10-31-2008, 11:47 PM | #1 |
Member#: 186861
SCIC
Vehicle:03 BMW 325i Deep Blue |
TD04 turbo on a 00RS
A buddy of mine will be selling his TD04 turbo along with the TMIC, My question is would i be able to do a direct bolt on to my 2000 RS, and if that is possible what would i need to buy and do to my subie? anyone that could answer my question can you please PM me or let me know on this thread. Any feedback would be greatly appreciated... Thanx
Albert
11-01-2008, 02:45 AM | #2 |
Member#: 36318
Vehicle:2002 wrx sold :( |
i think you posted on the wrong forum. try the naturally aspirated with bolt on turbo forum. and to answer your question in short, no its not a direct bolt on. you will need alot of other parts from the wrx.
11-01-2008, 02:55 AM | #3 |
Member#: 157692
Vehicle:2004 WRX "Big Red" |
If I had a nickel for every time....
11-02-2008, 01:39 AM | #4 |
Member#: 186861
SCIC
11-02-2008, 01:41 AM | #5 |
Member#: 186861
SCIC
I'm aware i posted on the wrong forum... I just need a solid answer the feed back I'm getting.... Not helping>>>>
11-02-2008, 02:00 AM | #6 |
Member#: 142345
Vehicle:2002 WRX 34'd WRB |
a solid answer is its not worth it. Your going to need a lot of extra parts and you will most likely severely cut the life of your engine. If you want to do it to see what it can do untill you drop another motor in there go for it but dont bank on longevity or power.
11-02-2008, 03:21 AM | #7 |
Member#: 154175
Vehicle:07 Impreza Wagon 2.5i??? |
just bolt the turbo onto the search button, and you will gain about 50 knowledge power...
11-02-2008, 03:22 AM | #8 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
11-02-2008, 11:34 AM | #9 |
Member#: 186861
SCIC
11-02-2008, 11:37 AM | #10 |
Member#: 137398
E. Canada
Vehicle:2004 Impreza |
This thread and OP fails.
11-02-2008, 12:00 PM | #11 |
Member#: 157692
FAIL!
Well, heres you're lovely answer. The bare minimum you will need to turbo an N/A RS is going to cost you atleast two grand. Bare minimum is like Up pipe Downpipe Exhaust manifold Injectors (STi 550cc yellows most likely) STi fuel pump or greater turbo (which you have) intercooler (which you have) EM, most likely Emanage ultimate (thats gonna cost you a handful right there) You will need to notch your cradle Stock BPV Boost gauge Wideband 02 with AFR gauge Turbo waterpump most likely heat shielding, relocating of the bell housing plugs Gaskets+ miscellaneous harnesses for EMU. There is a ton of things I am forgetting. I was gonna turbo my 96 L but decided to just buy a wrx. IF you did all of the work yourself, you are looking @ around 2,000 minimum, most likely closer to 3. If you are paying someone labor, look into getting a wrx. IMO, your car can sell for half the price of a wrx. Just come up with the rest of the cash. With the 3 grand for the turbo and your car, you are @ about the equivalent of a cheap wrx as it is. |
11-02-2008, 01:09 PM | #12 |
Member#: 124254
Vehicle:2006 06 SGM Slowbaru "The Scoobinator" |
11-02-2008, 06:06 PM | #13 |
Member#: 151079
Vehicle:2005 2.5RS RBP too many friction losses |
Just swap a turbo motor into your car. Turbo gc's are always nice.
11-03-2008, 04:27 PM | #14 |
Member#: 186861
SCIC
Yeah i just talked to a buddy of mine in Arizona that drives a GC and he told me that it is not worth the time and money to do a bolt on, So I'll prolly just go with a REX swap... I was trying to not spend so much money but it's worth the extra 3000 i was gonna save... Thanks
11-07-2008, 08:54 AM | #15 | |
Member#: 81633
Vehicle:'98 RS-T Blue |
If you can do the work yourself, you can achieve similar results. The biggest obstacles when adding a WRX turbo to a GC are modding the cross member, modding the up-pipe, and adding a WRX water pump. A little searching on this forum goes a long way. Last edited by 2milehi; 11-07-2008 at 11:24 AM. Reason: Added pic |
11-07-2008, 10:26 AM | #16 |
Member#: 156447
Vehicle:99 18g'd 2.5RS-T Black |
It is a HUGE amount of work having been there done that. I did alot more building than you plan on doing but unless you have alot of tools, wrenching experience, and time to reaseach everything then just buy a used wrx motor and swap it.
11-07-2008, 10:42 AM | #17 |
Member#: 168226
RMIC
Vehicle:2000 2.5RSti Coupe 02 Forester L |
mine ran 8.5 psi on the stock block for 2 years before a headgasket went- the easy way is to just do a swap, but if you want to be unique and give yourself a challenge, the rs-t is possible
11-08-2008, 03:11 AM | #18 | |
Member#: 186861
SCIC
This whole fourum site is for people to help you, wich makes no sence when you accidently post on the wrong fourum and they get all stupid... But whatever. THANKS to all those that took the time to help me. It's you guys that make me understand what makes a Subaru a Subaru...... |
11-08-2008, 09:47 AM | #19 |
Member#: 81633
^^^ Thanks for the complement. Just piece it together - it seems like you got a couple of parts already. It did mine in stages - First I added a WRX water pump when I replaced the timing belt. Then I notched the crossmember and welded in a support to make room for the up-pipe. That set the stage for adding the turbo stuff.
11-08-2008, 11:31 AM | #20 | ||
Member#: 36333
Vehicle:98 RS GT30R, closed deck madnes |
holly crap you got bashed hahaha Quote:
You can't go wrong for 600 bucks ! |
11-08-2008, 12:32 PM | #21 |
Member#: 81633
I am using the factory computer so no timing is being pulled out. I am not sure on which engine management upgrade to use but I probably will go MegaSquirt - I am just a little leary of tearing into the factory wiring. As for power, no guess but very noticeable improvement.
11-08-2008, 11:38 PM | #22 | |
Member#: 36333
do you have a knock sensor ? I would recomend the Emanage ultimate. Its definatly the best solution you can use without going full stand alone and NOT being able to pass inspection. |
11-09-2008, 06:57 AM | #23 | |
Member#: 81633
Where I am at, there aren't any emissions inspections. |
11-09-2008, 09:49 AM | #24 |
Member#: 157692
2MileHi's set up is definetly impressive, it was my intentions when I was planning my coupe turbo to model mine after his.
But with that being said, $600 is highly unlikely. In fact, this is the only time I've seen it done. Thats obviously with some talented fabrication skills. |
11-09-2008, 10:32 AM | #25 | ||
Member#: 36333
Similar Threads | ||||
TD04 Turbo on EJ25 SOHC? (non hybrid) | mikebontoft | Built Motor Discussion | 17 | 02-26-2010 12:32 AM |
TD04 Turbo on an '05 2.5RS? | JStoner33 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 11-10-2009 10:34 AM |
F/S: WRX TD04 turbo on e-bay | wrxtreme227 | Engine/Power/Exhaust | 2 | 08-21-2007 08:07 AM |
F/S: TD04 turbo on e-bay | crombiesux | Engine/Power/Exhaust | 5 | 08-07-2007 07:29 AM |
ha ha check this out - limited edition td04 turbo on ebay | anthonyrb98 | Off-Topic | 32 | 02-24-2006 10:07 PM |
