11-14-2007, 04:04 PM | #1 |
Member#: 155648
TXIC
Vehicle:2011 WRX World Rally Blue |
How important is it to learn how to rev match?
I want to learn how to rev match because I was told it can lessen the shock on your tranny when you downshift. Is it even neccessary? I feel uncomfortable downshifting sometimes because I feel that nasty clunk sound. I have ridden with people who can do that and it feels sooo smooth when they do it.
11-14-2007, 04:07 PM | #2 |
Member#: 3272
RMIC
Vehicle:2015 Toyota Sienna Black with Gold Wheels |
Not very important.
But, I like to do it because it feels smooth when down-shifting and its habitual now. Helps save the synchros a little bit and sounds cool when pulling into a ricer meet. Also helpful for going into 1st gear while still moving, which can be difficult in our cars. |
11-14-2007, 04:12 PM | #3 |
Member#: 128109
Vehicle:2011 E82 135i Alpine White |
It takes some time to learn. I figured out it's really easy to do wearing dress shoes, since the sole is wide enough to brake and tap the gas at the same time. This way you don't have to heel-toe. It took me about 5,000 miles, but now I can do it easily every time.
11-14-2007, 04:12 PM | #4 |
Member#: 55869
TXIC
Vehicle:YOTA Taco M796 |
In autocrossing, i only do it do go back into 1st off a tight U-turn...
other than that, Brakes are cheaper than Transmissions.. no need to downshift to slow down I cant say it wouldnt hurt to learn it, but I cant say that you MUST learn it either EDIT: you don't have to heel-toe to blip the gas pedal before a downshift.. |
11-14-2007, 04:13 PM | #5 |
Member#: 142520
TXIC
Vehicle:2006 STI - Protuned 308whp - SilverFox |
i too am addicted to rev-matching. i just recently started doing it but i would say that about 80 percent of the time i hit the rpms right on. the other 20 percent of the time i'm either a little bit too high or too low when i let off the clutch.
it does help a bit i'm sure. but i look at it this way. which is cheaper to replace?? tranny, or brake pads? you can slap pads on your car quickly and wayyyyyy cheaper than dropping the tranny and replacing it. --J |
11-14-2007, 04:17 PM | #6 |
Member#: 26361
TXIC
Vehicle:My shenanigans are cheeky and fun |
For daily driving you never need to use it, but if you are ever on a road course or pretend that the street is a road course then its pretty damned important to do it well.
11-14-2007, 04:21 PM | #7 |
Member#: 155648
TXIC
I do go into neutral to brake to a, let's say, a stop light, but what if you are driving and some guy pulls out in front of you going about 10-20 MPH on a highway in your lane (Happens all the time). If I want to move over to the other lane and I down shift to get more torque, because there are cars incomming in the other lane, can't you just revmatch so that you don't shock your transmission?
11-14-2007, 04:23 PM | #8 |
Member#: 26361
TXIC
Yeah, but its easy in that situation, just brake, after you are slowed down floor it and then downshift. And remember its better to guess to high with the rpms than to guess to low.
11-14-2007, 04:25 PM | #9 |
Vendor
Member#: 155450
Vehicle:2007 FXT WRB |
I do it pretty much every downshift out of habit. It wont cause tranny problems if you dont grind it. Slowing down with downshifts obviously causes more wear on the clutch (only as much as a normal shift though) and thats way more expensive than brakes.
I have always used downshifting and the engine for minor slow downs and such, I only started rev matching because I was starting to do track days and needed to learn the skill so I did it to practice. It just became habit. *shrug* |
11-14-2007, 04:28 PM | #10 |
Member#: 55869
TXIC
its habitual to me also, i was watching WAY too much Best MOTOring
11-14-2007, 04:36 PM | #11 |
Member#: 142608
TXIC
Vehicle:2003 Sonic Yellow Marginally well behaved. |
^^ I have to agree with several others above. Don't downshift to slow down, only downshift to go faster. Brakes are on the car for a reason, and they are indeed..._much_ cheaper than trannies and clutches.
11-14-2007, 04:51 PM | #12 |
Member#: 3272
RMIC
If you live in any place it snows, you WILL use down-shifting to slow down...
Best reason to double clutch: |
11-14-2007, 05:04 PM | #13 |
Member#: 152553
TXIC
Vehicle:2005 05 STI-Dom3 2006 B9 Tribeca Ltd. |
It's rarely necessary to use, but nice to know how. I, on the other hand, rev-match constantly when downshifting. if you're driving aggressively, it'll help to rev-match when down shifting so as to keep the weight transfer to a minimum in a turn (serious understeer/oversteer can occur)
11-14-2007, 05:10 PM | #14 |
Member#: 161325
Vehicle:'91 sentra se-r '92 se-r, '98 4runner |
if you really want to drive your car fast (and by drive i mean something other than hauling ass in a straight line) doing it on every shift just makes it that much more of a muscle memory response for when you actually need it.
11-14-2007, 05:14 PM | #15 |
Member#: 155648
TXIC
What is a double clutch btw?
11-14-2007, 05:19 PM | #16 |
Member#: 8891
International
Vehicle:2002 WRX Silver '02 SV650 |
11-14-2007, 05:21 PM | #17 |
Member#: 161325
clutch in
shift to neutral clutch out blip throttle clutch in select gear clutch out http://www.youtube.com/watch?v=0j-3xIZK-Bk |
11-14-2007, 05:51 PM | #18 | |
Member#: 26859
TXIC
Vehicle:of TXIC I also like (oYo)!!!! |
if you do, you are putting more wear on your synchros. downshifting (and rev matching) won't have any more of a negative effect on your drive train than any thing else. to save the synchros you should double-clutch, I'm sure others have chimed in on this, but anyway, I've driven a couple of cars over 100k miles downshifting with rev matching, but no double clutching, no synchro issues, and on my old integra I put almost 200k on it without seeing any noticable wear on the synchros. anyway, know that there are potential issues not only with doing a downshift incorrectly, but that there are potential issues with wearing out the synchros faster. |
11-14-2007, 05:55 PM | #19 |
Member#: 8891
International
Don't go into too low a gear and let the clutch out, rev limiters don't prevent a 12K rpm connection to the tires.
Do braking first, then rev match. |
11-14-2007, 05:56 PM | #20 |
Member#: 26859
TXIC
11-14-2007, 06:05 PM | #21 |
Member#: 8891
International
11-14-2007, 06:18 PM | #22 |
Member#: 128109
11-14-2007, 06:42 PM | #23 |
Member#: 155648
TXIC
11-14-2007, 06:49 PM | #24 | |
Member#: 155648
TXIC
11-14-2007, 06:55 PM | #25 |
Member#: 97043
TXIC
Vehicle:08 STI 02 Z28 - project |
just start doing it whenever you drive. You'll get the hang of it and rev match like Speed Racer in no time.
Similar Threads | ||||
How important is it to defragment a computer? | affinity1 | Off-Topic | 9 | 01-17-2009 03:53 AM |
How important is it to resurface the flywheel? | stephan | Transmission (AT/MT) & Driveline | 12 | 09-16-2004 07:40 PM |
how important is it to break-in fully? | Predator3 | General Community | 21 | 08-09-2004 08:45 AM |
how important is it to torque the turbo downpipe bolts | WRxednEffect | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 02-14-2002 07:54 PM |
how important is it to get the front o2 sensor replaced? | inpreza kid | Canada Region Forum | 1 | 08-02-2001 02:35 PM |
