01-26-2016, 06:56 PM | #101 |
Member#: 375462
NWIC
Vehicle:2006 Impreza WRX STI WR Blue |
The first time I removed one, I used a punch that was a little too small and had to do it twice... hard to see that there are actually two concentric roll pins in one spot =/
You normally don't have to remove this unless you're upgrading to a universal- or helicopter-joint - is that what you're doing?
01-27-2016, 08:48 AM | #102 |
Member#: 138994
Vehicle:2006 WRX, 6MT, 5x114 |
Cool. I like that over the OEM joint. Did it just swap in or did you have to modify it to work?
01-27-2016, 11:11 AM | #103 |
Member#: 375462
NWIC
01-27-2016, 11:29 AM | #104 |
Member#: 107618
Vehicle:06 GG WRX / 09 FXT @florencedestinedfxt |
I think the whole thing had to come out when I did it because one of the bolts can't come fully because it hits the transmission tunnel. I can't remember exactly but it had to come out in order to swap out the linkage bushings.
That's an interesting linkage though that comes with the short shifter, are they rubber bushings or solid mount? |
01-27-2016, 07:59 PM | #105 | |
Member#: 411834
TXIC
Vehicle:2005 Legacy GT Obsidian |
I really dig the design of that ujoint, it looks HQ. If you ever find the p/n, lmk. dealership said they didnt carry the spring pin for the stock clevis, does NASIOC have any alternatives to re-using the old spring pins? |
01-28-2016, 11:07 AM | #106 |
Member#: 375462
NWIC
It's shown in my picture above - unfortunately, it has been discontinued. Pegasus sells helicopter joints that will do the same thing, however. The reasoning behind the U-joint was likely for quick transmission change-outs rather than lower compliance.
10-11-2021, 06:41 PM | #107 | |
Member#: 526940
Will this fit a 2008 impreza 2.5i wagon? http://turninconcepts.com/driveline/08-impreza-super-shifter-set.html |
10-12-2021, 09:46 AM | #108 | |
Member#: 30804
SWIC
Vehicle:87 Yugo Red |
Drive Performance Mag and the STI shifter Upgrade? | cgerald1 | Transmission (AT/MT) & Driveline | 21 | 05-14-2009 03:50 PM |
STI Short Shifter upgrade for WRX | LEMON03 | Transmission (AT/MT) & Driveline | 5 | 05-08-2005 04:36 PM |
kartboy vs. factory short shifter upgrade | sdseagles | Newbies & FAQs | 16 | 04-30-2002 09:57 AM |
FS: nice cheap shifter upgrade for Legacy 5 speeds | dvancleve | Legacy Forum | 3 | 06-27-2001 05:04 AM |
Shifter Upgrades | Narso | Technical Forum Archive | 17 | 06-01-2000 12:55 AM |
