05-31-2000, 11:55 AM | #1 |
Member#: 1442
Vehicle:1999 2.5 RS Aspen White |
Shifter Upgrades
O.K., I'm sort of taking a poll. Who has aftermarket shifters and what do you think of them? Also, how easy are they for an idiot to install in an afternoon? I'm thinking of getting a shorter throw shifter and want all the input I can get.
Thanks, Dan Z.
05-31-2000, 01:07 PM | #2 |
Member#: 80
I have a SYMS shifter - costs a lot more, and I haven't tried the Kartboy shifter, but I can say I am completely satisfied and more with my SYMS unit. I've had Miata owners compare their shifter to it favorably, and I think most people will agree that the Miata has a really sweet shift feel. SCC also put the SYMS shifter in their project car and had good things to say about it.
I'm sure the Kartboy shifter is great too. Just letting you know that there are other choices. -Edwin |
05-31-2000, 01:19 PM | #3 |
Member#: 1407
Vehicle:2000 2.5 RS-T BRP |
I just installed the Kartboy shifter the other night - Man what a differnce, this is the way the car should come. I think the easiest way to install the shifter is to buy a rubber mallet, mine is about 3lbs. That way you don't need the piece of wood (alot easier to do by yourself - I had trouble holding the shifter and the piece of wood and then trying to hit it). Anyway I would recommend it highly.
05-31-2000, 01:32 PM | #4 |
Member#: 592
TXIC
Vehicle:'11 X5 xDrive35i '09 135i 6MT/'15 GTI 6MT |
I upgraded from the stock Outback Sport shifter /w nasty rubber boot to the 2.5 RS shifter with leather knob and boot. Great shifter! All you OBS owners out there, start grabbing the 2.5 shifters everyone's throwing out for Kartboy's...they have a shorter shift and firmer feel compared to the stock shifter.
Scavenging, Geoff |
05-31-2000, 01:32 PM | #5 |
Member#: 592
TXIC
I upgraded from the stock Outback Sport shifter /w nasty rubber boot to the 2.5 RS shifter with leather knob and boot. Great shifter! All you OBS owners out there, start grabbing the 2.5 shifters everyone's throwing out for Kartboy's...they have a shorter shift and firmer feel compared to the stock Outback Sport shifter.
Scavenging, Geoff |
05-31-2000, 01:34 PM | #6 |
Member#: 592
TXIC
And a corporate network hiccup causes me to post twice. C'est la vie. :P
05-31-2000, 02:48 PM | #7 |
Member#: 1367
Vehicle:2000 Impreza 2.5RS Blue Ridge Pearl |
I got an email today from Dale Teague. My Kartboy short shifter is on the way!! Yehaa!!!!! I know that it is as good as everyone is saying it is. Easy installation, inexpensive, Go with Kartboy!!
05-31-2000, 02:51 PM | #8 |
Member#: 1257
Vehicle:2000 GC8 WRX 93 RS-W Wagon (White) RIP |
I have the Kartboy Shifter/Bushings....as for installation??? (Kartboy) did the install in my car himself It took him about 10 minutes from beginning to stop to do the whole job (both SHifter and Bushings)
True I could have done it myself....but WHY...when the job was done PERFECT from the man himself.....Thanks TOM. Cheers Eddy L. |
05-31-2000, 03:46 PM | #9 |
Member#: 200
Vehicle:1999 Impreza 2.5RS Black |
Thanks for the support. You can view our shifter, bushings, as well as other products at our somewhat plain website. (We devote more time to the product.)
We will soon have the trick solid endlinks for the rear anti-roll bar. If you have an 18 or 20mm bar, these are the ticket. With the stock 13mm bar, I doubt they will help much. Thanks again. [email protected] www.kartboy.com |
05-31-2000, 05:21 PM | #10 |
Member#: 10
NESIC
Vehicle:2005 Legacy Gt wagon Garnet red pearl |
I have two shifter kits in my98 rs right now first i got the prodrive/sti kit and i loved it then i got a crazy idea so i took out the graham goode shifter lever that comes in the kit and put in a kartboy one and wow is it even better now i say buy both kits and mix and match to get your own perfect shifter kit.
05-31-2000, 06:33 PM | #11 |
Member#: 1254
Vehicle:1999 Impreza 2.5RS Black Pearl |
I'm curious what difference do the bushings make? Personally I'm not a huge fan of "notchiness" but I would like shorter throws. Are the hardened bushings a "must" (i.e. is there more play in the aftermarket shifter vs the stock shifter without the bushings) or can you get away with just the shifter?
05-31-2000, 07:56 PM | #12 |
Member#: 145
I'm a very very lazy boy(especially owning three previous cars with short shifters on it).
It definitely brings the fun back into driving(especially in rush hour traffic or around the city) Not sure with the Sube, but I shaved off 2/10 consistently off my 1/4 mile time with my last car and didn't ruin any synchros in the process. A guy that had the exact same car/mods as me lost at every race by 3/4 car length and broke a couple of his synchros by the end of the day. |
06-01-2000, 12:33 AM | #13 |
Member#: 64
Vehicle:1999 Impreza 2.5RS Rally Blue Pearl |
I've got the Karboy Kustoms shifter, and I like it alot. As for installation, it couldn't have been easier. I've done oil changes that were much harder. The only problem I ran into was that I live in an apartment and didn't have a block of wood lying around. When you put the new shifter in, it takes some brute force with a hammer and you don't want to ruin the threads (hence block of wood between shift lever and hammer). Once I had said block of wood, it took me about 15 minutes (Kartboy can probably do it in about 30 seconds ).
06-01-2000, 12:34 AM | #14 |
Member#: 283
I've got the Kartboy shifter and it ROCKS!! It was quite stiff when I first got it in but after a while, it has loosened up so it feels great now. It is a PITA to install if you're by yourself, make sure you have a friend to help you.. Also, if its cold outside, use a hairdryer to heat up the plastic when you pound it back in, it helps ALOT!!
06-01-2000, 12:43 AM | #15 |
Member#: 507
Vehicle:2005 Saab 9-2x Aero black |
hey,
I have the kartboy shifter also...getting it installed for me wasn't as easy as some other people had it...had a terrible time trying to get the shifter into the ball socket, but then did a search on the board while I was trying to install it and got some helpful hints..then it was in eventually. It's sweet....shorter throws, didn't cost an arm and a leg..and it feels nice and tight for a while...then loosens up a bit nicely. |
06-01-2000, 12:47 AM | #16 |
Worst Mod Ever
Moderator Member#: 369
SWIC
Vehicle:19 CTS-V, 18 XC90 17 GTI |
I also have the kartboy shifter and Cusco linkage bushings. I like them both a lot. I had the bushings before the shifter so I can't comment on how that is alone, but they make a good combination. It is really stiff and notchy for a while, but it broke in after awhile and I like I more now.
06-01-2000, 12:53 AM | #17 |
Member#: 19
i do NOT have a kartboy shifter, but essentially the same thing... Graham Goode Shifter. I also have the CUSCO bushings. Great mods!
michael |
06-01-2000, 12:55 AM | #18 |
Member#: 1342
Vehicle:99 OBS & SUXASS May your line be smooth |
I just installed my kartboy last night! Fantastic shifter, I cant say enough good things about it. It is still stiff but so much faster through gears than the stock one. I have the hardened bushings too. The bushing are a little tough to get in. They dont like to compress into the linkage (if I can call it that) under the car. We had to use the nut to tighten the bushing into the linkage before sticking the washer back on that separates the bushing and nut. That was the only solution we had to try that wasnt on the online instructions. All in all it was a snap and it was very inexpensive! Kartboy even sent us a box of hot tomales with their logo taped on it! hehe
Shifter upgrades simplified | Unabomber | Transmission (AT/MT) & Driveline | 107 | 10-12-2021 09:46 AM |
Drive Performance Mag and the STI shifter Upgrade? | cgerald1 | Transmission (AT/MT) & Driveline | 21 | 05-14-2009 03:50 PM |
STI Short Shifter upgrade for WRX | LEMON03 | Transmission (AT/MT) & Driveline | 5 | 05-08-2005 04:36 PM |
kartboy vs. factory short shifter upgrade | sdseagles | Newbies & FAQs | 16 | 04-30-2002 09:57 AM |
FS: nice cheap shifter upgrade for Legacy 5 speeds | dvancleve | Legacy Forum | 3 | 06-27-2001 05:04 AM |
