Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2024
Old 11-03-2004, 10:33 PM   #1
vitaminwrx
Member#: 46978
Default Anyone else's WRX not start on the first time occasionally?
Today I try to start my car, and on the first two times, it just won't turn over.
Seriously, I don't get it, am I the only one? Once every couple of months, when I try to start my car, it keeps on trying to turn over, but just wont start. It's wierd because it doesn't matter when I start the car, it's completely random.
Anyone else have this problem? It's been happening since I was stock. Only mods are an uppipe and downpipe.
vitaminwrx is offline   Reply With Quote
Old 11-03-2004, 11:11 PM   #2
subimp6u08
Member#: 15440
2015 STi
mine does that too i dont' know why
mine's 100% stock except cosmetic changes
subimp6u08 is offline   Reply With Quote
Old 11-03-2004, 11:19 PM   #3
Unabomber
Big Ron
Super Moderator
Member#: 18062
on car parts so PM
me b4 j00 buy
Probably due to lack of fuel pressure. Get in the car, turn the key to the ON position, buckle up, then start your car. Due to govt. regs, all modern cars have to vent their fuel pressure back into the tank. When your car sits for awhile (varies between vehicles) you won't have any gas until the fuel pump charges the fuel system.
Old 11-03-2004, 11:43 PM   #4
vitaminwrx
Member#: 46978
Thanks for the replies, guys.
Uni: When I start my car, I turn the key to the "on" position for about 3 seconds (or until I stop hearing the buzzing noise). Is this long enough, or should I give it maybe 10 seconds?
Old 11-04-2004, 12:19 AM   #5
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
What range spark plugs are you running. It could be due to the cooler weather we are having. I run one step colder plugs and my car is garaged every night. I've never had a problem starting it, but this morning it was pretty cold and for the first couple seconds it was rough until it got up to a decent temp.
dan avoN7 is offline   Reply With Quote
Old 11-04-2004, 01:30 AM   #6
David Medina
Member#: 37721
2003 WRX sedan
pearl blue
my car does it. only happend about 5 times.
David Medina is offline   Reply With Quote
Old 11-04-2004, 01:32 AM   #7
dElKwOn
Member#: 71184
Chapter/Region: HIIC
2002 ewg'd vf-34'd
GDA AMS Tuned !
Impreza WRX STi
my car would also do this , then i changed my battery ... and it hasn't happened since . if all else fails give it a shot .
dElKwOn is offline   Reply With Quote
Old 11-04-2004, 02:17 AM   #8
CyCoFooKee
Member#: 54649
2004 Impreza WRX
Java Black
ya dude, my 04 does that occastionlly....its odd. Its like you have to hold the ignition for like 5 secs until it turns over...has happend in a while but still does sometimes...
CyCoFooKee is offline   Reply With Quote
Old 11-04-2004, 02:29 AM   #9
black05wrx23
Member#: 68642
05 wrx
black
my 05 does it too, the first time it happen I took a ****. It has happen to me occasionally and my car is stock. Like I try to start it and it wont start the first time then I do it again and it starts so I dont know what it is.
black05wrx23 is offline   Reply With Quote
Old 11-04-2004, 02:35 AM   #10
vitaminwrx
Member#: 46978
Wow, looks like i'm not alone!
Dan Avon7-Thanks for the suggestion, I may be trying those one step colder plugs.
Old 11-04-2004, 04:26 AM   #11
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Colder plugs will make the problem worse, not better. But otherwise yes, seems to happen to everyone now and again.
drees is offline   Reply With Quote
Old 11-04-2004, 07:09 AM   #12
pezman04wrx
Member#: 66558
Same here ... Usually when I'm leaving work and the car has sat there for 8hrs ... I'll have to try the "prime the fuel lines" trick you guys are mentioning ... It's happend about 3 times to me so far, car only has 5k on it ... Go figure ...
pezman04wrx is offline   Reply With Quote
Old 11-04-2004, 08:10 AM   #13
jvic
Member#: 34953
2011 Legacy
Has happened to me since I got the car (new). I try to give a few seconds with key on/not turned over, but sometimes I forget...
jvic is offline   Reply With Quote
Old 11-04-2004, 09:32 AM   #14
Ghost Rider
Member#: 70346
2017 Golf R
Deep Black Pearl
I was just going to post something about this, it is wierd how that happens sometimes.
Ghost Rider is offline   Reply With Quote
Old 11-04-2004, 09:44 AM   #15
cbr600f3
Member#: 55067
2015 Audi S3
Monsoon Gray
Optima red top here.
cbr600f3 is offline   Reply With Quote
Old 11-04-2004, 03:51 PM   #16
WizardGandoff
Member#: 36667
04 DrgSmugrXps
Blackwiththablingblingold
my 04 does it
WizardGandoff is offline   Reply With Quote
Old 11-04-2004, 03:53 PM   #17
WizardGandoff
Member#: 36667
04 DrgSmugrXps
or its about to start and half way threw it just cuts out like the clutch isnt pushed it. and i have to push the clutch in again to start it
Old 11-04-2004, 04:18 PM   #18
Silver_04_WRX_SC
Member#: 67198
2004 WRX Wagon
My car does it also every now and then, will jump in and it takes maybe 5-8 secs to start..and I usally stop trying and then it fires up. Almost like you want to pump the gas to get her firing..very strange.
Silver_04_WRX_SC is offline   Reply With Quote
Old 11-04-2004, 07:56 PM   #19
Subie123Poot
Member#: 67364
2005 STI
my '04 has 4k on her and has done that once so far as well
Subie123Poot is offline   Reply With Quote
Old 11-04-2004, 10:17 PM   #20
MdWRX
Member#: 69636
2002 Wrx
Sedona Red
Mine did that once or twice, make sure you have the clutch in before you turn the ingnition to the 'ready' position, i think that is the only reason mine seemed to do it if it started to turn the key before the clutch was fully depressed.
MdWRX is offline   Reply With Quote
Old 11-05-2004, 12:39 AM   #21
jesse370
Member#: 12147
2005 g-35
ivory pearl
I think in most cases it is the battery. It is a very weak unit.
jesse370 is offline   Reply With Quote
Old 11-05-2004, 02:57 AM   #22
AWDfury
Member#: 29819
02 wrx wagon
sedona red pearl
leaving the key in the on position first for a few seconds usually did the trick. But yea, i would think the battery needs to be replaced with one that has more CCA's for those who live in the colder climates.
AWDfury is offline   Reply With Quote
Old 11-05-2004, 07:51 AM   #23
lionken07
Member#: 13660
16 BRZ Limited 6MT
04 WRX 5MT
Optima battery is your friend. You can even use them when the car is off with no problem!! way better than stock.
lionken07 is offline   Reply With Quote
Old 03-14-2005, 04:21 AM   #24
BobbyV
Member#: 55792
i did a search...and found this thread. my car does this exact same thing. could my blow off valve be part of the problem perhaps?? HKS SSQV.
BobbyV is offline   Reply With Quote
Old 03-14-2005, 07:59 AM   #25
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
mine does it too.... I don't think it is related to the stock battery or BOV's either...
What I do now is to prime the fuel system a few times before i go to start, but then, once every few months, the car will turn over but no start.
Even after getting a new battery with over double the CCA of stock, i have still had the car fail to start on the first attempt.
The advantage of having a better battery on the car is that on cold mornings when the car pulls off this stunt, the battery has enough grunt to spin the engine over again to attempt to restart. With the stock battery in winter, if the car failed to start the first time, you may be screwed, since it can barely muster another attempt...
jigga is offline   Reply With Quote
Car Just started for the first time after swap! But there are a few problems :(.HELP snowcrzy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 07-24-2007 06:09 PM
Anyone else's trim piece not fitting on the sides? pieces Car Audio, Video & Security 17 02-04-2007 09:29 PM
not sure how i missed this little gem the first time in the 80's Fyxtion Off-Topic 19 07-14-2005 09:22 PM
Anyone else's WRX sound like its about to die out before it starts up? WRXakaBooSTi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 01-07-2005 07:29 PM
ECU reset, doesnt start on the first try? moogooob Normally Aspirated Powertrain 4 08-21-2002 01:45 AM
