03-17-2006, 09:36 PM | #1 |
Member#: 88086
Vehicle:05 STi Black on Gold |
Speed sensor wire / Wiring on AVN5435
So I thought everything was wired up right. All day today I kept getting that "check speed pulse" message whenever I would go into navi mode, but figured it was working so I thought it was okay since it would properly navigate the car and the messafe would go away after about a min. Well i read up and it says the wire is not conencted to the speed wire on the car. I tried by the ecu and I tried the wire behind the gauge cluster and it still didnt work. When i go into systems check, it displays the speed, but the wire is not hooked up.
Anyone have a diagram, a picture? Thanks...
03-18-2006, 02:15 AM | #2 |
Member#: 51692
SCIC
Vehicle:04 STi JBP Enginuity Tuned |
did you cut the wire short and remove the diode? if you did you probably ruined your nav unit.
03-18-2006, 10:47 AM | #3 |
Member#: 88086
i didnt remove the thing on the wire that said not to remove it lol
03-18-2006, 11:07 AM | #4 |
Member#: 83865
Vehicle:2005 Saab 9-2X Aero Midnight Blue |
I have had my 5495 hooked up since Aug, and have not hooked up the speed sensor wire.
My nav is right on (as i'm passing a street in the car, it shows me passing the street on the nav) Some say that it 'improves' accuracy, but its not really necessary when selective availability is set to 0 (this means the gps system is as accurate as it gets w/o using dgps, 10m) |
03-18-2006, 11:28 AM | #5 |
Member#: 88086
^^ Thanks for the input, but whenever you go to the navi screen, does it say "check speed pulse" on top?
03-18-2006, 07:14 PM | #6 | |
Member#: 104420
SCIC
Vehicle:05 GarageTuningSTI BLK/Gold 519hp@23psi |
03-19-2006, 12:20 AM | #7 |
Member#: 88086
I am going to try again tmrw using this wire behind the gauges. I think I tapped into the wrong one...
03-19-2006, 12:48 AM | #8 | |
Member#: 83865
No, it doesnt say 'check speed pulse'. If I hit the 'info' screen, and look at the speed pulse though, it say 'no' or 'off' or something. |
03-19-2006, 12:56 AM | #9 |
Member#: 88086
thats strange, even though my speed wire inst hooked up it still gives me the speed.
03-19-2006, 10:35 PM | #10 |
Member#: 51692
SCIC
speed by gps.
03-20-2006, 04:22 PM | #11 | |
Member#: 83865
Right. SOG = Speed over Ground, or GPS calculated speed. |
Speed Sensor Wire On 2006 STI | Bennett | Car Audio, Video & Security | 21 | 10-12-2006 10:54 AM |
Speed Sensor and Cluster wiring on 98 Impreza | TwoFive | Electrical & Lighting | 2 | 07-18-2006 08:32 PM |
Speed sensor wire / Wiring on AVN5435 | essteaeye | Electrical & Lighting | 1 | 03-18-2006 12:11 AM |
Vehicle Speed Sensor - 2 wire MY98 | kingsubi | Private 'Wanted' Classifieds | 1 | 01-06-2005 05:32 PM |
Need help identifiying speed sensor wire on harness | roybfr | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 1 | 03-05-2004 09:41 PM |
