10-22-2008, 10:33 PM | #551 |
Member#: 147839
Vehicle:'03 SRP WRX '17 NGM SS |
I'm sure this has been brought up before, but I just downloaded the A4SGE01C firmware, and the .hex file is only 160KB. Isn't it supposed to be 192KB?
10-23-2008, 03:52 AM | #552 |
Member#: 188582
You have a virus on your ecu!!! You are screwed, your programs are all hacked and you are going to destroy your car if you hock your computer up to it again.
Lol, jk. gotcha. |
10-23-2008, 06:49 AM | #553 |
Member#: 156973
International
Vehicle:2002 ADM WRX STi STi Black/Blue |
It can be either 160kb or 192kb in size - but for patching it needs to be 192kb. You can change the size using ecuedit.
10-23-2008, 08:08 AM | #554 |
Member#: 11205
Vehicle:2015 WRX WRB |
10-23-2008, 09:57 AM | #555 |
Member#: 109623
Vehicle:'16 Fiesta '16 FZ-07 |
Im completely lost on how to patch this in. Anyone willing to help me?
10-23-2008, 01:41 PM | #556 | |
Member#: 188582
JK The hardest part for me was editing the subie file for ecuflash. Finding the correct file for your ecu in the program file folders of ecuflash and then finding a program that will let you open them and edit them ( pasting in the new lines of code ) and then resaving it back into the program files, took me a while but i found out how. What is your problem exactly? No idea where to start? read the "read me file" it helps, but is written in comperter savy speak, so it might be difficult to understand if you have no idea about that stuff Here are the keys- getting the map patched, getting the definitions the change the factors into ecuflash ( so you can edit the LC values ) here is a jist of what i did- hope this helps MAKE SURE YOUR rom FILE IS 192KB first [size=3]Getting the map patched - 1. put the .hex file of your map into the folder with the patching files ( unzipped) 2. click on patch (wind Last edited by 4cams4life; 10-23-2008 at 03:10 PM. |
10-23-2008, 01:53 PM | #557 |
Member#: 188582
more help
double post, opse...
10-23-2008, 01:56 PM | #558 |
Member#: 70395
Where did you download it from?I have EcuEdit so maybe what I can do just upload some 192kb files to OpenEcu for people to use for launch control.EcuEdit has the ability to change the ROM size.
10-23-2008, 02:09 PM | #559 | |
Member#: 17355
http://www.epifansoft.com/phpBB2/index.php |
10-23-2008, 02:15 PM | #560 | |
Member#: 70395
10-23-2008, 02:36 PM | #561 | |
Member#: 70395
10-23-2008, 02:41 PM | #562 | |
Member#: 70395
10-23-2008, 02:45 PM | #563 |
Member#: 109623
Thanks 4 cams. It would be the computer savvy speak that gets me. Hahahaha.
I has less than l33t skills. |
10-23-2008, 02:59 PM | #564 |
Member#: 188582
10-23-2008, 05:37 PM | #565 |
Member#: 70395
10-23-2008, 07:30 PM | #566 |
Member#: 188582
hey my old post got like chopped, wtf happened?
10-23-2008, 07:37 PM | #567 | |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
This patch needs an OEM rom, which I downloaded from openecu and applied the patch without a problem. I just finished copying over the tables from my old ROM, so I'll flash it to the car and try out LC at some point. |
10-30-2008, 10:21 PM | #568 | |
Member#: 139955
Vehicle:2015 Subaru STI 17Forester / 18Crosstrek |
11-11-2008, 08:44 PM | #569 |
Member#: 139955
Ok got LC working on my car again.
Only issue is the revs "bounce" really slow. How do I speed this up? |
11-11-2008, 09:42 PM | #570 |
Member#: 159682
Vehicle:1995 WRX 2015 F150 |
11-12-2008, 03:58 AM | #571 |
Member#: 156973
International
11-12-2008, 04:01 PM | #572 |
Member#: 43088
Vehicle:00 Impreza silver |
I set mine to 10rpm !
It works great ! |
11-12-2008, 06:44 PM | #573 |
Member#: 156973
International
np. I tried 10rpm difference, but it produced 2psi less - just remember to log it to check you get the best results - even though it sounds better and doesn't drop as far, it doesn't always mean it will perform better
11-13-2008, 04:26 AM | #574 |
Member#: 43088
Yep, but it bounce faster with 10 rpm, isn't it ?
11-13-2008, 08:24 AM | #575 |
Member#: 156973
International
yes, but have you logged to see if it makes more boost when it bounces faster?
When I lgged, I tried everything from oem difference to 5rpm difference, and 50rpm was the sweet spot for making the most boost under LC conditions. It may be different for you - which is why I'd log it to see how much boost you make under LC. Try several differences, ranging from 5rpm to 100rpm and see which one makes the most boost |
Similar Threads | ||||
Launch Control on 2004 WRX | Doomsti | AccessPort | 18 | 11-16-2012 03:16 PM |
Launch Control on 32bit ECU | Nuke209 | Open Source Reflashes | 126 | 05-17-2008 10:49 AM |
Help with wiring in launch control on an 05 WRX. | Sir Wagon | UTEC | 2 | 03-07-2008 04:45 PM |
Failed NY state Inspection because of Launch Control on UTEC? | vipernj | Engine Management & Tuning | 2 | 01-24-2006 06:10 PM |
utec remote switch launch control on 4eat | topgrinder | Engine Management & Tuning | 1 | 03-27-2003 08:34 PM |
