08-29-2006, 04:07 AM | #1 |
Member#: 118113
VIC
Vehicle:98' Stagea 260RS Autech Ver. |
EJ20 valve adjustment question
i have a ticking inside the engine. sounds like my valve(s) need some adjustment. are the valves adjustable like honda etc?? or are they hydraulic?
if they are hydraulic, how do i adjust them? What weight oil is everyone running?? Thanks!!!!!
08-29-2006, 04:58 AM | #2 |
Member#: 69071
Vehicle:2002 Stg2-WRX Wagon WRB & Dust |
Stock they are shim over bucket, at least the older ones are. To have the lash adjusted you have to change the shims. This can be done without removing the cams if you have the tool. I can get you the part number for the tool if you like but it's listed the the FSM which you should get before you start attempting any engine disassembly and modification. It's available online too.
08-30-2006, 04:33 AM | #3 |
Member#: 118113
VIC
does anybody elses EJ20 tick?
this sounds like a pain in the ass to do. my mechanic says its normal ticking but my friends wrx doesnt do it. |
08-30-2006, 06:31 AM | #4 |
Member#: 79859
South East
Vehicle:2002 384 whp 332.5 lbs |
When I first got my wrx I started noticing the ticking and was wondering the same thing. The guy at the dealer said it was OK and that wrx's do not need an adjustment like Hondas. More than likely what you are hearing is the injectors. If you ever my pinks they are louder. Your car should be fine.
08-30-2006, 08:37 AM | #5 |
Member#: 118209
Vehicle:2015 WRX Limitec |
I think most of them tick... It is heavily oil dependent. Go to a heavier oil and you won't notice it. Also I think adjusting them is on the service schedule, it was either 60000 or with the timing belt at 105k.
08-30-2006, 09:01 AM | #6 | |
Member#: 84181
NESIC
Vehicle:NASA #530 GTS2 |
Btw, mine has been ticking since the day i got it... so does my g/f's - its a boxer engine, heh. |
Valve Lash Adjustment Question/Issue on SOHC | wirolla | Normally Aspirated Powertrain | 10 | 05-25-2009 11:55 AM |
valve tick or valve adjust? | ali dashty | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 11-06-2008 06:15 PM |
WTB DEAD TD04, EJ20 rings, adjustable lateral links, VF34 low miles | cky211 | Private 'Wanted' Classifieds | 0 | 08-21-2007 03:46 AM |
Valve adjustment ej20 | riverwrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 11-22-2004 01:41 PM |
Cleaning now that heads are off? And Valve adjust question? | yebokmj | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 07-13-2003 05:44 AM |
