12-12-2010, 04:01 AM | #4926 |
Member#: 234270
Vehicle:99 sti swap gray |
all HID, 8000k , I love them, Thank you for looking lol
12-12-2010, 12:02 PM | #4927 |
Member#: 144821
Vehicle:1994 LS1 Miata 2015 white WRX |
All the blue is less than ideal for visibility, but I'm sure you already know that...or will soon find out.
12-12-2010, 12:07 PM | #4928 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
8kHID=epic fail
You lose the internet. |
12-12-2010, 12:33 PM | #4929 |
Member#: 251060
Vehicle:2008 Impreza Outback Black |
And what exactly do you "love" about them? it looks horrible, and they're not even aimed right. |
12-12-2010, 05:52 PM | #4930 |
Member#: 144821
Or just do away with the HIDs. Halogens win unless the reflectors are actually intended for HID bulbs.
12-12-2010, 09:02 PM | #4931 | |
Member#: 234270
Its a very sad thing when all people do is talk crap, I just posted it because i did not see any hid lights bars on here, its not like i really care what anyone thinks, I just thought some of you mite like to see what it would look like. Funny it sounds like in on a Honda forum and not a Subie forum the way you guys talk. Well thats fine, have fun bashing my style guys. |
12-12-2010, 09:37 PM | #4932 | |
Member#: 229527
Vehicle:2009 Subaru WRX WR Blue |
im gonna be making mine up in a week or so and was curious where u mounted the bar to car (if u had to drill any holes or any modification to the plastic skid plate?) thanks |
12-12-2010, 09:38 PM | #4933 | |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
There is also a reason why "NAZIOC" auto filters to "NASIOC" |
12-13-2010, 12:28 AM | #4934 |
Member#: 3265
NESIC
Vehicle:2013 WRX Hatch ISM 2013 Outback Limited |
No worries AFAP_Nor_CA I think yours looks Great! Is it stable or does it bounce at all?
12-13-2010, 12:52 AM | #4935 | ||
Member#: 131787
Vehicle:06 STI,OB,OME XJs Merkur Junkyard |
I suspect you can find some heavy reading in this very thread to educate yourself about what williaty is referring to. In fact you'll probably find that he is the author of some very detailed posts on the subject. Or you can continue solving your lighting problems with style instead of science. Quote:
Back to light bars! |
12-13-2010, 01:44 AM | #4936 | |
Member#: 234270
Now on to what i would like to tell anyone who is going to us hid. DO NOT CUT THE WIRES!!!!! if you need to make the longer just buy a HiD Extension Cable Wire Harness. they dont cost to much and you can find them on ebay. I rewired this 4 yes 4 times before i got it through my head that ITS NOT THE THICKNESS OF THE WIRE, ITS THE SHIELDING THAT MATERS. i used 12 gauge wire before i found that out and i was having a problem with the lights firing up. sometimes only 3 would fire and some times none would at all, i would hear a cracking sound coming from the wires them selfs and im very glad i did not burn down my car lol. If you look at even the plugs of the hid you will see that they are not together but each wire going to the light has its own plug. This is high voltage so please keep all this in mind. If i had to do it all over again (which i will on my next subie) i mite think about putting all the ballast under the glove box. Next i would us a light bar that is able to come off ez like with pins, i have some ideas. As far as color of the lights, i have always liked the 8000k i would never go more blue. It its not hard to understand why blue is not the very most best kind of light but like i said I LIKE IT, and I think it go's well with the world rally blue. My Unk just got some 3000k and some 5000k so we are going to put them on his blazer and I will get a chance to see the 3 colors at once side by side. I would also think about looking for other light housings, mine are spot lights, and when you have 4 and the 2 head lights are fine but a little more wider beam mite be better, keeping in mind they they will be used off road on dark windy road, but like i said before, you dont miss anything with mine. All and all the build cost me about 230 bucks for every thing and i had alot of fun and its not somthing that every one has. So thats my story hope it helps some one. and thanks for the good feed back for a change. EZ to pick my kid out I LOVE HOW NONE LOOK THE SAME! Last edited by AFAP_Nor_CA; 12-13-2010 at 01:55 AM. |
12-13-2010, 01:56 AM | #4937 |
Member#: 71092
HIDs, regardless of color temperature, are discontinuous emitters. This is a bad thing for visual acuity.
HIDs of high color temperatures, more than 5k or so (though even the 3k HIDs have A LOT of blue in them due to the discontinuous emission spectrum), emit a staggering amount of blue light. The human eye cannot bring blue light into focus at the same time as warmer colors of light. This is bad for visual acuity. You're behind the curve on a pinned bar. This one has been mine since last year. The first one from this vendor was made several years ago. |
12-13-2010, 02:07 AM | #4938 |
Member#: 234270
im sure you right, but as for me when i switched my head lights over to hids i the really seemed a lot brighter and i could see down the road more clear but hey thats just me.
about the clip bar,, i was thinking some where have a pipe that your bar would slide into that would not be seen when your bar is not installed all depending on the shape of the bar and where it is you mite go 2 slide in pipes or 4. but both bar and pipe would have a place for the pin to slide into. What were your thoughts on how to build that? love your car by the way |
12-13-2010, 02:11 AM | #4939 |
Member#: 71092
What you describe is basically exactly how the Jackson Rally bar I have is done.
There's a receiver that mounts to the chassis where the bumper beam is bolted in. The receiver is directly under the bumper beam with just enough room above it to wiggle the bumper skin in. The receiver stops just before the edge of the bumper so it's effectively invisible when the bar is removed. The bar slides into the receiver and is made fast with two quick-release pins. The lights are wired on quick-disconnect fittings. Whole thing comes off in 10 seconds and goes back on in 30. |
12-13-2010, 02:37 AM | #4940 |
Member#: 234270
where did you get the skid plate or did you build it?
12-13-2010, 02:39 AM | #4941 |
Member#: 71092
Um... Both?
I'm working with a Subaru vendor to design a new skidplate. That's one of the early prototypes. I've since sent back a list of alterations that have to be made. It's the only skidplate on the market, well, soon to be on the market, that'll clear aftermarket headers without reducing the ground clearance below the level set by the stock subframe. |
12-13-2010, 12:30 PM | #4942 | |
Member#: 135252
Vehicle:2002 WRX Wagon |
12-13-2010, 01:44 PM | #4943 |
Member#: 71092
Yeah, I'd have preferred higher myself, but this is where it was able to be done with big strength and convenience.
12-13-2010, 02:48 PM | #4944 |
Member#: 135252
12-13-2010, 02:57 PM | #4945 |
Member#: 71092
Kyle was working on a modified version of it that'll work for many different light loadouts rather than just 4 big Hellas. I don't know if he's started production yet or not.
12-13-2010, 03:29 PM | #4946 |
Member#: 135252
I've got four 500FF's anyways that I'd be using.
12-14-2010, 09:24 PM | #4947 |
Member#: 151509
Vehicle:2003 WRX black |
I wan't one of those Jackson Rally light bars soooooooo bad! I emailed him a while back about when he was going to start up another production run, but never got a response.
12-14-2010, 10:48 PM | #4948 |
Member#: 71092
12-14-2010, 11:30 PM | #4949 |
Member#: 251060
Can anyone tell me how the rally innovations bar holds up in the winter? I dunno if I should bolt the top part to something.
12-14-2010, 11:49 PM | #4950 |
Member#: 44168
SCIC
Vehicle:2017 Silver Forester with not enough lights... |
I might have to call up Rally Innovations to see what they're up to... I've been out of t3h loop too long.
The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs | Yesitsdrew5310 | Electrical & Lighting | 616 | 03-09-2024 10:09 PM |
The Ultimate DIY Water/Alc Injection Thread | hippy | Water/Methanol Injection, Nitrous & Intercooler Cooling | 33 | 03-08-2008 03:11 AM |
My new Hella FF200 Driving Lights and mounts | wrxinfx | Electrical & Lighting | 14 | 04-17-2005 12:24 PM |
WTB: WRX or Impreza RS (old school) fog lights and mounting brackets. | Yamaha600Biker | Private 'Wanted' Classifieds | 2 | 06-08-2004 03:37 PM |
