01-02-2015, 04:16 PM | #1 |
Member#: 399324
trouble re-enabling codes after pro tune
hello like the title says I am having trouble turning codes back on after pro-tune. I bought the car with the tune already on it and I believe it was done at precision tuning in nj. and now I am getting a cel with no codes and cel flashes under heavy load. I was able to read the tune using ecuflash and openport2.0 my issue is when I attempt to turn the disabled codes back on there is no option to in ecuflash. it just says disabled and when I select it, it just highlights It with no option to enable. I also tried to open the file in romraider. I can open it fine, there is an option to actually enable the codes, when I save it however. it doesn't save as a readable file in ecuflash to flash it back into the ecu. the codes I found that were disabled are p0420 p0545 p0546 p01301 p01312. I just want to enable the codes so I can c what the problem is so I can fix it.
ps I have the green connectors connected when reading/writing but not the white plug jumped. could that be an issue. any and all help is appreciated. I tried searching but could not find anything that helped
01-02-2015, 06:02 PM | #2 |
Member#: 70395
You didn't list what model/year car you have or mods. Flashing CEL is generally a gross misfire. Enabling those codes isn't going to help you. Did you not bother to look up the codes? 4 of them are for the EGT sensor which I am assuming you no longer have. The P0420 is probably because you have an aftermarket exhaust yes?
01-02-2015, 06:13 PM | #3 |
Member#: 399324
02 wrx. Missfire codes are enabled. P0301-04 still has stock downpipe with cats. Still seeing a change in corralation between primary and secondary o2s so there is something there. Weather or not its within the threshold is unknown. As far as i know it has a vf39 with sti top mount and borla catback. And i am still getting egt reading that change.
01-02-2015, 06:47 PM | #4 |
Member#: 70395
Sounds like you have bought someone's headache. Regardless,flashing CEL is gross misfire and nothing else. I have no idea what you are talking about with the O2 sensors. The P0420 just disables the catalyst efficiency code for the rear O2 sensor. The rear O2 sensor is still going to be functional. You need to check and see if it has the OEM catted up-pipe and if the EGT probe is in it.
01-05-2015, 09:39 PM | #5 |
Member#: 399324
Welp i figured out how to re-enable the codes on ecuflash. You have to us [ ] to change the values. (They really should say that more clearly) and trying to turn the misfire fix of without turning the readness fix off was fun figuring out. But after all that it is showing codes now. P0304 swapped the coil and it didnt move. So my next step is moving the injector bc i noticed that at full boost higher up in the revs there at about 95% duty-cycle. And they are stock with the bigger turbo and have been like that for 2 years so im sure they are tired
