS if you ask me. I need somewhere to get a coil for under 300$ Canadian. Any helpers?
Also I checked the wires and Number 2 (if I remember correctly) is bad. So it looks like I will have to change them anyway. |
01-16-2004, 03:34 PM | #20 |
Vendor
Member#: 19819
hello again
we can get you your coil for $128.50 USD (99 RS) - which is about??? $170 Canadian? wires are $29 for the set of 4 and we can ship via US Postal to save customs/shipping fees just contact me to order as the coil pack is not in our on line store at this time. cheers Jamie www.allsubaru.com || www.subiegal.com |
01-16-2004, 03:47 PM | #21 |
Member#: 47261
W. Canada
I'm assuming that the coil is OEM? MSD? I dont' know. Honestly I'm so confused right now. I have someone telling me MSD is same as OEM and then I have another guy saying that MSD is better than OEM. I don't know. This is honestly my first car and I haven't even had it for 3 months yet.
The wires are Prestolites? Bosch? I'll probably end up buying at least the coil from you. |
01-16-2004, 04:05 PM | #22 |
Member#: 18074
It just keeps getting more confusing as you go!
01-17-2004, 06:21 AM | #23 | |
Member#: 7101
Vehicle:00RS I want to fill your mouth with spiders |
01-17-2004, 03:03 PM | #24 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
Soccer_freak, I don't know of any manufacturer that makes a replacement coil pack for Subarus. MSD makes a replacement distributor-less ignition (the MSD DIS-2 I think it's called), but that's not what you want or need - it's way more expensive, and it's way overkill for a stock engine. The general consensus here seems to be that the stock ignition system is pretty stout, so just using OEM components is fine.
I'm sure the parts Subie Gal is offering you are OEM. Now, what's the story with the dealer? Why did they originally tell you the coil pack would be covered under warranty and then change their mind? One thing you need to learn about cars is Don't let the dealer screw with you! Pat Olsen '97 Legacy 2.5GT sedan |
01-17-2004, 03:13 PM | #25 |
Member#: 47261
W. Canada
well I guess I should update what's going on.
I told them to change the plugs to the new ones I bought and told them to leave everything else. I found a place here that I could get some OEM wires for 77 bucks in stock(Canadian of course). I installed those and when I pulled off the old wires the dealer had actually gone ahead and cleaned and put the silicone on the posts of the ignition coil. When I pulled out the number 2 wire the metal piece inside the boot actually stayed ON the plug. Problem??? I THINK SO! So I replaced all the wires and fired her up. She's running completely perfect and I think the dealer was just messing with me on the coil thing. Can't trust a mechanic's word sometimes I guess. |
FS NC: EJ20K NGK Spark Plugs and Wires | handyRS | 1993 - 2001 Impreza Specific Parts | 0 | 04-18-2010 07:58 PM |
How many hrs labor for spark plugs and wires? | Sir Punk | Newbies & FAQs | 15 | 10-06-2009 10:15 PM |
changed spark plugs and wires...now have CEL flashing...??? | marcus12 | Normally Aspirated Powertrain | 5 | 11-01-2005 07:01 PM |
Spark Plugs and Wires? | Steven Saunders | Normally Aspirated Powertrain | 15 | 02-02-2001 12:19 AM |
