04-28-2002, 09:34 PM | #1 |
Member#: 17296
Vehicle:2002 WRX Platinum Silver Metallic |
kartboy vs. factory short shifter upgrade
Just so I understand this correctly . . . when you buy the kartboy short shifter, you get only the shorter shifter and the bushings if you want. But when you get the factory short shifter it's a different linkage also? Wouldn't the best thing be to get the factory shorty and add bushings after so you get the improved linkage? Any thoughts or comments would be appreciated. Thanks
04-28-2002, 10:52 PM | #2 |
Member#: 6049
Vehicle:02 WRX & 99 RS Black |
The only reason you get the linkage is to maintain height of the stock shifter. If you go kartboy (I have one btw) its not as tall.
Also, lets factor in price... kartboy wins...hands down. its a great mod. |
04-28-2002, 11:06 PM | #3 |
Member#: 2916
SCIC
Vehicle:02 duburu arr exu |
the actual linkage doesnt look much different than the stock linkage. from the comparison pics of the stock linkage and short throw linkage i've seen, i could not make out any differences aside from the actual shift lever. the kartboy will give you short throw than the sti kit but it will also lower the height a bit.
oh and installing the linkage would be much more trouble some than just the kartboy bushings and level imo. the kartboy install is really quite simple, the only hard part about it is gettin the level to pop back into the socket. |
04-29-2002, 01:20 AM | #4 |
Member#: 9185
Vehicle:2012 Toyota Tundra Black |
Ya but factory would be covered under warranty .....hmmmmmmm
Wolf |
04-29-2002, 09:29 AM | #5 |
Member#: 17548
short shifter
Hey, anyone tried one of those adjustable short shifters from SPO? If so, how did you like it? I was thinking of buying one since it is adjustable and looks sweet (w/o the boot)...and its only slightly more money than the kartboy one.
04-29-2002, 11:08 AM | #6 | |
Member#: 2916
SCIC
Re: short shifter
04-29-2002, 12:17 PM | #7 |
Member#: 17296
factory shorty
I know how popular the kartboy is, in fact I'm probably still going to get one. But I realized the factory shorty includes a different (upgraded?) linkage and was wondering if anyone has it and what they think.
04-29-2002, 02:07 PM | #8 |
Member#: 1273
Vehicle:98 Impreza RBP |
I've heard....
that when you buy the whole thing linkage and all it's not really all that different from stock......In my opinion i would just buy the kartboy(i did), and spend the rest of the money on something else.
04-29-2002, 04:15 PM | #9 |
Member#: 17548
I guess nobody has tried the SPO adjustable short shifter???...And I checked Cobb (which really didn't answer my questions to begin with) and I didn't see one. I just want to know if its comparable to the kartboy and other non-adjustable shifters. Anybody know?
04-29-2002, 06:12 PM | #10 |
Member#: 9015
Vehicle:2002 Impreza 2.5RS Platinum Silver Metallic |
I installed a kartboy in my car and it made a LOT of noise, besides the noise (and hassle it would take to make it go away) it was a really nice shifter.
me = saving up for STi. |
04-29-2002, 06:20 PM | #11 | |
Member#: 17592
Vehicle:2005 Evo Apex Silver |
04-29-2002, 06:21 PM | #12 |
Member#: 15195
Vehicle:2002 WRX Silver Sedan |
kartboy gets my vote
at first I didn't really like the stiff and notchy feeling of the kartboy w/bushings, and my 1 - 2 felt weird. I had to trim down that surrounding piece of metal (1st was rubbing), I also had the bolt tightened too tight, fixed both of those problems, and I've also got used to the feeling. I was at the dealership again this past weekend, and I tried out the stock shifter and the STi short shifter. BLEH!!! Didn't like em at all. The Sti didn't really seem any shorter than stock. I love my kartboy w/bushings.
Go Kartboy! |
04-29-2002, 08:24 PM | #13 |
Techno Sapien
Moderator Member#: 449
Vehicle:2019 Impreza Sport Lithium Red |
Linkage and bushing is the same. One minor diff on the linkage is the legnth of the fork part is all.
http://www.scoobymods.com/forums/sho...?s=&threadid=6 Some more noise is transmitted with both the KB and the STi shifter. There is a rubber insert in the OEM shifter that is eliminated. Then if you install harder shifter bushings (which I suggest) in either the STi or normal linkage a little more noise will be transmitted. Basically the STi maintains stock shifter height the KB is lower. The Cobb one is adjustable from what I can tell. I haven't seen one up close yet. A local WRX owner is getting one and I plan on installing it and taking pics then. How to install a shift lever: http://www.scoobymods.com/forums/sho...=&threadid=205 Last edited by Peaty; 04-29-2002 at 08:30 PM. |
04-29-2002, 08:46 PM | #14 |
Member#: 14442
Vehicle:2002 WRB WRX |
Go with the Kartboy (spend the extra dough on an STi shifter trim).
As for the metal "ring" that interferes with the lever in first...Instead of grinding it down, simply loosen the bolts and push it forward and to the left, it will clear just fine. |
04-29-2002, 08:59 PM | #15 |
Techno Sapien
I've had some that hit and others that didn't. Production tolerance I guess:
04-30-2002, 01:55 AM | #16 |
Guest
Member#: 14110
Vehicle:2002 2002 WRX Swirly Black |
The best is the syms hands down but I don't know where to get them any more and be prepared to spend 300 bucks or more, the STi is not really any different then stock, the KB is much shorter, I installed the KB and bushings and like the feel of it. As far as rattles go I installed STI tranny and motor mounts so i have a lot of rattles so that part doesn't bother me. If I had the money I would have gotten syms but the STi is a waste of money in my opinion.
04-30-2002, 09:57 AM | #17 |
Member#: 2184
Vehicle:2005 Legacy GT wagon Platinum Silver Metallic |
People like to scoff at the factory stuff and why, I don't know. I have the STi short shift kit (about 30% shorter than stock) with Kartboy bushings, and it feels excellent. Smooth and solid. I also like the stock shifter height. I also admit to not liking at all the way that a Kartboy setup feels, but that's just me.
Tifosi is right about the Syms setup, btw. It's also worth noting that we don't know if the STi setup is stiffer or not. All that fancy gold metal isn't just cosmetic, I don't think, and it feels much more solid and positive (yet not notchy) than stock. Essentially, like all factory stuff, it feels like stock, only better, if that explains it correctly. You think it feels the same, until you shift a stock setup. Then you realize. But recent suspension experiments have taught me that STi knows what it's doing. They aren't selling snake oil. Whether it's your cup of tea is another matter, but the stuff works, no question about it. Kevin |
Kartboy vs Cobb short shifters | tbozek | Transmission (AT/MT) & Driveline | 33 | 02-03-2006 12:41 PM |
Kartboy vs. STi short throw shifter | txl146 | Transmission (AT/MT) & Driveline | 2 | 08-29-2004 07:18 PM |
Factory Short Shifter vs. Factory Shifter Part Differences | bullseye17 | Transmission (AT/MT) & Driveline | 1 | 09-22-2003 07:15 PM |
Kartboy shift w/bushings vs Perrin short shifter | Kucheto | Interior & Exterior Modification | 4 | 04-28-2003 02:17 PM |
Anyone compare Kartboy vs. Cobb short throw shifter | Ken S | Technical Forum Archive | 6 | 09-26-2000 09:13 AM |
