Welcome to the North American Subaru Impreza Owners Club Tuesday October 21, 2014
Old 05-23-2004, 12:07 AM   #1
italy wrx
Member#: 36450
2003 WRX
Default up-pipe/downpipe torque loss
I installed a catless Perrin up-pipe/downpipe today and I have to say I am a little dissapointed in the results. It seems that I have lost torque up to 4500 rpm. Although I do notice a gain in pull from 4500 to 7000. It just seems to have lost the quick pull through the rpm range that it used to have with only the Greddy Evo cat-back. I did reset the computer, but it doesn't seem as fast. I was planning a computer reflash, but my friend (Subaru tech) says I should get quicker spool-up and noticable power gain from these mods. There are no MIL lights,and no exhaust leaks. Sounds great, but lack of torque makes me drive harder. Anyone have similar results?
italy wrx is offline   Reply With Quote
Old 05-23-2004, 12:36 AM   #2
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
um.. I've never ever heard of that result.. losing the 3 cats should make a large torque & hp gain throughout the RPM band.. I think your butt dyno probably lies or is miscalibrated...
Unless you have a large exhaust leak somewhere (specifically the uppipe) these would cause big time power losses.
MustGoFast is offline   Reply With Quote
Old 05-23-2004, 01:05 AM   #3
italy wrx
Member#: 36450
2003 WRX
Im going to check the up-pipe tomorrow, but wouldn't I get a check engine light for an exhaust leak?
Old 05-23-2004, 04:28 AM   #4
SubieStyle
Member#: 48936
I Do Installs On The
Side;) PM me for details!
No, not necessarly.
SubieStyle is offline   Reply With Quote
Old 05-23-2004, 04:00 PM   #5
italy wrx
Member#: 36450
2003 WRX
No leak found at up-pipe to turbo, not sure about up-pipe to crossover(cant rev engine while under car, although I did stick screwdriver in bellcrank for t-body to hold constant rpm). I do smell exhaust fumes, and my up-pipe lost it's satin color(looks orange).
Old 05-23-2004, 04:33 PM   #6
Cronos
Member#: 51409
2013 Shelby GT500
Ignot Silver Metallic
Up-pipe leaks are pretty easy to identify, they make a very loud high pitched scream. You would know if you had one.
It's not uncommon for a loss in low end with a full 3"+ turbo back. Believe it or not, the stock turbo still likes a little back pressure to produce low end torque. EMS should help.
Cronos is offline   Reply With Quote
Old 05-23-2004, 05:59 PM   #7
italy wrx
Member#: 36450
2003 WRX
I hear a "whistle" type noise, but it sounds like the turbo spooling up. I do have 3 inch all the way back(perrin catless d/p and greddy evo).
Old 05-23-2004, 06:09 PM   #8
mr. m
Member#: 44229
2000 2.5 RS
blue ridge pearl
backpressure does not produce torque.
mr. m is offline   Reply With Quote
Old 05-23-2004, 06:36 PM   #9
Gfunk720
Member#: 42549
E92 BMW M3
2011 VW TDI Wagon
It may be a downpipe leak, atleast thats what I associate the whistle with. Did you use new gaskets when you did the swap?
My buddy has a dp leak and it seems that his car doesnt pull quite as hard as mine.....makes that whistleing noise too. The loss of the up-pipe cat should definetely decrease spool time.
my $0.02
Gfunk720 is offline   Reply With Quote
Old 05-23-2004, 06:50 PM   #10
AlboWRX
Member#: 37719
2003 WRX
You did said that you reset the ECU right.You gotta give it sometime for the ECU to learn,just like with everything else that has a computer in it..This has been covered so many time in this forum.Its not a leak.Give it about 3 days.
AlboWRX is offline   Reply With Quote
Old 05-23-2004, 07:05 PM   #11
italy wrx
Member#: 36450
2003 WRX
I used all new gaskets(oem) and I did reset the ECU. I did a thorough and careful install and like I said could not find any leaks. Hopefully the computer will "learn". I'll keep driving it for a few days to see if it clears up, if not I'll start looking for leak.
Old 05-24-2004, 08:06 PM   #12
italy wrx
Member#: 36450
2003 WRX
I think i've found the problem. On the Perrin downpipe, there is a seperate pipe to vent the wastegate. The piece of steel that divides the two pipes is holding the valve for that vent closed. I tried to move the rod from the diaphragm to the valve and it won't move. This, I believe is what is causeing my power loss issue. I will remove the downpipe and adjust the seperater and hopefully my problem will be eliminated.
Old 05-24-2004, 11:46 PM   #13
jlabelle4
Member#: 61015
2005 STI
SILVER
Smile
This problem sounds very familiar,this guy I work with had the same issues with the Perrin setup
jlabelle4 is offline   Reply With Quote
Old 05-24-2004, 11:58 PM   #14
wRxbeater11
Member#: 12682
Could be since you went to a larger exhaust setup maybe it takes a second to spool up like it did on the old 2.25 pipes with back pressure? I know when I installed a 3" o2 housing and downpipe on my SRT it made a lil more lag but not much. Worth the gain up top though.
-melo
wRxbeater11 is offline   Reply With Quote
Old 05-25-2004, 03:03 AM   #15
firedust
Member#: 38795
2003 WRX
Sonic Yellow
no. The only time you may see slower spool is if your uppipe has a different inner diameter (larger) than stock.
firedust is offline   Reply With Quote
Old 05-25-2004, 07:51 AM   #16
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
Sounds to me like a big plus for gutting the stock or going STI UP.
HerculesPeanut is offline   Reply With Quote
Old 05-25-2004, 10:54 AM   #17
SlideWRX
Member#: 3803
07 Mustang GT
285 is a wide tire!
I wonder if the 'loss' is because the wastegate spring is sprung a little too lightly - variation from the factory. For the stock setup it is fine, but when freeing up exhaust flow I think the wastegate spring occasionally needs to be tightened a couple turns to account for it.
With the light spring pressure, the wastegate flutters open earlier than normal and you get the low torque feeling down low.
Tom
SlideWRX is offline   Reply With Quote
Old 05-26-2004, 03:38 AM   #18
italy wrx
Member#: 36450
2003 WRX
Problem solved! The perfrormance is awesome. The difference is night and day. I have quicker spool up and more torque. I'm so happy I figured this out, I was worried I made a huge mistake but I can honestly say, this was money well spent. Anyone installing this set-up should check the clearance of the wastegate vent before putting everything together and enjoy the results. Now all I need is an ECUTEK reflash and I'll be stoked!
Old 06-04-2004, 07:55 PM   #19
Cronos
Member#: 51409
2013 Shelby GT500
Oh young Jedi, much you have to learn.
Old 06-05-2004, 07:41 AM   #20
Vector92
Member#: 40661
2002 Imprezza WRX
WRX Blue
Instead of just disagreeing, could you give us some explanation why you think backpressure produces torque?
I'm open to the possibility it may have some effect in the exhaust header, in NA engines... perhaps you can clarify.
However, I'm pretty sure that increased backpressure after the turbo will do nothing but reduce torque in all cases.
Why? Because it will definitely decrease the pressure ratio across the turbine, and therefore spin the compressor more slowly, putting less air into the engine. Less air=less gas burning, and less torque.
Vector92 is offline   Reply With Quote
Old 06-05-2004, 10:39 AM   #21
stang-spanker
Member#: 44276
2004 WRX Wagon
Java Black--COBB Stage II
Most good reflashes tune as a NA engine pre-spool (low rpms). That's why there is talk that a catless uppipe (less backpressure) reduces low end torque.
stang-spanker is offline   Reply With Quote
Old 06-05-2004, 02:32 PM   #22
danswrx
Member#: 50710
I have only heard that a catless uppipe reduces lag. I have seen dyno plots where at no time do you make less power with the uppipe. That said, I have a ScoobySport catless TBE and SS UP, and it's great. Compared to stock, it felt like a stroker kit or something. I think my 2.5" exhaust is ideal for a 13G turbo. 3" exhaust on the stock turbo is overkill.
danswrx is offline   Reply With Quote
Up pipe leaks and loss of boost xrocket21 Built Motor Discussion 5 11-20-2009 02:09 PM
Up Pipes, Downpipes, Mid Pipes and Mufflers niemand_1 Engine/Power/Exhaust 16 03-23-2009 02:33 PM
stock motor up pipe downpipe no cats 3" piping fmic sti injectors with vf39 w/70k mil onefastwrx04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-30-2006 08:27 AM
Up pipe and catback= loss of power Subie123Poot Engine Management & Tuning 3 08-01-2004 11:02 AM
CA: Stock pieces: up-pipe, downpipe, mid-pipe, sedan springs subaru kym Private 'For Sale' Classifieds 3 04-10-2004 03:46 PM
