Tire & Wheel Forum sponsored by The Tire Rack |
11-25-2013, 10:47 AM | #2551 |
Member#: 321857
245 max MIGHT work, but 255 or 265 I doubt it. Just roll your fenders.
11-25-2013, 11:11 AM | #2552 | |
Member#: 311911
SCIC
Vehicle:2012 WRX Limited Sdn SWP (TP Stg 2) |
http://forums.nasioc.com/forums/show....php?t=2456768 Check out my build thread...the black xxr's have 245/40's and the gold DPT's have 235/40 federals...this will give you an IDEA of how the car will look with 8.5" rims and those tires If this doesn't help I don't know what will haha!! |
11-25-2013, 04:48 PM | #2553 | |
Member#: 369128
E. Canada
Vehicle:2014 STI Tsurugi Satin White Pearl |
I was talking to the guys at wheeldude.com and they said a 255/35 will fit on my car with those rims. |
11-25-2013, 04:57 PM | #2554 |
Member#: 321857
Good luck...
11-25-2013, 05:44 PM | #2555 |
Member#: 97135
NWIC
11-25-2013, 06:51 PM | #2556 |
Member#: 369128
E. Canada
lol according to the answers ive been getting in this thread there is no way to go wider ( wheel and tire) without doing a roll/pull...there has to be someone on here thats running a different wheel/tire setup on stock!
11-25-2013, 07:26 PM | #2557 |
Member#: 351622
South East
Vehicle:2013 Wrx White |
245 40 18s on a 18x9 +35 slight roll in the rear only because I usually have about 400lbs in my trunk
11-25-2013, 07:47 PM | #2558 | |
Member#: 369128
E. Canada
i wanted to go wider to a 255 which is 9mm wider than the 245 according to tire racks chart ....so if i take the stock offset and subtract the tire width (which should be half of 9mm for both sides) and then add the offset of the grids(44) (55-44+4.5=6.5) so from what i got from this it will be 6.5mm further out than stock and i thought i read somewhere that there is 9mm to play with between the stock rim/tire and the fender. but if i run grids i have to run 5mm spacers in the front right? |
11-25-2013, 08:02 PM | #2559 | |
Member#: 351622
South East
11-25-2013, 08:03 PM | #2560 |
Member#: 351622
South East
Also you have more fender clearance In the front over the rear. I would go with a 245 still looks square with just a bit of stretch to help with rubbing
11-25-2013, 08:19 PM | #2561 |
Member#: 250556
Vehicle:2018 wrx limited wr blue |
I'm sure this has been covered but there is 103 pages to filter through. Looking to go 18x8 +48. 235/40/18 on a stock suspension 2011 wax sedan will the 5mm lower offset on the same width rim have adverse effects? Fender rolling?
11-25-2013, 08:21 PM | #2562 |
Member#: 351622
South East
You will be fine no rolling should be needed
11-25-2013, 08:30 PM | #2563 |
Member#: 369128
E. Canada
11-25-2013, 09:44 PM | #2564 |
Member#: 97135
NWIC
i dont think the 8.5 grids require spacers.
11-25-2013, 09:45 PM | #2565 |
Member#: 351622
South East
11-25-2013, 10:00 PM | #2566 |
Member#: 369128
E. Canada
11-25-2013, 10:21 PM | #2567 |
Member#: 351622
South East
11-25-2013, 10:25 PM | #2568 |
Member#: 97135
NWIC
a 255 really belongs on a 9" wheel.
11-25-2013, 10:31 PM | #2569 |
Member#: 369128
E. Canada
yeah i was kind of hoping not to hear that. soo no 255 i should just go with the 18x8.5 with 245s then. any other advice before i order this stuff?
11-26-2013, 09:31 AM | #2570 |
Member#: 351622
South East
11-26-2013, 01:28 PM | #2571 | |
Member#: 347674
South East
Vehicle:2017 STi CWP |
11-26-2013, 01:57 PM | #2572 |
Member#: 97135
NWIC
11-26-2013, 02:13 PM | #2573 |
Member#: 369128
E. Canada
11-26-2013, 02:46 PM | #2574 |
Member#: 97135
NWIC
11-26-2013, 03:35 PM | #2575 |
Member#: 369128
E. Canada
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L | acetmi | Private 'Wanted' Classifieds | 0 | 06-14-2006 12:43 PM |
need somewhere to get wheels and tires asap | bubba03wrx | Southern California Impreza Club Forum -- SCIC | 22 | 04-02-2004 09:14 PM |
Wider wheels and tires in the rear | SilveRexy03 | Tire & Wheel | 14 | 11-04-2003 04:49 PM |
WEre is a good place to buy wheels and tires | MilfordSubaru | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 05-25-2002 01:14 PM |
Where to buy wheels and tires? | wilddave1 | Brakes, Steering & Suspension | 4 | 03-21-2002 02:20 PM |
