Brakes & Suspension Forum sponsored by The Tire Rack |
12-31-2012, 10:42 AM | #4526 | |
Member#: 173581
W. Canada
Vehicle:09 WRX SWP |
Just buy them...You'll not regret it!
01-02-2013, 06:03 PM | #4527 | |
Member#: 171948
Vehicle:19 Sti Crystal white |
01-16-2013, 12:48 PM | #4528 |
Member#: 219100
Vehicle:2014 STI hatchback Satin White Pearl |
If any of you guys are interested, I have my RCE Yellows for sale listed in the classifieds.
Edit: My used Yellows went to a good home. Last edited by QwaktastiK; 02-17-2013 at 09:31 AM. |
02-17-2013, 09:39 AM | #4529 |
Member#: 219100
Just wanted to give a shoutout for a great product from a great company. Also, updated pic below...
Here's the best shot I've gotten of my stance: image by QwaktastiK, on Flickr And for reference, below is the list of suspension components and wheel/tire specs. I opted for taller tires to get rid of some of the tire to fender gap. If you desire more clearance, just stick with a rolling diameter closer to stock. Suspension: GTWORX/Bilstein Impreza Cup Sport Kit RCE Black (Regular Guy) Springs RCE Camber Plates (front) RCE 25mm Hollow adj. Front Sway Bar RCE 25mm Hollow adj. Rear Sway Bar Kartboy Front and Rear Endlinks Whiteline Rear Camber Adjuster Kit Whiteline Rear Trailing Arm Bushings Whiteline Front Inner Control Arm Bushings Wihteline Anti-Lift Kit Whiteline Steering Rack Bushings Whiteline Front Differential Positive Power Kit GTSPEC Strut Bar Alignment Specs: Camber: -2.0f, -2.0r Toe: 0 Caster: 6.5 Winter Wheels/Tires: XXR 527 17x8.25 +25 (Gold) Bridgestone Blizzak WS70 215/50/17 Last edited by QwaktastiK; 02-17-2013 at 09:46 AM. |
02-17-2013, 10:11 AM | #4530 |
Member#: 20952
Vehicle:BRZ & Datsun White & White |
That looks really good! One of the best looking 08+ WRXs I've seen.
- drew |
02-22-2013, 09:18 PM | #4531 |
Member#: 171948
qwak, the car looks great. i cant wait to get my camber plates on come springtime! mine will be a tad higher with the yellows. im gonna stick with them for now and see what i think with the plates.
03-15-2013, 12:12 PM | #4532 |
Member#: 208185
Vehicle:2009 WRX 5-door Dark Gray Metallic |
Just got my Bilstein + RCE black's installed! Is this the best place to post a review+pics? Where would it be most helpful?
As a heads up, I couldn't be more happy, excited, impressed....with the set-up. Thanks Myles, and everyone else who was able to make this a reality! |
03-15-2013, 12:39 PM | #4533 |
Member#: 306478
South East
Vehicle:2016 Focus RS stock |
Gratz! I was waiting for that but got Impatient and went with yellows and koni inserts and 08 struts upfront. It's an amazing transformation isn't it.
03-15-2013, 12:47 PM | #4534 | |
Member#: 54202
Vehicle:ASK ABOUT NEW RCE SWAY BARS FOR STI |
Myles |
03-15-2013, 01:16 PM | #4535 |
Member#: 34773
South East
Vehicle:2013 WRX STi SWP |
If anyone wants I set I have some for sale. To bad they wont work on a STi, cause I loved mine
03-15-2013, 10:13 PM | #4536 |
Member#: 208185
Bilstein + RCE black suspension review
* Please share this, or recommend a more appropriate location for this review. This forum has been incredibly helpful for me over the years, and I'd like this information to reach as many relevant people as possible - Thanks!*
I wanted to return the favor to the forum community and give my opinion on the Bilstein + RCE black guy suspension I just installed. The following notes are from a variety of road conditions and speeds over a total of only 85 miles. I will be sure to adjust my impressions as miles are added, but have driven so many types of surfaces and speeds today, I am confident enough to write up this post. Installed suspension components already on car: - 24 mm whiteline adjustable swaybar (soft setting) - 22 mm whiteline adjustable swaybar (middle setting) - Kartboy endlinks F+R - Group N/ STI Tranny and Engine mounts - TIC tranny crossmember mounts - Whiteline rear diff mounts - Whiteline rear subframe inserts - Whiteline steering rack bushing Wheels + Tires: - 18x8 +48 Enkei Raijin in Graphite - 235 40 ZR 18 Michelin Pilot Super Sports Installation. I installed the suspension myself along with my brother and his roommate. It was very challenging to get the old rears out, as well as the new ones re-installed. Switching over the top hats was pretty easy. Borrowed a set of spring compressors from Advanced Auto. With the car already on jack stands and wheels off due to regular maintenance work, it took about 3 hours for the suspension-done by complete novice people. I have experience working on cars, but have never done suspension. Everything was torqued to specs noted in installation guide without issue. Alignment scheduled for Wednesday. Driving Performance. Wow. I have nothing but good things to say. Let me go through this in a somewhat structured manner. I have taken my brother and friends along for rides after the install and will try my best to capture their impressions in addition to mine. Keep in mind, I have no real understanding of the mechanics involved - I am merely describing my thoughts and perceptions. I don't mean to refer to things incorrectly. First off, the car feels "substantial." It has a weighted, solid feel about it. The car follows the road. Bumps are hit without drama. There is minimal rebound. I was expecting more vibration, creaking, and squeaking from a stiffer suspension. This was not the case. The car is noticeably quieter. There seems to be less flex transferred to the chassis. The suspension is taking full responsibility for the road's misfortunes. The ride isn't "harsher" per say, but it is more honest. The bumps are more pronounced, but there are no negative side effects. I cannot get over the solid, perfectly weighted feeling of the car. Previously, correcting or adjusting steering midterm was a dangerous, cumbersome event. Now, the car responds without argument to greater, or lesser, turn in regardless of speed or turning angle. It is so compliant. There is no sway in the body at all. The car stays exceptionally flat. In the past, a bump in the middle of the turn would propel the car into the air, and it would jump, landing on edge. It was unnerving. For such a "firm" and hard hitting stock suspension, the car was miserable at keeping contact. No more. The suspension is in contact all the time. It is amazing to me the difference. It feels like an entirely different chassis. The car has transformed itself. My dad has a 2011 Audi S4. I'm not going to claim this car feels like and S4. But, it feels like an S4 had a crazy night with a WRX. The feel over bumps and composure in turns is really incredible to experience in a dramatically more accessible (financially) package. (I realize these are very different cars for different buyers). My main point here is that this car feels much more dynamic, composed, and substantial than one would ever imagine. Appearance. The drop is perfect. Anymore, and I would have serious concerns with ground clearance and scraping of the tires. The Perrin exhaust hangs a bit lower than stock by the axle and scares me. I, unfortunately, have no measurements. The rear is mounted on the setting 2nd from top (1 above middle). It has leveled out the stance and wheel gap between the front and rear perfectly, which really adds to the beauty. I could not be more happy with the look and stance. It is a perfect combo of drop, stance, and spacing. IN SUMMARY. This suspension has no downsides. It is honestly more comfortable, safer, higher performing***8230;you name it. It is incredible. I have had the luxury to drive in a variety of Porsches' from various decades (2001 Boxster S, 2006 Porsche 911 S, 1995 Carrera 4 to name a few), Audi's, BMW's, Honda S2K's***8230;..enough to have a dose of good and bad handling and riding cars. I can say that this is one of the most balanced (in terms of comfort and performance), rides I have rode in. This car drives on everything from route 1 out of Boston, Pennsylvania turnpike, to gravel roads in NH. As a performance minded daily driver - I cannot think of a better suspension set-up. I have been waiting for 11 months to get my hands on these. I can say with full confidence that it was worth that wait. I am still in the honeymoon phase (as I'm sure is evident) but, it feels Like I have a completely new, revived, reincarnation of my car. A huge thanks to Myles, RCE, and Bilstein for your relentless effort, talent, and great quality products. Enjoy the pictures! [IMG] _DSC0170 by David Burbank, on Flickr[/IMG] [IMG] _DSC0157 by David Burbank, on Flickr[/IMG] [IMG] _DSC0163 by David Burbank, on Flickr[/IMG] [IMG] _DSC0166 by David Burbank, on Flickr[/IMG] Last edited by stoker68; 03-15-2013 at 11:20 PM. Reason: spelling/grammar |
03-17-2013, 12:10 PM | #4537 |
Member#: 234357
Vehicle:2009 WRX Sportwagen zum einbauen! |
Great review!
03-18-2013, 12:42 PM | #4538 |
Member#: 54202
yeah this suspension with Michelin Super Sports is pretty awesome !
good review ! Myles |
03-18-2013, 09:32 PM | #4539 |
Member#: 219100
Great review and great pics.
03-19-2013, 11:28 AM | #4540 |
Member#: 208185
Glad You guys appreciate it! I have put a couple hundred miles on now and have an alignment scheduled for tomorrow morning.
I read through my review and my impressions haven't changed. I may have to get the rears rolled (not that it's an issue right now, but it would make me feel a bit more comfortable). If anyone knows a good place to do that north of Boston, that would be awesome. |
03-19-2013, 10:00 PM | #4541 | |
Member#: 212389
Vehicle:2009 WRX 5-door DGM |
PSS + Bilsteins (yellows) + camber plates + sways/endlinks + some bushings = MUCH better behaved when pushed. Little rough for my commute, but it's worth it for those few days I get to play. Find ye salvation at RCE! |
06-16-2013, 11:31 AM | #4542 |
Member#: 27021
Vehicle:2015 WRX |
Update:
I've been running the Bilsteins + RCE Yellows since they first came out. Last weekend, I added the Whiteline Com-C strut tops, which are FINALLY available! Wow, what a difference! The steering is way more responsive and front end bounce is greatly reduced, with little added harshness. These tops use a hardened Group-N type bushing. They are not adjustable per se, but they use an offset to add negative camber and some additional caster. With factory camber bolts, I was able to get -2.0 in the front with 7 degrees of caster (I do have an ALK). Before the Com-Cs, I couldn't get more than -1.2 or so in the front with the factory bolts. In summary, the Com-Cs are a good deal for the money and really complete the Bilstein/RCE package nicely. |
06-17-2013, 08:03 PM | #4543 |
Member#: 234357
I'll have to remember that...
08-15-2013, 01:16 PM | #4544 | |
Ethon
Member#: 221885
Vehicle:2050 Ivory Tower Ivory...duh |
So, it has been a couple years since I have been to this thread and thought I would update. After 70,000 miles on the struts/dampers I have had zero problems. Other than an endlink that gave up for unrelated reasons there has been no appreciable change in performance and zero problems. Thanks for a great set it and forget it setup Myles. Last edited by etothen; 08-15-2013 at 01:49 PM. |
08-15-2013, 01:59 PM | #4545 |
Member#: 54202
We are in the preliminary stages of development of a solution for this.
while thats super vague....thats all I can say. I find it interesting that the rear OEM mounts failed/popped out after 75k..... If I understood you correctly? Myles |
08-16-2013, 01:14 AM | #4546 |
Member#: 234357
I think he was refering to a swaybar endlink...?
08-16-2013, 04:07 PM | #4547 |
Member#: 54202
08-17-2013, 11:01 AM | #4548 |
Member#: 234357
Bah, I'm just guessing, seems somewhat logical.
HOWEVER. What are you working on that is a solution to what??! |
09-02-2013, 06:13 PM | #4549 |
Member#: 341137
RMIC
Vehicle:2009 WRX Silver |
I have an 09 wrx an it's my DD. what should I get if I want a lower ride and reliable set up?
10-02-2013, 07:09 PM | #4550 | |
Member#: 259919
SCIC
Vehicle:2011 WRX Hatchback SWP |
Setup For Sale
http://forums.nasioc.com/forums/show....php?t=2556586 |
Similar Threads | ||||
09-10 specific Eibach Springs | ...cAs... | Brakes, Steering & Suspension | 0 | 04-02-2010 11:29 PM |
How About Getting Some RCE Wagon Springs Made? (Gauging Interest Thread) | hklatte | Brakes, Steering & Suspension | 77 | 11-19-2009 02:36 PM |
FS SD : 08/09 WRX hatch turboback custom made 4 rally $250 and more | ricepapertiger | SCIC Private Classifieds | 8 | 10-15-2009 03:34 AM |
foooooood... lets get some fooooood | nateconnella | North West Impreza Club Forum -- NWIC | 18 | 04-09-2003 06:33 PM |
LI meet! Lets get some ideas here. | Keith | General Forum Archive | 31 | 07-11-2000 07:15 PM |
