02-13-2008, 04:17 PM | #1 |
Member#: 122302
Vehicle:2007 Impreza 2.5i Newport Blue |
Trouble Shifting after donuts?
I pull into a parking lot full of a ton of slush and snow to do donuts today. That lasted about a minute so i went to park, i get into a parking space and try to shift into park, and the car willnot shift out of N, into R, to get to P. It was stuck in Neutral and wouldnt budge into R, or P. But i could go back down to D, 3, 2, or 1st gear. but not into R or P. I try it again pushing the shifter harder into R, (using more force than i should need to to shift) and then it shifts into R and then P. I try to shift again and drive around another minute just to be sure nothing is wrong. What would cause trouble shifting from D->N->R after doing donuts??? (2007 impreza, auto) any thoughts?
02-13-2008, 10:55 PM | #2 |
Member#: 84405
NESIC
Vehicle:2007 V8 4Runner 1994 flaming red Miata |
Its the Stick Shift Gods punishing you for driving an automatic.
(Make sure your foot is on the brake while you are trying to move the gear selector) |
02-13-2008, 11:09 PM | #3 |
Member#: 87067
AKIC
Vehicle:02 Old but tasty SRP |
If it gets stuck in park there is a override under the little tiny door. Flat blade screwdriver. If its those damn manual god again... It cant be helped.
02-13-2008, 11:27 PM | #4 |
Member#: 106411
Vehicle:2001 GM6 Silverthorn |
Maybe the car protecting itself from you
02-13-2008, 11:30 PM | #5 |
Member#: 133379
Vehicle:2004 legacy gt silver |
^^ Lmao
02-13-2008, 11:54 PM | #6 |
Member#: 89528
Vehicle:2005 sti crystal grey |
check all your motor/tranny mounts. something's probably moved.
...and sacrafice a virgin snow tire to the SSG's before it's too late |
02-14-2008, 12:34 AM | #7 |
Member#: 112433
E. Canada
Vehicle:06 WRX.stage2 OBP |
bad camber problems after donuts and fun | lowranger | Brakes, Steering & Suspension | 5 | 03-18-2008 12:34 AM |
trouble shifting after donuts? | nyx | Normally Aspirated Powertrain | 5 | 02-13-2008 05:06 PM |
Get in trouble for doing donuts!? | 04.STI | Off-Topic | 28 | 03-13-2007 02:16 AM |
My car in the garage after donuts... | GeoffM | Mid Atlantic Impreza Club -- MAIC | 6 | 12-06-2003 11:47 PM |
trouble starting after short trips | henry1ma | Service & Maintenance | 0 | 02-17-2003 11:19 AM |
