09-26-2007, 11:17 AM | #1 |
Member#: 103343
Vehicle:2004 2.5 Hybrid 6spd Rotated Manifold/35R |
18G and 20G owners need help w/ shifting
Hey guys,
I'm heading to ETown tonight, and was wondering if you guys can help me a bit. I was just wondering at what rpm range you guys shift at the track. I still have the stock 5spd and stock slipping clutch. I don't know what I am going to trap today. (My car is running on the 20G w/ external gate set up. ) I was thinking 1st till redline, 2nd and 3rd till about 6200's. My expectations w/ a slipping clutch w/out a launch, mid 13's at 106mph. What do you guys say?
09-26-2007, 11:18 AM | #2 |
Member#: 74792
VIC
post your dyno plot and we'll tell you where to shift
09-26-2007, 11:21 AM | #3 |
Member#: 47145
Vehicle:2012 Gas Saver |
you'll have to launch high to keep from bogging +5.5k. Not sure of your exact setup but for my car making peak hp at redline(& still making good torque as well), I'd shift at redline in every gear.
09-26-2007, 11:28 AM | #4 |
Member#: 103343
Let me post my detuned dyno plot. I was thinking to launch at about 5k. I have successfully launched well on 5k till I've decided to launce a bit more aggressively (close to 6k) and burned my clutch from slipping it too much. ARGH>
09-26-2007, 11:33 AM | #5 |
Member#: 103343
Here it is. 19psi DB 20G port&polish + all heat coatings tial 44mm EWG dumped externally tial BOV 850 pe injectors Walbro 93 oct tune stock tranny/ stock clutch (Slipping) Helix Downpipe HKS cat-back |
09-26-2007, 11:36 AM | #6 |
Member#: 47145
on 93octane you should be running 21-23psi depending on which intercooler you are running.
09-26-2007, 01:23 PM | #7 |
Member#: 103343
Perrin FMIC
09-26-2007, 01:54 PM | #8 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
Vehicle:98 2.5 RS 04 WRX |
Your horsepower stays pretty flat all the way till redline, could use some more boost though (I'd say no less than 23 psi with that FMIC and turbo). Don't shift until redline with the current tune. During drag racing the guy with the highest average horsepower wins
09-26-2007, 02:01 PM | #9 |
Member#: 88411
Vehicle:2002 PSM WRX Wagon slower than ever |
ha good ****. i ran a 13.8 with stage 2. if you dont break anything tranny, blow your clutch,ect. i think you can do better then mid 13s. good luck...
09-26-2007, 02:13 PM | #10 | |
Member#: 67182
Vehicle:2004 Subaru STi 11.0 @ 128mph - 93/Meth |
dude i would get that car checked out. look at the HUGE @$$ dip in the center of the RPM BAND. TIMING BEING PULLED!!!!! aka KNOCK!!!! not to mention look how choppy the whole thing is. get that thing checked out. |
09-26-2007, 02:32 PM | #11 |
Member#: 86628
Vehicle:2002 WRX EJ257 COBB Tuning Surgeline |
I'm running stock tranny and clutch on my Greddy 18G w/ 2.5L and I shift at redline. Since I still have the stock drivetrain I just eased off but I was trapping 113-115 consistently!
I did try launching around 5k in 1 run but it was useless, clutch just slipped in 1st and 2nd |
09-26-2007, 02:32 PM | #12 |
Member#: 126519
Vehicle:2002 WRX 18g 2.5l hybrid |
09-26-2007, 03:58 PM | #13 |
Member#: 103343
See~ I'm no expert in any kind of tuning. Basically you take the car to someone you think you can trust and have it tune. This is basically what happened to me. I don't know if timing is being pulled. I would expect my tuner to tell me this and say, hey listen this is what's going on w/ your ride.
I guess I got to talk to my tuner. |
09-26-2007, 05:31 PM | #14 | |
Member#: 149426
Vehicle:2002 Subaru WRX 2005 Subaru STi & 2000 RS |
here: http://forums.nasioc.com/forums/show...ght=automaster |
09-26-2007, 05:36 PM | #15 | |
Member#: 144880
TXIC
Vehicle:03 Civic Rollin' hard... |
I ran a 13.27 @ 102 with a 2.0 60ft with the VF39 OTS map from cobb... you better be in mid 12's if u dont break a tranny first. 97subi... i see ur seeking a vf39... PM me.. I have your treasure. I'm now running an 18G and have no use for my 39 anymore Last edited by rhinotech; 09-26-2007 at 05:51 PM. Reason: type0 |
09-26-2007, 06:10 PM | #16 |
Member#: 101378
Vehicle:2022 Ioniq 5 SEL AWD Matte Baby |
Its really not that choppy, look at the smoothness correction, its only set at 1. Most graphs you look at are set between 3 and 5. And the "dip" would not look so terrible had the smoothness been set higher. Did Junior tune your car? If so then I really wouldn't worry about it too much, he does great work.
09-26-2007, 06:15 PM | #17 | |
Vendor
Member#: 155450
Vehicle:2007 FXT WRB |
09-26-2007, 06:34 PM | #18 |
Member#: 47145
09-27-2007, 12:59 AM | #19 |
Member#: 103343
I ran like crap. My clutch couldn't handle the launch. Tried at lower RPMs and bogged and gave up on the run.
Second attempt launched, bogged, clutch slipped, ran a bad 60' trapped 102 w/ a 13.82. I was shifting very slow, next week will try a different settings. I'll try w/ higher RPM launches w/ fast shifting. I think I'll be at high 12's. What bothers me the most is the previous tune done at "The Shop" my car came out w/ 347whp and 1 month later when I take my car to the Dynoday @ ICS it only ran 309whp. I will take my car to the track again and see if I can improve my time. After that is done I'll talk to my tuner. |
09-27-2007, 02:40 AM | #20 |
Member#: 78118
Vehicle:2002 Corvette coupe 05 Legacy |
that dyno sheet is alll farked up. those chops are REDICCCCCC!. timimg def was pulled at one point as you can see
09-27-2007, 08:36 AM | #21 | |
Member#: 85905
Vehicle:2004 WRX |
09-27-2007, 12:11 PM | #22 | ||
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
You will need to trap 104-106mph and hit at least a low 1.8 60' to get a 12.9. |
09-27-2007, 04:30 PM | #23 |
Member#: 103343
We'll have to wait and see next week. My shifting was not the greatest. will practice my launch and will shift faster next time. Hope my clutch will last.
09-27-2007, 05:25 PM | #24 | |
Member#: 149426
First off "the shops" dyno is jacked up big time, especially back when AL was tuning there. so you werent making 375whp . Second, your trap speed is not gonna change because you are not making the power you believe you are. thats why you are confused. its not the shifting or the launching, its the tuning and the car. |
09-27-2007, 06:04 PM | #25 |
Member#: 57882
Vehicle:2004 WRX WRB |
I do not understand why you are tracking the car when the clutch is slipping. Doesn't it just keep getting progressively worse over time, meaning that you cannot compare results?
FWIW, on my 18G setup I go to redline in 1st and 2nd. 6,750 in 3rd. |
Similar Threads | ||||
Finally New 18g and 20g Turbos for 08+ WRX and LGT | DS1 | Vendor Announcements | 6 | 10-17-2010 01:27 PM |
18G and 20G upgrade on VF turbos? | cmann14 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 12-03-2006 03:05 AM |
