01-06-2003, 04:20 PM | #1 |
Member#: 4989
oil leak from front of engine, oil pump?
( posted on the 90-94 legacy board as well, but thought someone may be of help here too )
Ok, so a few days ago I decide that my turbo wagon should get a tune up, so I change plugs / wires/ filters/ atf and oil. So the next day we head up to the mountains for our weekly snowboarding trip and when we get there and park there is CLOUDS of oil smoke comming off the exhaust. So I poke around and check fluid levels etc , find that it can wait till I get home to mess with. When I got home I proceded to check the filter , drain plug etc, replaced the filter just in case ( I have had a problem with some filters on my wrx just NOT sealing for some reason ) and I still seem to have some oil seeping down from under the timing belt covers. So I have searched a bit and found that it is possible that the oil pump could be loose, or the front seal is leaking, or both. So my questions is this, how hard is it to change the seal, is this a pull the engine sort of deal or something I can do with the engine in place? is there anything else I should look out for when doing this, tips etc. I am mechanically capable of doing this so that is not an issue. I wanted to check with the knowledge on the board before doing it. thanks, Nate
01-06-2003, 04:45 PM | #2 |
Member#: 8267
Vehicle:2010 MB E63 Black on Silver |
Well, I am NOT mecahnically knowledgable, but having just had this exact thing done about 6 months ago to my Turbo Sedan 5MT, I can tell you the dealer certainly did NOT pull the engine.
Jim |
01-06-2003, 04:48 PM | #3 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
thoughts
If it is anything like a MY98 2.5L, pull all the belts, front cover, timing belt, crank pulley and there is the front seal.
I did my seal when I did all the belts. |
01-06-2003, 04:48 PM | #4 |
Member#: 4989
cool, thats what I was lookin for , now to get to actually do it
if anyone has any more info on this I would love to hear it. thanks for the help guys. Nate Last edited by Nate@S-Squared; 01-06-2003 at 04:59 PM. |
01-06-2003, 05:06 PM | #5 |
Member#: 8267
I could probably scan my work ticket, would that help you?
Jim |
01-06-2003, 05:09 PM | #6 |
Member#: 4989
yea actually it might, if they listed what was done on it. if you want you can just email it to me at [email protected]
thanks! nate |
01-06-2003, 05:41 PM | #7 |
Member#: 8267
You have an email, sir.
Jim |
01-06-2003, 05:57 PM | #8 |
Member#: 4989
thanks !
01-06-2003, 06:04 PM | #9 |
Member#: 15543
Vehicle:555 Having a Subaru shop means too many cars |
Read what I said here http://www.bbs.legacycentral.org/viewtopic.php?t=328
You dont have to pull the engine but its HELL OF ALOT easier if you pull the radiator out. |
01-06-2003, 06:20 PM | #10 |
Member#: 4989
yup the rad is gonna come out, I am gonna do the water pump, t belt etc while I am in there. actually on the phone having my parts guy get me the parts now. hopefully by the end of the weekend I will have a no leaking legacy again :P
nate |
01-06-2003, 06:47 PM | #11 |
Member#: 4989
one more quick question since I am getting differing info on this, is the water pump the same on the non turbo and turbo ej22 engines?
thanks, Nate |
01-06-2003, 07:11 PM | #12 |
Member#: 15543
Not the same (posted on legacycentral as well).
From what I know the turbo pump has an extra nipple on the elbow and the thermo mounting surface is 90 degrees twisted (towards the front of the car). |
01-06-2003, 07:16 PM | #13 |
Member#: 4989
well that would explain the $60.00 price difference , why cant anything I do be cheap
thanks for all the help.. Nate |
01-06-2003, 07:19 PM | #14 | |
Member#: 3198
Vehicle:2005 GT LTD Wagon Garnet Red |
01-06-2003, 07:44 PM | #15 |
Member#: 4989
I think its more the subaru I chose, I seem to have this thing where I have to have the rare stuff, so when it comes time to fixing it I have to shell out more $$$ , oh well, I enjoy the turbo and thats all that matters :P
oil leaking from front of the car. (pics) | scoobiekid86 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 07-15-2009 06:11 PM |
Oil Leaking from Front Center of Engine | williaty | Service & Maintenance | 4 | 05-30-2009 10:39 PM |
pre ej20g install oil leak at rear of engine need part numbers fast | GregBolby | Pre-2002 Factory Turbo Powertrain | 5 | 05-21-2009 06:56 PM |
Oil Leak From Front Bottom Center of Engine that Isn't the Oil Pump? | williaty | Service & Maintenance | 4 | 05-21-2009 02:54 PM |
Oil leak from front seal | ctrexer | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 01-26-2004 03:36 PM |
