Brakes & Suspension Forum sponsored by The Tire Rack |
10-22-2002, 04:04 PM | #1 |
Member#: 15532
wheel expert needed on balancing
How much weight can you add to a wheel to balance it before it becomes excessive.......and now how about if that wheel was only 12.5 lbs to start with.
-Br I'll post my questionable dilema after I hear back from some of ya
10-23-2002, 02:25 AM | #2 |
Member#: 5132
Vehicle:95 BMW 330ti black |
Anything over 5 oz. or so. Not excessive, but means you've got a really bad balance problem.
Gary |
10-23-2002, 11:11 AM | #3 |
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 4362 |
we typically see no more than 2.5 ounces maybe 3.0 at the most
10-23-2002, 08:04 PM | #4 |
Member#: 15543
Vehicle:555 Having a Subaru shop means too many cars |
I have a side question.
When tires have that mark on them for alignment with the valve stem why dont they ever use it? Isnt the mark where the tire is lightened slightly in order to offset the extra weight or was someone pulling my chain? If that is correct then maybe they could remount the tire on the same wheel in a different position and fix the issue? |
10-24-2002, 12:03 AM | #5 |
Member#: 15532
What does that mean when 2.5+ ounces needs to be added to a wheel?? Something didnt set right in the process to make the wheel? I'm just down that I have 70 grams slapped to outward part of the rim on already light wheels(what I paid the $$ for)
k wahh time is off |
10-24-2002, 12:15 PM | #6 |
Member#: 26005
Vehicle:2003 wrx sonic yellow |
often the tire is as much to blame...you didn't indicate whether the wheel was balanced by itself, or if the installer rotated the tire on the wheel (just break it down on the machine and spin it, re-inflate it). always put the wheel that took a (relatively) large amount of weight on the right rear...
That little circle on the back? Wheel expert needed. | imprezkid | Tire & Wheel | 4 | 10-31-2007 01:24 PM |
ATTN: OT watch experts - need help on an Omega | PGT | Off-Topic | 21 | 10-14-2005 02:12 PM |
need expert info on motor | eatus ravenous | General Community | 0 | 06-09-2004 11:06 PM |
Need expert advise on problem!!! | rjhhockey1 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 03-23-2004 01:56 PM |
Need your expert advice...on stereo set up and exhaust!! | silver ghost | STi Forum Archive | 7 | 07-30-2003 07:29 PM |
