01-26-2007, 09:53 AM | #1 |
Member#: 98812
Clutch Rattle Noise 02 WRX
Hey i have a 02 wrx. recently ive been hearing this rattle coming from under my car. i started to think it was some heat shield making the noise but i was messing around and realized that only when im in neutral with the clutch up i hear the rattle. when i push the clutch in the rattle noise goes away. i got my clutch changed at the dealer about 10k miles ago. does anyone else have this problem?/?/?
01-26-2007, 10:00 AM | #2 |
Member#: 130144
South East
Vehicle:2007 STI Limited |
I have the same problem on mine but I only hear it will its in gear and I am slowing down. I have asked around and this noise is a pretty coomon factor with the 02-03 Tranny's, nothing wrong just noisey
01-26-2007, 10:01 AM | #3 |
Member#: 98812
hahah i dont know if this should be normal. it sounds like my clutch springs or something in there thats not tight.
01-26-2007, 12:29 PM | #4 |
Member#: 92114
NESIC
Vehicle:03 WRX (NAVY Camo) in"Special Ed." Run Group |
Did you put in an aftermarker clutch and flywheel combo or did you replace with stock. They do rattle a little but the noise is usually magnified when you to aftermarket units.
I've had two replacement clutches in mine so far and still have that noise in neutral without the clutch depressed. At 1st I thought it was a throwout bearing gone bad but it wasn't. It's just one of those things you have to get used to. |
01-26-2007, 02:48 PM | #5 |
Member#: 98812
everything was replaced with stock parts. i got it done for free at the dealer cuz i had the 02 wrx clutch chatter when its cold out. ive also been hearing a weird noise when i switch from first to second gear. both noises started happeneing at the same time. i wonder if i can go to the dealer and make them check it out for free.
01-26-2007, 02:51 PM | #6 |
Member#: 98812
the thing is it dosent allways rattle. sometimes it does and sometimes it dosent. and it goes in and out like it starts to rattle then stops and then starts again after 10 seconds. its really annoying and loud. mostly it makes the noise when its really cold out.
01-29-2007, 08:08 PM | #7 |
Member#: 98812
anyone have an idea on what it can be??????
Growling Noise 02 WRX | turbobird14 | Transmission (AT/MT) & Driveline | 12 | 05-15-2008 06:11 PM |
Grinding engine noise 02 WRX | dpalo81 | Service & Maintenance | 6 | 06-25-2006 08:37 PM |
Flywheel noise 02 WRX | Yin | Transmission (AT/MT) & Driveline | 0 | 08-28-2005 09:08 PM |
Exedy standard clutch kit for 02 WRX? | MackDaddy | Transmission (AT/MT) & Driveline | 2 | 09-16-2002 06:40 AM |
