09-30-2013, 01:10 AM | #76 |
Member#: 356215
What brand external wastegate is that? That's a lot of work you're doing so good luck with the installs, hopefully everything goes smoothly.
09-30-2013, 01:58 AM | #77 |
Member#: 352498
NESIC
Vehicle:2008 Wrx 2.5L World Rally Blue |
Its a cx racing ewg. There were a few things that broke my balls but took care of them. I just got to do a quick retune of the boost and I'm going to tune my ignition advance a little bit.
09-30-2013, 02:41 AM | #78 |
Member#: 356215
Better boost control for sure specially on the vf and just the sound alone from that external waste gate will net you extra power on the butt dyno. Good luck with the tuning!
09-30-2013, 02:55 AM | #79 |
Member#: 352498
NESIC
Thanks man and the boost is why I did it. I felt like with the ewg I could get more out of it the iwg is just to small
10-02-2013, 04:05 AM | #80 |
Member#: 365797
Nice car
Nice car and good info on mods
10-02-2013, 05:28 AM | #81 |
Member#: 352498
NESIC
10-03-2013, 10:09 AM | #82 |
Member#: 352498
NESIC
Burning force, I did run into a couple snags due to the fact I started rushing a little bit on sunday, because the sun was going down. Turns out I forgot the ring on the wg and had to take it down and add the ring. It runs good now except my temp gauge is pinned hot and I get a code P0117 coolant circut low. So I got new sensor still the same found out I have air in the system working on trying to bleed the air. It is not easy man cause I have been running it and it doesnt seem to be bleeding so I started a thread looking for some advice. In all my years as a tech I have never had such a hard time bleeding a cooling system.
10-03-2013, 02:57 PM | #83 |
Member#: 217563
South East
Vehicle:2006 Sti 12.68 @ 108 321WHP 422WTQ dynojet SAE |
Put a coolant funnel in the overflow tank by the turbo. Fill up with extra coolant in the funnel. Run car until hot, aka coolant starts to boil and push out. At this point thermostat will open. Shut car before coolant bubbles over the top. Let cool for at least 30 mins. Done.
This process works about 95% of the time, hardly ever does it not. Have you cleared this code? Is it pretty much instant code that comes right back after clearing? You may have shorted a wire to ground. Are you sure the car is really overheating? |
10-03-2013, 03:38 PM | #84 |
Member#: 352498
NESIC
No I think it's not over heating. You can tell cause it runs normal. As soon as I clear comes right back. It's either like you sai short or air locked
10-03-2013, 03:41 PM | #85 |
Member#: 217563
South East
Air lock wouldn't cause an instant code. Most likely would take 2 drive cycles to set a code and the car would be overheating/pushing coolant. Sounds like you have pinched a wire, pulled a pin from a connector or something of that nature.
10-03-2013, 03:47 PM | #86 | |
Member#: 356215
10-03-2013, 03:50 PM | #87 |
Member#: 352498
NESIC
Thanks guys, I'm going over the wiring now that's all that's left.
10-03-2013, 04:14 PM | #88 |
Member#: 352498
NESIC
OMG!!!!! I had the map sensor plug and coolant temp plug switched. I'm such a retard. This is a lesson don't rush while working on your car. I started second guessing my confedince about cars cause nothing made sense. Thanks for the reply guys.
10-05-2013, 07:46 AM | #89 |
Member#: 352498
NESIC
He everyone, I just wanted to share some awesome news. I got a sponsor. I had applied for sponsorship from a local vendor, HPT motorsports, and I was chosen to be sponsored by them. This is a dream come true. Now I'll be able to do the things I wanted to do to upgrade my car more. Bigger turbo, wheels and more. Anyone who follows this thread in my area maybe I'll see you at some shows.
10-06-2013, 09:14 AM | #90 |
Member#: 137405
Vehicle:2011 WRX 6spd GTX3076r |
Sweet man! Excited for the bigger turbo lol
10-10-2013, 12:03 PM | #91 |
Member#: 352498
NESIC
So doing one more project while I ha eye motor apart. I pulling engine and dong head gaskets and don't new mishimoto radiator cap and hoses. Getting all my sponsor promo stuff today can't wait. Will up date when car is closer to being done and will post new numbers.
10-11-2013, 09:52 AM | #92 |
Member#: 352498
NESIC
New parts going on car mishimoto radiator, radiator cap and racing thermostat cometic head gaskets and a couple more gauges.
10-11-2013, 10:03 AM | #93 |
Member#: 193757
Vehicle:2006 XTI Limited OBP, Junior tuned 573WHP |
I would suggest to not use the Mishimoto cap. Get a set of STI or Cosi caps for both the radiator and upper tank.
I have a Mishimoto radiator and their cap leaked on mine. |
10-11-2013, 10:06 AM | #94 |
Member#: 352498
NESIC
Thank you ill do that
10-11-2013, 10:06 AM | #95 |
Member#: 352498
NESIC
10-11-2013, 10:20 AM | #96 |
Member#: 193757
Works great, I also have a GS 170* thermostat and currently my AEM temp gauge reads 175ish when moving and also pushing it hard. Temps cycle higher when in stop and go, all normal.
10-11-2013, 10:28 AM | #97 |
Member#: 352498
NESIC
Awesome thanks a lot. That makes me feel better.
10-11-2013, 11:05 AM | #98 | |
Member#: 217563
South East
Im curious why you would go to cometic headgaskets? I mean don't get me wrong Im not bashing them, but I think OEM would work fine for your power level. And you see to many people have problems out of the cometic ones way to often. Most likely from having to low of surface RA. I think the factory bolts will fail well before the headgaskets do. Also I like idea of bigger radiator, but I dislike the idea of going to lower theromsstat. I think OEM put what they did in for a reason, if colder was better then they would have went that route. From what Ive always been taught from OEM and perfromance standpoint, hotter engine is happier engine up to you have overheating/failure point. I would think if you run engine colder cruise/idle you would get worse fuel mileage and more wear due to cylinder walls and pistons not being up to full operating temp. Plus I have seen more brand new aftermarket thermostats fail than oem. Like I said just opinions, but I think you may be setting yourself up for some PIA problems. |
10-11-2013, 11:29 AM | #99 |
Member#: 352498
NESIC
I was thinking the same thing you were about the thermostat. I'm still debating on wether to put it in or not. I went with thicker gaskets then oem because I chose to go with cometic. Thanks for your advice.
10-11-2013, 11:46 AM | #100 |
Member#: 217563
South East
Is you compression ratio currently stock? So you are running a thicker gasket to get a lower your CR? Is that the reason for the thicker hq?
