07-17-2011, 03:41 AM | #1 |
Member#: 268190
TXIC
Vehicle:2005 STi |
stock front fenders widened out like evodave kit?
hey guys is there anyone who sells a kit that includes spacers, bolts, brackets that can space out the front fenders to gain up to 30mm more clearance like the evo dave kit? I think itd be more cost effective than buying 10 mm "wider fenders"..
07-17-2011, 01:40 PM | #2 |
Member#: 147776
Vehicle:2001 Forester 2013 Scion FR-S |
I haven't seen a kit like that... it is interesting. Not quite sure how I feel about it.
http://www.fendermods.net/ This looks ok: This looks like poo: |
07-17-2011, 05:29 PM | #3 |
Member#: 268190
TXIC
Vehicle:2005 STi |
yeah the red evo is one of the better examples, no one has made a kit for our fenders? i know there is a a rwd gc8 on here with his fenders spaced out like that.
07-17-2011, 05:48 PM | #4 |
Member#: 255816
SCIC
Vehicle:2006 Subaru WRX WRB omgwtfbbq |
Isn't the AQ motorsports car running something like that plus fender flares? I to am interested in where this kit can be found or if there is a DIY floating around...
07-17-2011, 05:53 PM | #5 |
Member#: 268190
TXIC
Vehicle:2005 STi |
yeah i think aq is, but i want to save money and not run flares and still flush a 265 tire. there has to be something on this site...
07-17-2011, 06:20 PM | #6 |
Member#: 127232
W. Canada
Vehicle:2017 Mullet SS1LE |
07-17-2011, 06:25 PM | #7 |
Member#: 162174
Vehicle:05 CGM STi - SOLD 13 SWP STi - TITS |
I would like to find a kit as well. Fitting a 265 FLUSH would require a lot of roll and maybe even a pull on an 02-07.
For ~$70, and being reversible, that would be a good buy. I would much rather spend the money on a kit than rolling/pulling my fenders. Might avoid some paint/body damage as well. |
07-17-2011, 06:35 PM | #8 |
Member#: 268190
TXIC
Vehicle:2005 STi |
not fender flush though...
yeah you could but with +40 or higher offset,wanting to run lower offsets in front due to brembo clearance but also to help reduce understeer. a kit to give up to 30mm could let us run a 285 tire easily but thatd be overkill for my car. |
07-17-2011, 06:38 PM | #9 | |
Member#: 162174
Maybe we could talk to a Vendor to see if they could produce a kit similar to that of an Evo? |
07-17-2011, 06:44 PM | #10 |
Member#: 268190
TXIC
Vehicle:2005 STi |
hm vendor... thatd be awesome but what vendor could make a kit or even be interested in producing it?
07-17-2011, 06:47 PM | #11 |
Member#: 162174
TIC (Turn In Concepts), GrimmSpeed, ummmmm, I'm not too sure.
I'd say TIC first, then GrimmSpeed. Who would you think? |
07-17-2011, 06:52 PM | #12 |
Member#: 268190
TXIC
Vehicle:2005 STi |
tic would do it first, then probably gt spec, anyone else who has made fender braces... grimmspeed possiblly. we should see if we can convince them to make it!
07-17-2011, 06:53 PM | #13 |
Member#: 162174
Im gonna message TIC right now!
07-17-2011, 07:03 PM | #14 |
Member#: 268190
TXIC
Vehicle:2005 STi |
I wonder how long itd take for them to release the kit if they made it lol
07-17-2011, 07:06 PM | #15 |
Member#: 162174
Probably a few weeks. Just finished messaging TIC. Hopefully they reply with some good news.
07-17-2011, 07:07 PM | #16 |
Member#: 127232
W. Canada
I still don't understand what you want. You can fit 265's on the stock body with a pull/roll, if you have the right offset wheel and enough negative camber. Pick the wheel you want to run and modify accordingly, not the other way around.
07-17-2011, 07:10 PM | #17 |
Member#: 162174
Basically, NO PULL, NO ROLL, NO POSSIBLE BODY DAMAGE!
We get to stuff a wider, lower offset rim/tire combo. If we RTS, we can unbolt it, and have clean fenders. Simple. |
07-17-2011, 07:28 PM | #18 |
Member#: 268190
TXIC
Vehicle:2005 STi |
^^ exactly, and also with this kit you dont have to run so much camber in the front..
if tic agrees to make it, ill preorder it asap lol |
07-17-2011, 07:31 PM | #19 |
Member#: 162174
Same here.
I'm pretty sure the AutoX, SCCA, and Hella Flush guys would probably jump all over this for their various reasons. |
07-17-2011, 07:34 PM | #20 |
Member#: 213413
SCIC
Vehicle:2004 STI WRB |
what about the rear though? would it be a higher offset wheel or what?
im thinking 265 all around the rear would need some clearance help as well (just camber?) |
07-17-2011, 07:36 PM | #21 |
Member#: 268190
TXIC
Vehicle:2005 STi |
the rears are easier. its just like normal. roll, shave and pull for most clearance necessary.
07-17-2011, 07:38 PM | #22 |
Member#: 162174
The rear would unfortunately remain the same. Rolling, Pulling, and possibly Grinding.
I couldn't see a 285 but maybe a 265 or 275. 265 is nothing crazy but I would say it would need camber and a roll/pull. Check out the Member's car gallery or Wheels and Tires. Fitment's have been thoroughly covered. |
07-17-2011, 08:06 PM | #23 |
Member#: 268190
TXIC
Vehicle:2005 STi |
285 is possible, username HORSE had 285 and now 295 stock fenders...
07-17-2011, 08:12 PM | #24 |
Member#: 162174
Yea, it is possible. I wouldn't be going that big. 265's or 275's at all 4's seems to be enough. Unless you're doing something completely crazy.
I saw a pic of his car the other day.....AMAZING! |
07-17-2011, 08:25 PM | #25 |
Member#: 268190
TXIC
Vehicle:2005 STi |
i used to want 17x9 five zigen fnro1c +43 with 275 on stock fenders, but i decide i wanted something wider and way lower offset. I was thinking of either xxr 526 17x10 with spacer to clear brembo or 17x9.5 varrstoen 2.2.0 +12 offset, and this kit if made would definately help out with clearance!
Similar Threads | ||||
pic request: widebody rear panels with stock front fenders?? | naggg | Member's Car Gallery | 16 | 03-27-2008 06:33 PM |
Stock front right fender and stock 4300k HID d2r bulb | t-rex25 | Exterior/Styling | 36 | 12-14-2007 01:06 AM |
WTB: LI, NY: Sonic Yellow Sedan Front Fenders, STI scoop, Body kit | chrisarella | Private 'Wanted' Classifieds | 1 | 12-11-2005 07:48 PM |
WTB: LI, NY: Sonic Yellow Sedan Front Fenders, STI scoop, Body kit | chrisarella | Tri-State Area Forum | 4 | 12-10-2005 04:08 PM |
