02-11-2015, 02:15 PM | #1 |
Member#: 263220
NWIC
Vehicle:2005 Wrx / Sti conv. 2014 XV Crosstrek |
2.1 stroker. Wrx eagle rods?
Hey guys
So I have searched around on Google and nasioc and couldn't get a straight answer. My ej205 spun a bearing and killed the crank and rod in the process. The block is still good along with everything else. So after deciding to build it. Picked up eagle H beam rods and new 205 crank from a friend for a steal of a deal. But after doing research I remembered you can stroke the motor out using Sti parts and custom pistons. So now that I am changing my plans. Power goal is 325-350. Nothing crazy with a jdm 6 speed Sti trans behind it. Non dccd version Does anybody know if there is a piston out there that will allow me to use the Wrx block, Sti crank, use my 205 eagle rods? Or should I sell the eagle rods and crank and just get the Sti stuff? Thanks guys.
02-11-2015, 02:20 PM | #2 |
Member#: 199632
You need a set of 79mm stroker pistons for an ej205 (JE #314446 is one example) to use the Eagle Rods. WRX and STI rods are the same length (130.5mm)
http://www.jepistons.com/Catalogs/Sp...aru/ej205.aspx http://www.manleyperformance.com/sc/..._pistons.shtml |
02-11-2015, 03:11 PM | #3 |
Member#: 263220
NWIC
I appreciate the quick response. I dunno why when everybody does the builds they use STI rods, I can only assume its cause they are stronger then wrx rods? But I appreciate the info. I was really leaning towards the Manley pistons since I have heard nothing against them and most builds use that piston.
02-11-2015, 03:31 PM | #4 | |
Member#: 199632
This isn't my image but the wrx rod is left and sti on the right. |
02-11-2015, 05:30 PM | #5 |
Member#: 261696
E. Canada
Vehicle:2004 wrx red |
I had a set of manley rods new, tom at tech works said they had to be resized to get the correct bearing crush
02-11-2015, 05:43 PM | #6 |
Member#: 263220
NWIC
Based on what mopar said I am curious if the eagle rods need to be resized...
btw thanks for the visual reference concept11253. helps explain alot knowing the end cap design is different. |
02-11-2015, 08:25 PM | #7 |
Member#: 261696
E. Canada
he said its common for a lot aftermarket rods, I don't think most shops are as picky as him either,
02-12-2015, 03:45 AM | #8 |
Member#: 263220
NWIC
Mopar by chance would he know off hand if the Eagle rods would need resizing or is that something he needs to see in person?
02-12-2015, 08:01 AM | #9 | |
Member#: 5810
Vehicle:2001 S366 2.5RS |
? Never had to mess with crush on new Manleys...... Clearance yes. Perhaps you mean clearance? Manleys are tight out of the box Sent from my iPad using NASIOC |
02-12-2015, 10:47 AM | #10 |
Member#: 261696
E. Canada
""On another note, I assume we are supplying a crank for you?
Preliminary measurements show that your rod big end will need to be resized as the are significantly small for correct bearing crush. This is common on a lot of aftermarket rods. Also, you will need +.026 mm bearings on number 2, 3, 4 main bearings or your clearances will be way too loose. Loose clearance on #3 is a sure way to lose a rod bearing on #2 or 3 con rod"" |
02-22-2015, 11:09 PM | #11 |
Member#: 374960
How much power can the 2.1L stroker make. I'm new to the subbie thing. Just built mine.
03-06-2015, 07:22 PM | #12 |
Member#: 412765
Sorry for the newb question but Is it possible to check whether an installed engine is a standard 2.0 or 2.1 stroker without major disassembly?
