02-16-2011, 11:26 AM | #1 |
Member#: 260545
Vehicle:2011 WRX Limited 4dr WRB |
WRX idle RPMs?
Can anyone tell me the approximate normal idle RPMs for a 2011 WRX running up to temperature?
Mine idles around 7-800 and tends to dip sometimes randomly as has been mentioned in other threads. This can make for a difficult first gear engage, as I either have to rev fairly high (2k) then back down onto the clutch, or struggle to not stall while the clutch engages (feels like the throttle response is really slow).
02-18-2011, 07:41 PM | #2 |
Member#: 171948
Vehicle:19 Sti Crystal white |
mine was about 7-800 too. after i got my accessport i raised the idle 200 rpms. it can be adjusted with ac on and ac off up to 300 rpms difference. i love that feature of the accessport.
02-20-2011, 01:54 AM | #3 | |
Member#: 265047
Vehicle:2011 STI |
03-17-2011, 11:52 PM | #4 |
Member#: 269191
TXIC
Vehicle:2011 Impreza WRX WRB |
03-18-2011, 01:45 PM | #5 |
Member#: 243663
SCIC
Vehicle:2011 WRX Sedan Black |
03-19-2011, 12:41 AM | #6 |
Member#: 269191
TXIC
Well I did some googling and found that the reason can be because of:
Big stereo or aux lights that may need the extra revs to keep power flowing. When starting the car the engine warms up faster Some people have a rough idle, so it'll even that out. Other than that I figured it might give an advantage on launching but I could be wrong. The cons though are that the engine will produce more heat on idle than normal and gas will be a factor. Would anyone else care to give there thoughts and experiance on this matter? |
03-30-2011, 05:15 AM | #7 |
Member#: 256620
Vehicle:2014 WRX 4dr!! Satin White Pearl |
I know i have a 2010 but its the same car so I figured I'd ask here. When you guys start your car it idles at 700rpms right away? Or does it drop to that after idling for awhile?
03-30-2011, 01:06 PM | #8 |
Member#: 276780
BAIC
Vehicle:2016 STi Limited Dark Grey Metallic |
I have noticed upon first starting my car it will idle around 1500, then once the engine warms up it drops down to the 7-800 range
03-30-2011, 07:01 PM | #9 |
Member#: 256620
Similar Threads | ||||
'03 wrx idles high at 2k rpm. | guy_in_red_wrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 16 | 08-14-2021 07:57 PM |
02 wrx idling problem/throttle sticking during high rpms | rebel1988us | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 11-15-2008 10:04 PM |
High idle RPMs and throtlle blips when shifting | Holograph | Service & Maintenance | 9 | 09-19-2002 02:53 AM |
Idle RPMs? | willguidry | Normally Aspirated Powertrain | 12 | 03-28-2002 12:33 AM |
('93-'01) Lowering idle RPM? | tonytiger | Impreza Forum | 4 | 05-14-2001 02:34 PM |
