10-17-2006, 09:53 AM | #1 |
Member#: 104386
Electrical/Radio issues...what to ask for...
Hey all,
I've got a 2003 WRX wagon (I'm the second owner) and have had the car for about a year. It has 40K miles. The issues that I am having (and the previous owner had) are with the radio. It shuts itself off randomly or won't shut off at all. In the latter case, I have to disconnect the battery to shut the radio off. I have had the car into the dealer about 10 times now and the previous owner several times too. SOA regional tech guru looked at it twice. All work was and is still under warranty. The dealers have replaced the radio with a new one 2 times (that makes 3 radios have been in the car), replaced the engine compartment and passenger compartment wiring harnesses, new ground(s), new antenna, new alternator, new power lead, etc. I am at the point now (I am expecting) that SOA will say they can't fix/resolve the problem. They have asked me what I think should be done. I have no idea. Since it may be more than the radio causing this problem I would like to have it solved. I get an aftermarket radio installed aftermarket and paid for by SOA, they may claim that their responsibility is over. If the problem is still there, I'm SOL. Is my resale value already screwed? I wasn't planning on keeping this car until its final days. I can't keep taking it in every time this happens (it happened 5 times this past week, and I only drove the car 5 days out of that week) and I had to disconnect the battery twice to reset the radio. Is it out of the question to think of having my car swapped for a similar mileage or equal blue book value car? They have suggested incentives on a new vehicle, but I don't want a new car payment. I don't know what to expect for appropriate or meaningful resolution that is fair to me. Anyone have any advice? I am truly appreciative of any input.
10-17-2006, 10:32 AM | #2 |
Member#: 110567
Vehicle:2009 JK Sunburst Orange |
I know this sounds stupid but it happened on a nissan of mine. Have them check the ignition switch (where you put your key), I replaced mine on the nissan and it fixed it.
10-17-2006, 10:36 AM | #3 | |
Member#: 99289
I think it's pretty clear it's not the radio causing the problems, I'd have them start looking at relays as well, one is probably stuck. |
10-17-2006, 03:38 PM | #4 |
Member#: 60976
SWIC
Vehicle:1969 LGT FATURBO |
40k and its under warranty still? ohhh your talkin about the 1 year/unlimited mile warranty
10-17-2006, 03:58 PM | #5 |
Member#: 110459
Vehicle:2017 Impreza Premium Island Blue Pearl |
10-17-2006, 04:36 PM | #6 |
Member#: 60976
SWIC
Ahhh thats a new one... gonna have to remember that one...
10-17-2006, 05:26 PM | #7 | |
Member#: 2992
Vehicle:02 WRX Sedan Silver |
10-17-2006, 05:33 PM | #8 | |
Member#: 60976
SWIC
10-18-2006, 09:59 AM | #9 |
Member#: 104386
Thanks for the responses so far...
The car is at the stealership right now. The SOA case worker told me that the regional tech guy and the panasonic rep are working together to find out what is going on. IMHO, they will come up with zip again as there were so many other attempts to locate the problem. But it would be nice if they find something. I will keep an update here. BTW the idea for swapping cars (I thought) would be so that they can take it to their highest level guys (if they want to) to fix it, and resell it at auction or whatever. At least the would have every opportunity to learn what the problem is without having to piss off a customer in doing so. I should know today if there was anything found. |
10-18-2006, 10:28 AM | #10 |
Member#: 104386
OK....Just updated from SOA representative. The tech played with the car and the SOA rep said there was no mention of them finding anything that was outstandingly wrong. So I am imagining that they ripped the dash apart went fishing for a problem and found nothing, but did some testing and they hope that by pulling stuff out and putting stuff back the problem will be solved. I am not encouraged.
They are also going to keep my car for 2 more days to see if they can get the radio to cut out again. They DID offer me a rental car, so that was good faith. Panasonic rep said two out of the 4 radios that have been in the car were defects. The last 2 were fine though. So I am planning on picking the car up tomorrow and the problem will probably re-surface shortly thereafter and we can do this drill alll over again The SOA rep apologized for the hassles and acknowledged my frustration. I told her that the next time it's raining, to think about standing in a parking lot under the hood with a wrench undoing the battery cable to turn your radio off, then she will understand my frustration. This SOA rep is the second one on this case for me. The first one did nothing for me. Didn't return calls, didn't return emails, etc. This new rep has called me repeatedly and I really feel that she is trying to resolve the case. So hats off to Kerry at SOA, a rep that represents. |
10-18-2006, 11:59 AM | #11 |
Member#: 99289
Good luck, I'm still 100% absolutely convinced it's not the radio itself but the ignition or a relay. when it happens again and you need to turn of the radio, try pulling the fuse for it or the accessories instead of undoing the battery.
10-18-2006, 12:44 PM | #12 |
Member#: 104386
IIRC, at one point I did pull the fuse. In fact, I pulled (I think) all of the fuses (in the car fuses) one at a time to see if I could get the radio faceplate light to turn off with no luck.
Last resort...So are you saying that if the ignition switch was not OK it could be providing the constant power to the radio? Just spoke to the mechanic working on my car. Nice guy, really seems to want to fix the problem and he's the most senior subaru mechanic they have. I told him about the ignition switch and he said they wouldn't rule that out. The mechanic is going to open up the steering column and look at the ignition switch today. And get this....panasonic told the mechanic that it is not possible for the faceplate to stay on with the car turned off/key out. The mechanic believes me so the next time this happens, I am going to stop by the dealership and we are going to take a picture and send it to panasonic They did just put a new battery in my car at no charge!!! The saga continues...... |
10-18-2006, 01:03 PM | #13 |
Member#: 99289
Because 2 of the 4 radios were OK and still had the problem, I think we can conclude that issue is in the car. What I'm thinking is (and I could be wrong) is that the possibly the ignition is not correctly turning off the accessories when the key is removed, but after thinking about it, I would think that would leave other accessories on as well. I just don't know enough about how the ignition is wired to know if the ignition has a contact that is used exclusively for the radio. Are there any other symptoms? The other option is the a relay that is controlled by the ignition is getting stuck. I would have your dealer/mechanic look at the relays that are connected between the HU and the ignition.
10-20-2006, 12:47 PM | #14 |
Member#: 104386
OK, I picked up the rex last night. From what the service desk guy told me, they pretty much did nothing but poke and prod around at wires. Oh yeah, and replace my battery for free. They said they will give me all the paperwork next week.....They did interface with Panasonic and Subaru or Panasonic wants yet another radio placed in the car. That will happen next week. I seriously doubt it's the radio. I will let them play the radio replacement exercise and then I will see when the next time the problem occurrs.
This really is getting ridiculous. Or is it just me? I think my dashboard has been torn open so many times that I am getting concerned about it getting loose and rattling sooner than it should. Is this a legitimate concern? Thanks for all the responses so far. |
10-20-2006, 01:12 PM | #15 |
Member#: 110567
I am sure they will put new clips in to hold the dash if it starts to get loose.
10-20-2006, 01:34 PM | #16 |
Member#: 110459
10-20-2006, 03:51 PM | #17 |
Member#: 99289
Talk to SOA, and see if you can take it too a specialist and have them bill SOA. They will more than likely say "No", but this is getting old I'd bet
10-31-2006, 01:25 PM | #18 |
Member#: 104386
Well, another new radio was placed in my rex last week. I drove the weekend without issue and today....poof, radio shuts off again. ALTHOUGH, this time, I turned it back on to find that the pre-sets were still there. So all power was not lost. Still another permutation of the same problem. AAAAARRRRRRGH. More calls, more emails......waiting......
10-31-2006, 03:19 PM | #19 |
Member#: 99289
Not the stereo.....
10-31-2006, 09:40 PM | #20 |
Member#: 105089
South East
Vehicle:05 STi/ Toyota Land Cruiser |
god, this must suck. I hope it gets resolved soon!
11-02-2006, 10:21 AM | #21 |
Member#: 60976
SWIC
or save yourself the headache and get yourself an aftermarket radio.
11-02-2006, 12:24 PM | #22 |
Member#: 99289
Similar Threads | ||||
Buying from used car center. What to ask for? | gianspi | Newbies & FAQs | 3 | 07-30-2006 05:52 PM |
What to ask for my Bride's | pastorman | Interior & Exterior Modification | 4 | 04-14-2006 02:17 AM |
what to ask for as a wedding gift... | m750 | Off-Topic | 38 | 09-14-2005 09:27 PM |
What to ask for? | OCD | General Community | 16 | 12-05-2003 11:28 PM |
Need engine, what to ask for? | Kruf | Legacy Forum | 10 | 09-10-2001 12:46 PM |
