Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 04-18-2005, 02:20 PM   #1
dt311
Member#: 80478
02 WRX
Default need help with coolant line hook up
I am putting my engine back in my car and I was wondering if anybody had any diagrams of the coolant system. I have one connection that I don't know what gets hooked up to it. It is on the coolant line that runs from the water pump, then goes up bihind the timing belt cover, and then goes back towards the starter. It sits on top of the engine block and has a 1 1/2 inch nipple coming off of it. I know what the big pipe gets hooked up to, but can't find where the little nipple runs to.
Also if anyone has a front mount intercooler I think if you look back by the starter down by the engine block you should be able to see the black coolant pipe and that little nipple. If you can please let me know if you can see what it gets hooked up to.
Any help would be great so i can finally get my car running again.
Joe
dt311 is offline   Reply With Quote
Old 04-18-2005, 03:41 PM   #2
CirrusWRX
Member#: 17439
2010 WRX STI SE
Gray
A pic of somebody pointing to what you're describing could help a lot
Any access to a digicam?
CirrusWRX is offline   Reply With Quote
Old 04-18-2005, 04:36 PM   #3
Backsteer
Member#: 83304
03 WRX Sedan
WR Blue
Backsteer is offline   Reply With Quote
Old 04-18-2005, 05:01 PM   #4
dt311
Member#: 80478
02 WRX
yeah those help.
The pipe in the first link is the one that has the hose H607191 hooked to it. Now the question is where does that get hooked up to? Does it go to the throttle body?
Need help with coolant tgraci Newbies & FAQs 0 08-10-2009 01:31 PM
need help with fuel line setup bloopsta26 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 09-03-2008 10:15 PM
Need help with vac line... Strng1dah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-31-2007 01:12 AM
need help with coolant lines on a perrin rotated kit 03clipsegts Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 09-11-2007 12:29 PM
Help with coolant lines smacksube Normally Aspirated with bolt-on Forced Induction Powertrain 1 12-17-2002 10:03 PM
