12-22-2014, 03:49 PM | #1 |
Member#: 327329
Vehicle:2002 Impreza WRX Black |
Tactrix reflash subaru impreza usdm 2002
Such friends would like to know if i could help to reflash my ECU i have a subaru impreza wrx 2002 what conectors are those that i have to bridged .
I have tactrix cable open port 2.0 My computer is hp with windows 7 64bits and the drivers are installed i need help please Sent from my SM-G900H using NASIOC mobile app
12-22-2014, 03:54 PM | #2 |
Member#: 204578
Connect the green ones together, and (if you don't have this: http://tunertools.com/evoscan***tact...connector.html ), use a paper clip to jump the connectors of the corresponding female plug under the dash.
12-22-2014, 04:07 PM | #3 |
Member#: 327329
I have this conector i buy the set of tactrix but i cant the error is get kernel error and interface close i dont now what i can do
Sent from my SM-G900H using NASIOC mobile app |
12-22-2014, 04:09 PM | #4 |
Member#: 204578
12-22-2014, 04:15 PM | #5 |
Member#: 327329
the check light is flashing and the cycle of fan and the fuel pump its working but when i click in the program starts read and then error get kernel interface close
12-22-2014, 04:24 PM | #6 |
Member#: 204578
PM a mod to get this moved here:
http://forums.nasioc.com/forums/forumdisplay.php?f=80 You'll find more people that can give you some advice. Try reinstalling ECUflash? |
12-22-2014, 04:27 PM | #7 |
Member#: 361810
NESIC
Vehicle:2010 GSR EVO X Wicked White |
If you are having issues doing this you probably shouldn't be touching your ecu... Fair warning.
12-22-2014, 04:36 PM | #8 |
Member#: 327329
No i didnt try reintalling the ecu flash but i understand why i cant do the reflash
12-22-2014, 04:41 PM | #9 |
Member#: 327329
Only one conector i need to usr...???
12-25-2014, 11:31 AM | #10 |
Member#: 316863
E. Canada
Vehicle:2001 2.5RS Red |
Good luck, I could never get my op2.0 cable to work, tried everything. Wasted over 30 hours messing around trying to get it to work. (03 WRX)
Tried an op1.3U cable and it worked instantly. Something about the new firmware. |
12-26-2014, 06:26 AM | #11 |
Member#: 319257
Did you quickly turn the igition to 'on' position and quickly click 'ok'? You need to do it before all the fans and etc start cycling.
12-27-2014, 08:27 PM | #12 | |
Member#: 236475
BAIC
Vehicle:2002 WRX Black |
If you're having a problem in the future, send an email to support at tactrix dot com. We try to get back to you quickly and even over the holiday break I've been answering support questions almost daily. |
12-27-2014, 08:53 PM | #13 |
Member#: 316863
E. Canada
I should have updated my post: the new firmware I got made my cable come back to life! I didn't know you guys had such responsive support, I knew/know you're a fairly small company.
12-27-2014, 09:02 PM | #14 |
Member#: 236475
BAIC
We try to offer support bigger than our size Again, sorry you had the trouble you did though. We're going to get an official release containing this fix out shortly. We're just trying to wrap up a couple other issues in the same distribution.
01-06-2015, 09:16 PM | #15 |
Member#: 327329
Hi mens i cant do work this **** i try in a mitsubishi evo 7 and he works i try an other tactrix and not work im reinstall the programs and not work i dont know i need help ...!!!!
01-07-2015, 01:01 PM | #16 | ||
Member#: 236475
BAIC
and I also posted here that same day to let anyone know how to contact us directly to get quick service: I just checked our ticketing system and found your email address from your order but you haven't contacted us once. Is there a reason you never read my post here (in reply to a thread you started!), or read my PM, or haven't bothered to contact us by email?? |
01-07-2015, 01:57 PM | #17 |
Member#: 327329
Hi mikeypsf im try register in the page to de forum but dont send the email confirmation i cant log in the forum i download the version if you send my and the steps to do the reflash but i can conect to my ecu...!!!
01-07-2015, 02:07 PM | #18 |
Member#: 236475
BAIC
You don't need to register anywhere. Just send me an email: support at tactrix dot com
I promise, It really is that easy. |
01-07-2015, 10:26 PM | #19 |
Member#: 327329
thanks mikeyPSF its work install the version for de pm and work thanks bro really thanks...!!!!
01-07-2015, 10:37 PM | #20 |
Member#: 236475
BAIC
Excellent! Glad to hear the problem is solved. Happy tuning!
