05-31-2011, 12:01 PM | #1 |
Member#: 112220
Vehicle:2011 WRX 5DR Premium DGM |
valve adjustment question
Can someone please explain to me why a valve adjustment would be quoted as costing $2300. Is it really that much in labor even if there is a few hundred in miscellaneous parts (gaskets, etc).
Also, why is this repair not covered under the SAS GOLD plan when everything under the sun is? I've researched my documentation for the SAS GOLD and it does not differentiate between a repair/adjustment -- seems like they are contradicting what was sold to avoild getting out of doing this costly 'repair.' I've been fighting with the dealer in trying to fix a P0304 code for a few months. First it was "caused by a bad plug" and it was cleared during my 90K. It came back a month later, now it was caused by the bad P2443 Secondary Air Valve that was replaced -- cleared, and now it's back a few days later.. This time they swapped injector 2/4 along with the coil packs to see if they could get the code moved -- it stayed, so now they're saying the car requires a $2300 valve adjustment to fix - which won't be covered. I'm about to take SOA to small claims on this one -- I feel like I'm getting jobbed. P0304 is a Cylinder 4 Misfire. Last edited by rkjunior; 05-31-2011 at 11:22 PM. |
05-31-2011, 01:43 PM | #2 |
Member#: 22825
Just as the name implies, "Valve Adjustment," is just that, an adjustment normally carried out in a maintenance routine.
At your mileage, this is wear and tear, normally not covered under a warranty unless specifically stated. Best to blow your engine to get it covered |
05-31-2011, 01:53 PM | #3 |
Member#: 112220
The website info for SAS GOLD clearly states that wear and tear is included.
http://www.subaru.com/finance-center...mparisons.html |
05-31-2011, 01:56 PM | #4 | |
Member#: 79805
TXIC
Vehicle:2011 Acura TSX 2.4 Blue |
2300 to do what? |
05-31-2011, 08:41 PM | #5 |
Member#: 49998
RMIC
Vehicle:2017 WRX MT6 WRB |
...the hell would you need to adjust valves on a car with hydraulic lifters for? Could be that you're misinterpreting their results? Maybe valve replacement is what they're talking about, as in one is damaged/warped/etc.
05-31-2011, 10:36 PM | #6 |
Member#: 112220
From the workorder:
"also recommend valve adjustment to correct misfire code P0304. Estimate for valve adjustment $2300+TAX". Wouldn't a compression/leak down test determine if the valve was out of adjustment? If one was warped/damaged, that wouldn't be an adjustment - a repair - and it would be covered, according to them. |
05-31-2011, 11:35 PM | #7 |
Member#: 24890
SCIC
Vehicle:2002 Jackwagon WRB GG |
I've had intermittent P0304 CELs from tight valves. Valve adjustment = pull the engine EJ205/257s use solid lifters
06-01-2011, 01:00 AM | #8 |
Member#: 112508
Thats because their $2300 repair is actually replacing the blown piston
06-01-2011, 10:13 AM | #9 |
Member#: 265606
lol, sorry to laugh but i like the last post and its probably true
and yeah, to adjust the valves requires changing the buckets and its a lot of work, but not $2300 either. Wicked M@ |
06-01-2011, 11:06 AM | #10 |
Member#: 132394
Vehicle:1.21 gigawatts? Lighting bolt power bitch |
try replacing the coilpack. i had a p0303 code, swapped 1/3 coilpacks and the code went away. but now i have a p0301 code. so basically the code followed the bad coilpack. try replacing the coilpack (100+ bucks) and see if it goes away
06-01-2011, 12:28 PM | #11 | |
Member#: 112220
What I don't understand is how you can recommend a valve adjustment BEFORE you do a compression and/or leakdown test. Its almost like they know if they do, and it comes back bad, they know they will have to cover it - which they don't want to do. Keep in mind, too, that the p0304 is very intermittent and not constant. If I clear it, it may not come back for a week or more.... Which is why I feel like they are going overboad and guessing on this. Could the knock sensor cause this? Last edited by rkjunior; 06-01-2011 at 12:38 PM. |
06-02-2011, 12:34 PM | #12 |
Member#: 112220
Anyone else fought with SOA regarding this? How about the P0304. Seems like going from the injector swap directly to the valve adjustment is overkill... Could anything else be causing it?
06-02-2011, 12:59 PM | #13 |
Member#: 21145
Vehicle:2002 Enemy of Aku |
If changing the plugs doesn't help
If swapping the igniters doesn't help Try this ... Change your gas station. I had this issue last year. It was a PITA trying to find the problem. I changed plugs, swapped plugs, swapped igniters, checked igniters, checked igniter connections, changed rear O2 sensor, and a bunch of other items. In my case, the issue always stayed w/ #2 cylinder. All of the above * could * be a cause of the P030X code. Lots of searching in NASIOC, IWSTI and other places. I logged every chenage, one by one, to track the issue to eliminate areas of possible trouble. Finally realized what conditions caused the code. I used to use the same gas station all the time with no problems. One day, the issue started without warning (don;t they always?), not long after filling up. Problem would either come and go OR come on for an extended period. Finally changed to a different gas station and after running a complete tank of fuel on the new stuff, problem went away on its own. I have not gone back to the old gas station and my problem has not returned. |
06-02-2011, 12:48 PM | #14 |
Member#: 133597
SCIC
I would demand a leakdown/compression test. Have them show you the #s too.
06-02-2011, 02:46 PM | #15 |
Member#: 112220
I may try that. Won't hurt.
Where is Cylinder 3 located on the engine? I may pull the plug and see what it looks like, too. |
06-02-2011, 02:53 PM | #16 |
Member#: 184619
Vehicle:2005 Impreza WRX STi PSM |
06-02-2011, 02:53 PM | #17 |
Member#: 267815
South East
Vehicle:Be in awe dont hate .) |
............................................facepa lm................................................ ......
06-02-2011, 03:01 PM | #18 | |
Member#: 112220
Thanks for trolling! :thumbsup: |
06-02-2011, 03:16 PM | #19 |
Member#: 267815
South East
^^^^^^^^^no prob son......tell mama ill be a little late this evening......lol......highschoolers tryin to build engines just reassures my position at the dealership......i love fixing your f-ups.....hahaha
06-02-2011, 03:26 PM | #20 |
Member#: 112220
maybe you could use some of that dealership knowledge and maybe lend some suggestions on what to do?
06-03-2011, 09:26 AM | #21 | |||
Member#: 21145
Swapping plugs/igniters is quick and easy and will tell you immediately if the part is bad or not becuase the problem will follow the part if the part is bad. |
06-02-2011, 03:37 PM | #22 |
Member#: 267815
South East
Sure........sounds like you need to have a good leakdown and cylinder compression test done. If valve adjustment is the culprit...a leakdown test will prove it. compresion test it....if its low.....pour some engine oil into cylinder(yes this will require some longass homeade type funnel), check compression again....if its good, problem is in the ring/piston area. PO304 is the worst code you can probaly get on a subaru as the #4 cylinder is the hottest/leanest cylinder in stock form. My #4 piston blew apart at 46000 miles on a all stock 04 STi. ALL STOCK!!!!! As far as testing the injectors and ign coils, theres no need to be swapping any parts, look in the service manual(if u dont have it.....get it) Its very easy to test with a common volt/multimeter. Ohm em out and compare to manual specs.
06-02-2011, 05:10 PM | #23 | |
Member#: 112220
Thank you. This is good information and is appreciated. Any idea what the numbers for the compression and leakdown test should look like? Does this $2300 quote for a damn valve adjustment sound right in the ballpark? Everyone seems to think it's very high. |
06-02-2011, 05:31 PM | #24 |
Member#: 267815
South East
Cold compression usually 110-130 +/- leakdown should be no more than 25% or so. When i built mine(04 STi wih ej257, forged pistons, oversized valves) I had a leakdown rate of 35% This was due to everything being brand new and cold as hell lol started her up, idled it for about 20 mins. Checked compression and leakdown. Comp was at 155 on all 4 cylinders, leakdown rate of 15%. People will tell you that a leakdown of more than 5% is a problem, that is not correct as sooooo many variables come into play such as oil temp, thickness, age. New parts or old etc... Im looking at the time charts now and complete valve adjustment is only a 4.8 hr job. At our $85 an hr rate, thatd be $408 plus any buckets that you may need. $36 per bucket. Worst case senario if you needed 16 buckets and 4.8 hrs labor is $984.00 $2300 is waaayyyyyy high!!!!!!!!!!!
06-03-2011, 10:12 AM | #25 |
Member#: 267815
South East
Alrighty samurai jackoff. .lol sounds like you need to go and help those auto zone boys change some wiperblades or something . lol If YOU want to work on YOUR car then YES you do NEED a service manual. If all your gonna do is swap parts and blame problems on faulty fuel, then i think you need to bring your problem cars to someone who KNOWS what they are doing.You can analyze the fuel for parts per water with a fuel analyzer and you can flawlessly repair problems time after time with the factory service manual that can be found online in cd format for very little cost, as it contains all the torque specs and parameter values for sensor/wiring tests. Or some people just have nothing better to do than make uneducated guesses and swap around parts , potentially creating new problems. hhhmmmmmmm what to do.........
Similar Threads | ||||
Valve Lash Adjustment Question/Issue on SOHC | wirolla | Normally Aspirated Powertrain | 10 | 05-25-2009 11:55 AM |
valve tick or valve adjust? | ali dashty | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 11-06-2008 06:15 PM |
EJ20 valve adjustment question | Loomin | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 08-30-2006 09:01 AM |
Cleaning now that heads are off? And Valve adjust question? | yebokmj | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 07-13-2003 05:44 AM |
Valve adjustment | Pinoy | Southern California Impreza Club Forum -- SCIC | 0 | 06-13-2001 10:42 AM |
