Tire & Wheel Forum sponsored by The Tire Rack |
12-01-2013, 10:19 PM | #4276 |
Member#: 61950
Vehicle:2008 Outback big blue wagon |
12-03-2013, 06:12 PM | #4277 |
Member#: 375229
Vehicle:2006 impreza sti blue |
year: 2006
make: Subaru model: sti location: BEND, OR tires only or winter package: WINTER PACKAGE |
12-03-2013, 06:53 PM | #4278 |
Member#: 360019
Vehicle:2013 Wrx |
Damn none of my local suppliers can get the continental ewc. The one guy is going to try one more time tomo. I guess I'm going to get the general arctics instead if not the ewc. The prices he gave me for both mounted n balanced was $146/tire
12-04-2013, 12:03 PM | #4279 |
Member#: 44652
BAIC
Vehicle:16 Colorado diesel ATC Bobcat Pop-up |
Seriously, check the goodyear ultra grip ice. For me it was the same price as blizzak and ewc and boy, they are on par with the blizzak, better in some areas actually, less mush. Also better than the altimax for the same reasons plus better snow performance, mind you I didnt stud mine.
Finally started snowing and getting cold here, -3 this morn and snowed yesterday. I give the goodyears an A or A-. Very pleased with them. |
12-04-2013, 12:07 PM | #4280 |
Member#: 44652
BAIC
I would downsize to 16's and get 205 55 or whatever size is recommended by tirerack, maybe 215 55. They should have plenty of cheaper alloys that clear your brakes, you can just have them shipped mounted and balanced. Id go, in descending order, michelin Xi3, goodyear ultra grip ice, conti ewc, general altimax. Hopefully you can find rims that clear without buying rpf1's pr something. Otherwise, you might just throw 225 45's on your stocks and get aftermarket rims for summer instead
12-04-2013, 12:12 PM | #4281 |
Member#: 44652
BAIC
I would seek out the rim with an offset closer to the stock 53, otherwise, for my ex's '12, 215 55's were the size equivalent. The 205's will be just enough smaller to where youll notice a difference in appearance, cruising rpm, and mpg
12-04-2013, 12:16 PM | #4282 |
Member#: 278547
Vehicle:2005 STi OBP |
Hey folks, i drive a STi 05, and was wondering if mounting a set of tires 225/50R/17 on my stock GD BBS would be ok.
Before I had 225/45r/17. Btw I'm still running stock suspension. Any input will be appreciated. Last edited by ChrizTi; 12-04-2013 at 12:28 PM. |
12-04-2013, 08:42 PM | #4283 |
Member#: 44652
BAIC
Too tall, theyll fit on the wheels, but probably not your car. Run the sizes through the tire size calculator
12-04-2013, 09:28 PM | #4284 |
Member#: 362218
Vehicle:2013 WRX PBP |
ya, I was told the spedo would be off a few percent. I hope the mpgs won't be too bad....
12-04-2013, 10:41 PM | #4285 |
Member#: 278547
12-05-2013, 06:48 AM | #4286 |
Member#: 360019
Vehicle:2013 Wrx |
Ok done procrastinating! Ordering the general arctics at 8am today. I think he is charging me $155/tire mounted and balanced. I called around all my local suppliers and I got prices from $146-189/ tire.
How's $155 sound per tire mounted and balanced? Going with them because they're the only place that told me they can get them in the same day. |
12-05-2013, 09:44 AM | #4287 | |
Member#: 167544
Vehicle:'12 DGM STi sedan '14 Audi S6, '16 XC90 |
You'd be wise to get an alignment at the same time |
12-05-2013, 10:21 AM | #4288 |
Member#: 360019
Vehicle:2013 Wrx |
Yea I'm just going to wait untill spring to get an alignment with new wheels nd tires. I barely drive lol I just want snow tires just so I know I can go out if its bad weather
12-05-2013, 10:56 AM | #4289 | |
Member#: 375229
With summer tires when I bought it. |
12-05-2013, 11:42 AM | #4290 |
Member#: 44652
BAIC
I would still downsize at least to 17 myself. the price difference alone makes it a good choice. Besides, you want more sidewall ideally.
12-05-2013, 02:52 PM | #4291 |
Member#: 375386
Just got a new 2013 Sport Premium 5dr Impreza, and just had my first encounter with snow/ice in salt lake city (i have a steep driveway). Lesson learned, need some snow tires!
I see that tirerack's recommended winter package includes 15 inch tires and wheels. Since my car is 17 inch stock, should I be worried about going minus two for the winter? Thanks! |
12-05-2013, 05:26 PM | #4292 | |
Member#: 314375
Vehicle:2012 Impreza Sport Marine Blue Pearl |
12-05-2013, 08:42 PM | #4293 |
Member#: 360019
Vehicle:2013 Wrx |
General arctics installed!!!
12-06-2013, 12:01 PM | #4294 |
Member#: 375229
12-06-2013, 12:03 PM | #4295 |
Member#: 375229
12-06-2013, 12:40 PM | #4296 |
Member#: 44652
BAIC
Yeah, dunno what the offset is on those, but the closer to stock the better. You can go 205 50, 215 45, or 225 45. run the sizes through the tire calc to match the stock tire od as close as you can.
After 3 sets of various blizzaks, Ill never buy them again. Not bad, but overrated and others are just as good if not better for the same price. |
12-06-2013, 12:41 PM | #4297 |
Member#: 44652
BAIC
12-06-2013, 01:44 PM | #4298 | |
Member#: 360019
Vehicle:2013 Wrx |
We are supposed to get 1-2inches tonite with a mix of rain and sleet. So ill see how they do tonite on all surfaces. |
12-06-2013, 09:19 PM | #4299 |
Member#: 21542
BAIC
Vehicle:2011 Impreza 2.5i Dark Gray Metallic |
Has anyone experienced w/ Semperit Speed-Grip 2? It seems to be popular in Europe & Canada, but not in U.S. I searched but only found reviews of orig. Speed Grip & pretty old info.
12-07-2013, 08:25 AM | #4300 | |
Member#: 207528
Vehicle:2005 Legacy GT |
"7th: Semperit Speed Grip 2 Total: 44 / Dry: 5 / Wet: 6 / Snow: 8 / Rolling Resistance: 8 / Comfort: 7 / Noise: 7 / Wear: 3 Positive: A balanced winter tyre with short braking distances and balanced handling qualities, pleasant ride comfort, fuel efficient rolling resistance Negative: High wear, excessive price/performance ratio Overall: Recommended" http://www.tyrereviews.co.uk/Article...-Tyre-Test.htm |
Similar Threads | ||||
This here is the Android OS thread. All phones, news, general info welcome. | under pressure | Off-Topic | 10849 | 12-13-2011 10:10 PM |
WTB: Winter wheels/ or All season tires on wheels, or just all season tires! | Robstunner | MWSOC Private Classifieds | 0 | 10-29-2009 11:42 AM |
Winter Tires vs. All Season Tires | wrx425 | Tire & Wheel | 22 | 01-15-2009 11:34 PM |
same tire thread all around for AWD? | MystikalDawn | Newbies & FAQs | 6 | 10-15-2008 11:28 AM |
Anybody get tired of all your mods and go back to stock or somewhere in between?? | Farnsrocket | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 31 | 09-11-2007 10:06 PM |
