01-17-2014, 10:18 PM | #5976 |
Member#: 307177
Vehicle:2k4 WRX/WRB |
I've gotta replace my left front axle boot. Difficult?
01-17-2014, 10:53 PM | #5977 |
Member#: 331131
Vehicle:2001 2.5RS-T Silver..thorn Metallic |
If the '04 is anything like the '00:
Disconnect sway bar endlink. Remove bolt from lower ball joint that goes through the hub and knock out the LCA from the hub with a hammer. Punch spring pin out of axle stub that keeps it attached the transmission. Remove nut from outter axle stub and knock it out of the hub with a hammer. ~137ft/lbs on this nut. Installation is reverse. Should take about an hour to do both sides if you're swapping out the axles for already assembled units. |
01-17-2014, 11:17 PM | #5978 | |
Member#: 307177
01-17-2014, 11:22 PM | #5979 |
Member#: 331131
01-18-2014, 12:00 PM | #5980 |
Member#: 378655
Vehicle:2012 WRX WRB |
Installed a Cobb ss today.....didn't take much time as I thought it would
01-18-2014, 12:03 PM | #5981 |
Member#: 366849
Vehicle:2000 OBS Silver-ish |
Finished wiring up the compass pack, installed the supertones (and shamed myself for it), and did a psuedo-permanent install of the bed in back for road trip/camping mode
01-18-2014, 05:15 PM | #5982 |
Member#: 370557
Vehicle:'94 Legacy Touring '98 M3/4/5 |
Got a nice 18% all around tint. Feels like a new car!
01-18-2014, 06:16 PM | #5983 |
Member#: 258967
SCIC
Vehicle:2007 |
replaced the pcv valve, did a seafoam treatment to the intake, no oil though,
im having problems with my idle. two codes in both relating to the IAV and the high idle problems.. i think they both can be pointed back to the twe ported throttlebody, and extrude honed intake. |
01-19-2014, 10:36 AM | #5984 |
Member#: 234357
Vehicle:2009 WRX Sportwagen zum einbauen! |
Drove it about 400 miles. Used a couple rest area on ramps to test out the new clutch, launch control, etc. with a couple 0-60 runs (65mph freeway ).
Found out the latest firmware on my access port isn't functioning properly for the 0-60 test. After the test it switches to the 1/4 mile results screen (odd) and doesn't show any results for anything (double odd).. |
01-19-2014, 03:45 PM | #5985 |
Member#: 240706
Vehicle:2006 STI OBP Stg 2 Protune |
New plugs, oil change, power steering flush, Installed SPT hear shield and picked up some all weather mats! Successful Saturday
01-19-2014, 04:25 PM | #5986 |
Member#: 180155
Vehicle:05 Jdm Sti 2.0 PSM |
Gave her a bath from gray to psm and cleaned wheels from bronze to bbs gold
01-19-2014, 04:25 PM | #5987 |
Member#: 359737
Vehicle:2005 Impreza OBS Platinum Silver Metallic |
Replace two wheel studs and did an oil change
01-19-2014, 08:38 PM | #5988 |
Member#: 259589
Vehicle:05 Saabaru 9-2X Deep Blue Metallic |
Purchased a dash/window cam for her. Getting crazy out there after witnessing an insurance fraud being pulled. Driver reversed into another and claimed being rear ended.
Not bad review for only $65. It has the option to auto records over from the start once the card is full, unlike cell phones/go pros. |
01-19-2014, 09:07 PM | #5989 | |
Member#: 364301
Vehicle:1996 WRX Swap Aegean Blue |
The Hero 3 gopros do have the option of acting as a dashcam while plugged in(overwriting, starting when 12v socket gets power, turning off, etc) with one of the newer firmwares. |
01-19-2014, 09:22 PM | #5990 | |
Member#: 259589
01-21-2014, 05:12 PM | #5991 |
Member#: 208588
Vehicle:2005 WRX STi Black |
Replaced the A/C idler pulley...heard an odd whining that started two days ago and decided that it was the most likely culprit. I was correct; after I pulled it out I spun it a bit by hand and it sounded like it was full of freakin gravel. $40 metal replacement from the local Oreilly's and I was back in business in about 20 minutes.
After that, finally flashed the ECU to Cobb Stage 1 |
01-21-2014, 05:25 PM | #5992 |
Member#: 39086
Vehicle:2004 STi White |
I had my timing belt replaced last summer and one if the idler's had that same graunchy feel. Scooby Bucks paid for all but $8.34. No noticeable noise from under the timing cover though. ~10 and did a little PM...
01-21-2014, 09:21 PM | #5993 |
Member#: 378080
Vehicle:2002 WRX Black |
New tranny, new legal taillights aka stock..now to put the bumper back on and lift the dang coil overs UP.
01-21-2014, 10:33 PM | #5994 |
Member#: 359737
Went to the Stealership today to get an alignment and came out with a suggested repair and labor invoice. They say I need a new rear passenger side Abs tone ring and sensor and a rear drivers side axel, wheel bearing and seals. Bad news all around.
01-21-2014, 11:24 PM | #5995 |
Member#: 327408
Vehicle:2013 WRX SWP |
01-22-2014, 01:10 AM | #5996 |
Member#: 377416
Vehicle:2011 Impreza 2.5i Marine Blue Pearl |
Did Tints all around and blacked out the tail lights - I'm in love even more ^.^ there as dark as i can go legally but in the light at the shop you cant really see them >.>
01-22-2014, 01:44 AM | #5997 |
Member#: 149686
Vehicle:2002 My name is Evan and I am an Autoholic |
Swapped my VF39 for a new one and put the heatshield on after I cut it to fit the external waste-gate.
DSC_0363 by HawthorneEF, on Flickr |
01-23-2014, 07:41 PM | #5998 |
Member#: 284143
Vehicle:1998 Impreza 2.5RS Acadia Green |
Uncovered my rs to put my kartboy shifter bushings in to discover mold everywhere. Sweet.
01-23-2014, 08:33 PM | #5999 |
Member#: 359737
01-23-2014, 11:28 PM | #6000 | |
Member#: 333099
Vehicle:2013 WRX STi ISM |
Similar Threads | ||||
What did you do to your Subie Today? Version 3 | TrickNipple | North West Impreza Club Forum -- NWIC | 3796 | 09-07-2011 02:52 AM |
What did you do to your Subie Today? Version 2 | Smoke | North West Impreza Club Forum -- NWIC | 1978 | 05-21-2010 12:43 AM |
What did you do to your Suby today? | BREWPUBEAVER | North West Impreza Club Forum -- NWIC | 1197 | 11-01-2009 12:06 PM |
What did you do to your subie today?! | 07imprezadrifter | General Community | 277 | 06-14-2009 11:42 PM |
