02-22-2007, 01:39 PM | #51 |
Member#: 90539
South East
Vehicle:My BOV goes COVFEFE! |
So even though I now have the 02 wrx short throw shifter assembly I still can't connect it to my 96 transmission because where the rod comes out of the transmission is the opposite of what it needs to be? Do I have to also get the piece that is riveted (or whatever) to the transmission? Instead of the "x" connecting linkage, I have a double clevis or something? I removed my entire shifter assembly from the car, both rods, and where it connects to the transmission is totally opposite. The bushings are pretty much non existent. Is there a way to get the joint that is connected to the transmission rod off? Drilling? Punch?
04-10-2007, 12:44 AM | #52 |
Member#: 82431
NWIC
Vehicle:2006 06 wrx limited CGM |
Right place
Hey fellas, I just installed the Kartboy SS with front and rear bushings. It feels soooo amazing. Like I imagine a 911 feels. I have a couple of install tips though.
On my 06 there is no need to remove the whole center console, the shifter housing comes off in a seperate piece. Makes that part really easy. If you do the bushings, here are a few things that scoobymods did not mention, nor have I seen here. To get the front bushing out, just push the whole thing out using the stud the thing was attached to. The rear bushing is a pain in the ass no matter what you do, the exhaust and driveline are in the way. I found that if I left the shifter unhooked from the linkage, there was a lot more play and made the whole process much easler. The rear bushing is impossible to install with the shift lever attached to the linkage. Leave it un-attached and the linkage will more around under the car a whole lot more. |
10-11-2007, 03:58 PM | #53 |
Member#: 101206
NESIC
Vehicle:1992 Built, S/C'd, 6MT SVX #122 400whp |
Would anyone recommend upgrading the bushings on an 07 6spd? I have the tranny in my garage waiting to go into a SVX and was wondering if this is something worth doing while the tranny is out and the linkage is easily accessible.
10-11-2007, 04:33 PM | #54 | |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
Oh, and a 6MT SVX would rock! You gotta tell us how it turns out. |
10-11-2007, 08:13 PM | #55 |
Member#: 101206
NESIC
It has already been done and it does rock. My svx will be the 4th or 5th one. My question was whethere this was an upgrade or simply a replacement for when stock bushings wear out.
10-11-2007, 10:06 PM | #56 |
Member#: 93646
Personally, I think they're an upgrade. Hopefully others who have bought them will chime in so you don't think I'm biased.
10-11-2007, 10:43 PM | #57 |
Member#: 101206
NESIC
k........... and a whole bunch of letters to meet the post requirements
10-11-2007, 11:58 PM | #58 |
Member#: 90539
South East
Thanks again for the advice, TIC. Mine still shifts firmly with the new bushings and linkage. My friend has an 06 with upgraded shifter components and always seems amazed at how firm mine feels.
10-12-2007, 09:15 AM | #59 |
Member#: 101206
NESIC
So which kit would you recommend for my application.
10-12-2007, 12:28 PM | #60 |
Member#: 93646
05-18-2008, 12:01 PM | #61 |
Member#: 2348
Vehicle:2006 WRX TR Steel Grey Metallic |
any word on the older tranny kits? My wifes 96 leggy 5mt needs 'A' bushings real bad, I mean real bad. Help!
08-28-2008, 02:53 PM | #62 |
Member#: 187579
After scanning thru the thread I have a question that didn't seem to be addressed.
How much improved feel comes from the upgraded bushings and how much comes from the short throw shifter components? My reason for asking is that I would like to upgrade the bushings for better feel but keep the stock shifter and linkage. Am I doing a lot of work for very little improvement or does just changing out the bushings give a substantial improvement in the feel? |
08-28-2008, 03:45 PM | #63 | |
Member#: 93646
08-28-2008, 04:08 PM | #64 |
Member#: 187579
08-28-2008, 04:18 PM | #65 |
Member#: 78075
NWIC
Vehicle:98' SF5 STI 93' GF8 (rally) |
I swapped out the front and rear shifter mount bushings when i did my wrx conversion into my 96 wagon. Compared to how the shift feel felt before the conversion it was a night and day difference. Driving my car, and then my dads one year newer GF is totally different in feel...
Front/rear shifter mount bushings on stock shifter is great! I just finished the swap about 8 weeks ago, and put in a kartboy short shifter last week... i think the bushings made a much bigger difference than the short shifter. I almost liked the feel of the stock shifter with the bushings more... |
08-29-2008, 09:27 AM | #66 |
Member#: 151928
South East
Vehicle:09 Triumph S3 |
alright, so do we have linkage and pivot bushings for the 02 yet? I got all the front and rear stays from you guys a month or so ago, TiC. Didn't see the other two available????
08-29-2008, 07:35 PM | #67 |
Member#: 188165
woot.
Very nice work- thanks for the information.
08-30-2008, 09:33 PM | #68 | |
Member#: 40720
Vehicle:03 wrx/jdm 6mt PSM |
just got a 07 jdm 6mt in my 03 wrx. could use a set of bushings. shifter seems a bit to sloppy. |
11-24-2008, 08:08 PM | #69 |
Member#: 193252
NWIC
Vehicle:2004 WRX Platinum Silver Met. |
i have the factory short shifter on my 04 wrx, would it make any difference to get the perrin performance short shifter with polyurethane bushings? or would this just be a waste of $100? they're on sale right now, so i figured it would be a good time to upgrade if i have to.
11-24-2008, 09:55 PM | #70 |
Member#: 126441
SCIC
Vehicle:03 bugeye |
^^waste of money. get the kartboy front and rear shifter bushings if you haven't already
11-25-2008, 11:19 PM | #71 |
Member#: 193252
NWIC
thanks, i just didn't wanna be an idiot and throw my money away.
11-25-2008, 11:22 PM | #72 |
Member#: 93646
Both have been out for a LOOOOOONG time. pivot bush are in stock. linkage is out of stock with more on the way.
03-30-2009, 05:03 PM | #73 |
Member#: 206969
Great info... thank you
03-30-2009, 06:10 PM | #74 |
Member#: 206969
question to Turn in Concepts.... You said
"Ok, I got that. How do I tell which one I have? Here's the breakdown: - If you have a 1997-2001 Impreza you will need the narrow version - If you have a 2002+ Impreza you will need the wide version (except in below) - If you have a 2002+ Impreza with the FACTORY optional short shifter you will need the narrow version" Does this mean if I have a 99 rs 2.5 I can use a stock wrx short shifter for an upgrade? Im just looking for a good deal, my rs tranny blew up and Im putting in another one so I would like to do a little upgrading while its out. |
03-30-2009, 06:16 PM | #75 | |
Member#: 67
SCIC
Vehicle:1999 Outlasting the competition. |
T |
Drive Performance Mag and the STI shifter Upgrade? | cgerald1 | Transmission (AT/MT) & Driveline | 21 | 05-14-2009 03:50 PM |
STI Short Shifter upgrade for WRX | LEMON03 | Transmission (AT/MT) & Driveline | 5 | 05-08-2005 04:36 PM |
kartboy vs. factory short shifter upgrade | sdseagles | Newbies & FAQs | 16 | 04-30-2002 09:57 AM |
FS: nice cheap shifter upgrade for Legacy 5 speeds | dvancleve | Legacy Forum | 3 | 06-27-2001 05:04 AM |
Shifter Upgrades | Narso | Technical Forum Archive | 17 | 06-01-2000 12:55 AM |
