03-28-2005, 08:36 PM | #1 |
Member#: 60224
Swap underway, need sway-bar help…
I’m right in the middle of my WRX swap and found my stock Legacy sway-bar mounts will not work with my v6 cross-member. My turbo cross-member appears to require mounts which use some kind of locking tab & slot with only one bolt as opposed to my stock two bolt clamp style mounts. Is this a WRX mount that I need or something different?
I’m thinking I’ll need both mount and bushings but need to know from what donor vehicle to obtain them… Thanks in advance and all comments appreciated…
03-29-2005, 11:45 AM | #2 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
Those mounts are the same on all the early Legacies and GC Imprezas. Should be pretty easy to come by at the dealer. I may have a spare set I could sell you. Price them out new at the dealer and then PM me a reasonable offer...
03-29-2005, 12:05 PM | #3 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
lock and tab is confusing me ? i used a wrx stock front and my 1.8 end links |
03-29-2005, 08:13 PM | #4 |
Member#: 60224
Got some pics...
Here is my v6 sti crossmember sway-bar bracket mounting point: And here is my stock NA crossmember sway-bar bracket mounting point: As you can see the v6 sti crossmember takes a different kind of mounting bracket. Matt: Thanks for the details, I'll looking into the early Legacy's and GC Impreza mounts... |
03-29-2005, 11:06 PM | #5 |
Member#: 62747
Vehicle:1998 Impreza L Red |
you should just pick up some WX brackets and maybe sway bar as well....I'm not sure what size your sway bar is but I believe the stock WRX sway bar is 18 mm...This is what I did with my Imprez L swap and everything fits well.
03-29-2005, 11:25 PM | #6 |
Member#: 41626
NWIC
Vehicle:SPB We make people quit teh internet |
They are the exact same as my rs brackets....which are now on a turbo legacy x member....all you need if you want to re-use your old bar is the new brackets and the appropriately sized bushings for the bar.
Sway Bar Help Needed!! | Superorb | Brakes, Steering & Suspension | 18 | 04-28-2007 11:18 PM |
Need Front Sway Bar Help Quick Like!!! | YourMother'sLover | Brakes, Steering & Suspension | 6 | 10-11-2005 12:13 PM |
Need Front Sway Bar Help Quick Like!!! | YourMother'sLover | Texas Impreza Club Forum -- TXIC | 4 | 05-01-2005 01:26 AM |
Help Needed Sway Bar | autoxdad | South East Region Forum | 22 | 03-04-2005 09:21 PM |
Sway bar help needed | JDMSubaru | Brakes, Steering & Suspension | 2 | 09-18-2003 08:47 PM |
