05-30-2006, 05:20 PM | #1 |
Member#: 56624
BAIC
Vehicle:2004 Subaru WRX STi Blue |
Problems with Wiring?
2 weeks ago, my car was broken into and they took away my navigation and cut my negative battery wire.
Now that the negative battery cable is fixed, I can start the engine and drive normally. However, some issues still remains such as: 1. Dome light cannot be turned on 2. Stock center clock is not working 3. Front light not working 4. Remote to lock and unlock car not working 5. Stock alarm not working 6. A/C button can't seems to remember my previous settings. For example, i turn the A/C on but when I switch off the car, the A/C button is not on by default. 7. The odometer is always set to Trip A even though I put to Trip B before I switch off the engine. What do you guys think is the main reason behind it? I was thinking, if its just the wiring, why is the Odometer and the A/C not behaving normally? - Charles
05-30-2006, 05:33 PM | #2 |
Member#: 62975
AKIC
Vehicle:2004 WRX Silver |
blown ctsy fuse? ssounds ike a blown courtesy fuse... check the cigarette lighter... if no worky, then thats it. just sounds like a fuse to me dude.
05-31-2006, 09:14 AM | #3 | |
Member#: 32636
Vehicle:2004 Impreza STi Silver/Silver |
offset |
05-31-2006, 12:37 PM | #4 |
Member#: 56624
BAIC
I go and check it out later
- Charles |
05-31-2006, 12:43 PM | #5 |
Member#: 82147
SCIC
Vehicle:2005 WRX Sedan Aspen White |
I will also have to agree about the courtesy fuse.
~REVNU |
05-31-2006, 12:47 PM | #6 |
Member#: 56624
BAIC
For the Subaru, there is only one location where all the fuse are located right which is under the steering wheel behind the small compartment.
- Charles |
05-31-2006, 01:11 PM | #7 | |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
06-01-2006, 10:14 AM | #8 |
Member#: 56624
BAIC
Thanks guys. I fixed the problem yesterday and everything seems ok now.
- Charles |
problem with wiring subwoofer w/o aftermarket headunit | 07otleSTi | Mid Atlantic Impreza Club -- MAIC | 17 | 04-28-2009 10:44 AM |
Problem with the spark plug wires | colorfull | Normally Aspirated Powertrain | 7 | 05-02-2008 02:22 PM |
Problem with EGT wires... | Jpizzzle | Electrical & Lighting | 2 | 05-16-2006 01:27 AM |
Problem with changing plug wires | DreddRS25 | Service & Maintenance | 6 | 03-15-2005 11:29 AM |
Potential problems with wiring TT? | Jerry Seagreaves | Electrical & Lighting | 2 | 12-12-2002 12:08 PM |
