11-14-2002, 12:34 PM | #1 |
Member#: 13004
Vehicle:2002 Pump Gas Homo |
Vishnu Stg 2 TXS stg 4 comparo
Ok after paper racing both systems the TXS seems to have a significant amount more torque. HP seems the same but I feel TXS has the step on it and go advantage. What say you?
11-14-2002, 01:04 PM | #2 |
Member#: 15194
Vehicle:2004 Lightning, 2001 BMW 330ci |
Talk to Dug-e-fresh.
He has had experience with both setups. |
11-14-2002, 01:23 PM | #3 | |
Member#: 4980
-Nathan |
11-14-2002, 02:24 PM | #4 |
Member#: 4568
Vehicle:10.7 @ 136, '02 WRX 12.8 @ 112, '09 spec.B |
My set-up, stuff that matters for Hp:
VF30 turbo STi Injectors Walbro 255 Pump Vishnu Uppipe Vishnu Sig Exhaust, catless Vishnu Crank Pulley NGK 7 Plugs Blitz SBC iD Boost Controller SO FAR, my best run with Vishnu Stage 2 Unichip has been [email protected] w/1.831 sixty foot on 17 psi of boost My best with everything the same except using Turbo XS Stage IV Unichip and more boost was [email protected] w/1.790 sixty foot on ~19 psi of boost. I am gonna be able to run more boost with the Vishnu Stage 2 set-up, and will have more times tomorrow.... if all goes well. def |
11-15-2002, 09:46 AM | #5 |
Member#: 13025
RMIC
Vehicle:1998 RS-T Rally Blue |
Jealousy!
I have the exact same setup as Dug minus exhaust and stage 2 map. I have run 13.50 E.T. 1.87 60' at a 5000' altitude. Stock exhaust.
I am trying to get the Signature Exhaust to complete my system as well. Dug, Have you run the TXS exhaust? Sorry I don't have any info to offer. I am simply jealous of Dug for actually laying his hands on a Signature Exhaust. The Non-Signature Stage 2s are in stock FWIW. It would seem the TXS maps are more aggressive since the Vishnu exhaust system was the same. What is the Best TXS stage4 ET out there? |
11-15-2002, 11:38 AM | #6 | |
Member#: 4980
Re: Jealousy!
Vishnu's stg2 air fuel/boost chart The way we tune is different, but "more aggressive" might not be the right way to phrase it. I'll let others comment on the success they have had at the track with stg4... My favorite stories come from our road racers though. -Nathan |
11-16-2002, 03:21 PM | #7 |
Member#: 4568
Last night a Turbo XS Stage IV car and I went to the local track...
Him: Turbo XS Stage IV Utec TXS TMIC Aggressive Race Gas Map 1.3 bar of boost (18.8 psi) 100+ Octane Full Interior 12.8 @ 107 on a high 1.8 sixty foot Me: Vishnu Stage 2 Sig Series Exhaust Normal Map Max 18.5 psi boost 93-94ish Octane (had to add some 93 before I made it to the track) Full interior minus spare and floor mats () 12.738 @ 105.88 on a 1.828 sixty foot. This is my whole run: 60- 1.828 330- 5.246 1/8- 8.128 mph- 85.87 1000- 10.608 1/4- 12.738 mph- 105.88 I think near the top of the track I was having some timing being pulled. Had I been running a slightly higher octance, perhaps 98 or 100, I think I would have trapped near 107 or so... looking @ my 1/8 mile trap normally I pull about 21-22 mph from there to the quarter trap... def |
11-16-2002, 03:56 PM | #8 | |
Vendor
Member#: 14494
Vehicle:WRX Porsche 996 blue & black |
Re: Re: Jealousy!
It's not feasible to compare wideband readings taken from different widebands. I (and many others worldwide) have reported the Autronic wideband unit (the one we use) to read quite a bit differently from other widebands units. The difference mainly lies in its temperature compensating logic. The resultant differences usually manifest themselves most at higher engine speeds when EGTs are at the highest. Doug-e-fresh, Congrats. I'm not entirely surprised the computer pulled back timing towards the top en of your run. We've recorded some pretty high intake temps from high-hp WRXs with stock intercoolers under prolonged boost. Same thing happens when we do repeated run-after-run dyno pulls without cool-down. Knock correction goes negative (well, actually less positive). It's just on of the ways the factory computer keeps your engine in one piece. More of an issue with pump gas than with race gas, of course. Just my 2c, shiv Last edited by Vishnu Performance; 11-16-2002 at 07:10 PM. |
11-16-2002, 05:22 PM | #9 | |
Member#: 9392
Vehicle:2005 Cobb AP2 STi Gray/Gold |
-- Rich |
11-16-2002, 07:24 PM | #10 | |
Member#: 4980
Re: Re: Re: Jealousy!
Doug, Good job! As you know I’ve been cheering for you. -Nathan |
11-16-2002, 07:27 PM | #11 | |
Vendor
Member#: 14494
Re: Re: Re: Re: Jealousy!
Shiv |
11-16-2002, 07:32 PM | #12 | |
Member#: 4980
Re: Re: Re: Re: Re: Jealousy!
-Nathan www.turboxs.com |
11-16-2002, 07:37 PM | #13 |
Member#: 7468
Vehicle:2008 Outback very limited |
The correct one Thanks Michael
11-16-2002, 07:41 PM | #14 |
Member#: 4568
Thanks guys! I appreciate the responses... TTYL
def |
11-16-2002, 07:45 PM | #15 | |
Vendor
Member#: 14494
Re: Re: Re: Re: Re: Re: Jealousy!
Cheers, shiv Last edited by Vishnu Performance; 11-16-2002 at 09:19 PM. |
11-16-2002, 09:07 PM | #16 |
Member#: 5627
South East
Vehicle:06 WRX STi Black |
My lord I'm long winded!
Back to the topic... I can't say for the TXS stage 4 kit as for most of us it's not financially feesable to test both out (and the two companies have different tuning methods/philosophies.) It's not news that I'm pro Vishnu, just as there are many people also happy w/ TXS components... It's simply a personal choice which company you choose to go with. Realistically, the TXS4 & VS2 will likely show similar results at the drag strip and on the street. I'd be curious to see a real world road test conducted of the two, but such tests are invariably difficult at best. Maybe someone should work on a nice article for SCC.
Fact is the Vishnu products are undeniably more expensive, but most of this is due to their no-compromises approach which will cost more. I guess the best way to describe the Vishnu products (I'll agree the battery tie down is a little out there) is more akin to something you'd expect from a highly skilled custom fabrication shop rather than a shop targetted at high-volume high-profit sales. The detail of quality is impeccable of all their products. In fact I would say that their signature series downpipe fits BETTER than the stock unit, and this with a 3" cat, and divorced dump tube. The welds are among the best I've ever seen. The clamps seal perfectly and fully the first time out (and require less effort to seal up than most smaller exhaust components including the stock unit.) Angles are a perfectly aligned for the entire legnth of the exhaust. Pulley's are perfectly balanced. Uppipes fit perfect w/ a very logical location for wideband O2 placement. In the end it is really hard to find flaw in the execution of their products, and this isn't even hitting on the tuning side of things (which is even more important.) The best way to describe the Vishnu tuning philosophy is one of max power, but not to the point of compromising the safety/reliability of the motor. This is their philosophy and one that is at the very heart of their company. Vishnu in the Hindu religion is known as the "Great Preserver," or one who "sustains" and finds/achieves "balance"; while Brahma is the "creator" (which it could be said that Vishnu (the company) also does.) Vishnu initially strictly did tuning, but has since branched into the creating new products realm. In the end though the sence of balance that is Vishnu (both meanings) shows up in everything that comes from them. In the US though their company can best be surmised by the saying, "Anything worth doing is worth doing right." Yes, they've had their share of problems in the past w/ customer service as they grew because of their current load, but this has changed quite a bit as of late. It is now rare that you cannot contact them for a question, comment, complaint, or order. If you have a problem or complaint Brett, Shiv, or Ken will do what they can to work with you and make things right. (At least this has always been my experience.) The only front they seem to still have some trouble on is the email, but I've seen that improve quite a bit as well. Vishnu is growing just as our entire Subaru community has grown dramatically over the last year. One thing for certain though is that the Subaru community is certain to get even bigger over the next couple of years, and that all of the competitors will have to grow, expand, and change over time to cope with things. One thing I know though is that Shiv and Vishnu and hardly ever content to just sit on their laurels. --Matt Last edited by Obsidian; 11-16-2002 at 09:17 PM. |
11-16-2002, 10:03 PM | #17 |
Member#: 4568
A friend of mine and I frequently get into pulls on the street... he runs Turbo XS Stage IV... with the topmount and the Utec... I of course run the Vishnu Stage 2...
Normally its who ever kicks it first who wins... but the other day we got on it the SAME time and we were literally DEAD EVEN! def |
11-16-2002, 11:27 PM | #18 | |
Member#: 4980
Re: Re: Re: Re: Re: Re: Re: Jealousy!
Shiv, My post of the two plots was for simple comparison to show that boost, and air-fuel ratios are in the same ball park not to say one is better than the other or to say that all Vishnu kits run at 11.2:1 where as all txs kits are at 10.5:1. There seems to be an erroneous notion going around that TXS is more aggressive and that Vishnu is more concerned with reliability. In the end it's marketing or "I-club" fluff. Both kits are comparable, and from looking at Doug’s track results, I’d say that the power levels he is NOW running are very much in line with what most stage4 cars will make assuming a proper install. I'd even go so far as to say that it's likely a very reliable setup for him assuming he can manage to keep the boost under control, but that is a whole different issue. You'll not get an argument from Turboxs that full exhaust system; VF30, STI injectors, Up-pipe and a unichip make a nice kit. If nothing else, we at least agree on that. Anyway back to your regularly scheduled I-club post... -Nathan |
11-16-2002, 11:39 PM | #19 | |
Vendor
Member#: 14494
Re: Re: Re: Re: Re: Re: Re: Re: Jealousy!
Shiv |
11-16-2002, 11:47 PM | #20 | |
Member#: 4980
Re: Re: Re: Re: Re: Re: Re: Re: Re: Jealousy!
-Nathan |
11-16-2002, 11:48 PM | #21 |
Member#: 25433
Vehicle:2003 WRX SW all we'll drive |
psst... don't forget about the fuel pump...
11-17-2002, 12:11 AM | #22 |
Member#: 5627
South East
For the record I did not mean to further imply that TXS was not concerned w/ reliability. Afterall, if they didn't care at all then people would stop bying their kits most likely (as happened to at least one turbo setup in the Miata community.) Anyone can have the potential to kill an engine: modified or even stock. So from a sheer probability standpoint there will likely eventually be someone somewhere that'll have problems. The only thing that I can say though for a fact was that last time I went to one of the local tracks (road course, not drag strip) there was a guy running the TXS Stage 4 kit. He was obviously having a bad day. I spoke w/ him for a bit and he said that he was having massive problems mostly w/ his EGT's wanting to go dangerously North (read 1700+. ) This was w/ the TXS UniChip, TXS IC, and everything. Needless to say he was quite upset he was being passed by Miata's on the straights b/c he couldn't get on the power safely on the track. I didn't go into detail w/ the man as I had to get ready for my session. FWIW when I ran that day in my Stage 0 WRX (stock IC) EGT's never went North of 1600f. I'm not saying that all instances of the TXS kits or stage 4 kits are, will, or do manifest themselves like this, but either way it was enough to scare me away from personally doing business w/ TXS (in regards to their UniChip tuning.) It's entirely possiable that this may be an isolated case and I hope it is, but this was my encounter w/ the TXS Stage 4 which wasn't exactly confidence inspiring.
--Matt |
11-17-2002, 08:14 AM | #23 |
Member#: 7468
This tread used to be about Doug's great run in his Vishnu stage 2 set up. But since everyone got a hair up ther ass whether Vishnu or Turboxs is the best. "The proof is in the pudding" how many 12 second Turboxs cars are there versus Vishnu?. Obsidian ( You do a great Marc Anthony ) I have 44k on my car and have been turboxs since 6k and no worries. You spoke of The "NO COMPROMISE" approach by Vishnu. You should ask Doug about this, or better yet how about the NO COMPROMISE product developement such as the Turboxs management system (utec) that allows you to run different maps,gas,boost etc with a flip of a switch while not cutting one wire versus that of the Vishnu that everytime the gas, and weather change you have to disconnect your hacked wires and send it to Shiv for a remap and hope its right. Obsidian Thanks for the lesson in Hindu it was quite enlightening. Does Obsidian mean anything in Hindu? If it does I bet its "wanker" Regards Michael
11-17-2002, 08:56 AM | #24 | |
Member#: 18713
Vehicle:06 CRV 04 STi |
d-e-f gave some results and opinions, and then we got some interesting discussion between 2 very knowledgable TurboXS and Vishnu people, which may have drifted slightly off topic, but in the spirit of making direct comparisions. I agree that Obsidian's post of trying to explain the origin of the Vishnu name seemed slightly out of place. But, not enough to make him a "wanker" |
11-17-2002, 09:43 AM | #25 |
Member#: 7468
I am sorry you're right the original tread was Vishnu 2 versus The Turboxs stage 4. Doug is a good friend so I was just happy he ran a 12.7 on the Vishnu 2 system. As for my remarks toward Obsidian well just read his posts and you too will understand the ways of a "wanker". Boy I hope I didn't hurt his feelings. Thanks Michael
Rallispec rules- wrx 2.0 Ecutek Stg 2-->VF39/Stg 4/2.0 Review | Blown95ImpalaSS | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 14 | 04-23-2006 10:41 AM |
Stg 2 TXS STi in the 1/8 | burnin4 | Proven Power Bragging | 11 | 08-08-2004 11:29 AM |
Vishnu Stg 2 wgn, Mods 4 sale, Seller pays Escrow | familywagon | Private 'For Sale' Classifieds | 37 | 01-25-2004 04:36 PM |
Can I use a stg 2 TXS UTEC W/O a boost controller and uppipe? | waitandbleed92 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 03-16-2003 09:53 PM |
Vishnu stage 2/TXS stage 4 setups | UGotWRXed | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 10-09-2002 02:05 PM |
