01-06-2014, 11:01 PM | #7926 | |
Member#: 350221
NWIC
Vehicle:2006 WRX Wagon silver |
01-07-2014, 12:04 AM | #7927 |
Member#: 183480
South East
I did a build on my bugeye where only the compression was changed, and it made a decent difference below the power curve but not much above it. It did make more power, but not much. Below peak torque though, it made a pretty good amount more power a pretty good amount sooner.
This was running 9.77:1CR, FP Red 8cm, a 2.5L ej255, stock sti exhaust manifolds and uppipe, and stock ej255 heads with avcs inactive. |
01-12-2014, 12:56 PM | #7928 | |
Member#: 166005
Vehicle:2005 Saab 92x Beaten Silver |
01-12-2014, 02:56 PM | #7929 |
Member#: 183480
South East
I have no idea...did it get deleted?
01-12-2014, 11:25 PM | #7930 | |
Member#: 158864
Vehicle:2003 SOHC destroker |
install a new donk and change NOTHING other than convert to parallel setup... still even on the same tune and zero problems. with everyone banging on about cyl#3 being the one to die first for aforementioned reasons, and my tune being too lean, i didn't consider this coincidence. so in light of all that, can you elaborate on what you said for me? |
01-13-2014, 05:11 PM | #7931 |
Member#: 314642
SWIC
Vehicle:2004 STI silver |
DW 850cc should be in the mail today to run e85 on the stock vf39. have people had good luck with romraider for tuning their own cars? my tuner lives 45 minutes away. or would it be better to buy a cobb ap and have him send me a tune to get the car down to him.
01-13-2014, 05:14 PM | #7932 | |
Member#: 172698
Vehicle:11 STi BW 8374 E85 02 v8 Spec C E85 |
01-13-2014, 05:17 PM | #7933 |
Member#: 183480
South East
We have absolutely no way of knowing if you are capable of tuning your own car. Romraider and ecuflash are great tools that many upon many of us have had success using, but if you aren't knowledgeable about what you are doing, you will blow something up. Tuning isn't the most complicated thing in the world to do, but it definitely isn't a cakewalk or something you just pick up in a weekend by reading a DIY and watching a YouTube video.
I am all for people learning to do it on their own, but definitely do your homework, and be smart enough to realize if you are going to be in over your head or not. If you are, turn it over to a professional. |
01-13-2014, 05:42 PM | #7934 |
Member#: 314642
SWIC
thanks. i have a little experience with HP tuner i watched/helped a good friend run data logs and was apart of the road tune for a couple mods and pump gas on his 2011 cobra. i am not comfortable making an aggressive tune for my self. i guess the question just should have been whats the best way to get my car 45 miles down the road with the DWs installed. i dont own a cobb ap or wideband or tuner software currently.
also its about 35 minutes of highway and then the rest is residential |
01-13-2014, 05:52 PM | #7935 | |
Member#: 172698
If you tuner only tunes with Cobb, then you'll need to buy an Access Port anyway and then they can send you a base tune for that. |
01-13-2014, 05:56 PM | #7936 |
Member#: 314642
SWIC
thanks for the info. he tunes open source. i have been tuned once before for mods and 91. do you have more info on that cable.
01-13-2014, 06:01 PM | #7937 | |
Member#: 172698
Its a really good tool to have in my opinion, even you don't actually tune your own car. You can still check things and run logs for your tuner in the event something seem off. You can also flash base maps or updates to your tune as needed. If you don't have the budget for one then ask around and see if someone local to you has one and I'm sure they can help you flash a base map. |
01-13-2014, 06:33 PM | #7938 |
Member#: 314642
SWIC
thats great info man. really thanks a lot.
01-14-2014, 09:05 AM | #7939 |
Member#: 235648
TXIC
Vehicle:2006 Impreza Sti SGM |
2006 sti
330hp/385tq (at 20psi) -stock vf39 turbo -stock block and heads -ets 4" titanium fmic -id 1000s (around 73-75% duty cycle) -ap fuel rails -gs 8mm phelonic spacers -gs 3port ebcs -topfeed tgv deletes -forge atmos bov -ebay gtspec uel replica manifold and uppipe -invidia v3 downpipe -invidia n1 exhaust -full blown 340 fp -amr 3" turbo inlet -ks tech 83mm intake -e85 |
01-20-2014, 04:53 AM | #7940 |
Member#: 375748
Vehicle:04 STi |
Does the TurboXS knocklite still work 100% like it should even tho we running on E85 ?
01-20-2014, 07:52 AM | #7941 |
Member#: 183480
South East
Why wouldn't it? Granted I use the turboxs tuner pro, which is a tiny bit different than their basic knocklite, but it has always worked just fine and actually been more accurate than the stock system for me.
01-20-2014, 11:30 AM | #7942 |
Member#: 223066
RMIC
Vehicle:2013 STI Black |
I ran one tank of E-85 before I had to switch over to the 91 Octane map for the duration of the winter .
1) Your injectors size = ID 1000CC 2) Injector duty cycle (if you have it) = not sure but probably not much more than 80-85% 3) Elevation = 6200 4) Turbo = Stock VF-52('13 STI) 5) Dyno(figured I would add this since this makes a big difference in numbers) = DynoDynamics (load bearing, aka lower numbers) Tuned by Servion/Revolutions Performance. Temperature outside was about 20 degrees so I got slightly higher numbers than most Stage 2 STIs. 91 Ocatane: 255 whp / 295 ftlb E-85: 275 whp / 343 ftlb Mods: AEM CAI ID 1000s COBB DP SPT exhaust Walbro 255 |
01-20-2014, 11:12 PM | #7943 |
Member#: 375748
Vehicle:04 STi |
01-21-2014, 11:00 AM | #7944 |
Member#: 242700
Vehicle:2015 Impreza Wrx White |
Injector size: FIC 2150cc injectors
Injector duty cycle: 80-85% Elevation: 1015 feet Turbo: FP 3794 HTA Dyno: Mustang 500 AWD ECU: COBB AP V3 Boost: 37 Psi 790 WHP 698 WTQ -TPG Tuning "stg 3" shortblock -TPG Tuning "stg 3" cylinder heads -Ported Heads by Curt Brown Racing -Kelford 280 duration camshafts -FullRace "pro-stock" manifold -P&L Motorsports T3 up-pipe -AMS Performance Intercooler -TPG Tuning custom 3" intercooler piping -TPG Tuning custom 3" down-pipe -STM aluminum exhaust -Radium Engineering Dual Bosch 044 Surgetank -Cosworth fuel rails (ran in series) w/ -8 lines -DW 65c in-tank fuel pump |
01-30-2014, 06:56 PM | #7945 |
Member#: 134949
VIC
Vehicle:'07 SWP STi Instagram | arthurlam89 |
Just switched to ID1300's. Doing E85 flex fuel. Right now I have a single bosch 044. Will that be enough to max a 68lb/min turbo or do I need another one. Thinking 50-60psi base. 80-90 w/boost. 2.5L, 8.5k limit
01-30-2014, 07:25 PM | #7946 |
Member#: 149262
Vehicle:03WR rallycarFXTleg PrimerGrey |
Are you guys on winter E85 in British Columbia right now? Just curious if Canada does that.
01-30-2014, 07:44 PM | #7947 | |
Member#: 134949
VIC
Closest station is about 2 hours away from me in Washington. I'll store a drum or 2 at my house but I pass by on the way to the race track so that's the only time I'll really need E85... unless I want to play around on the street |
01-30-2014, 07:49 PM | #7948 |
Member#: 291770
South East
Vehicle:2004 Impreza WRX STI Java & satin black |
Damn bro!
01-30-2014, 08:05 PM | #7949 |
Member#: 149262
Start making your own!
01-30-2014, 08:34 PM | #7950 |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag 9.8@150 |
Single 044 is enough pump to handle about 585whp uncorrected on our dynojet. The 1300's will likely be tapped before that.
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY | Motion Lab Tuning | Proven Power Bragging | 125 | 04-12-2010 02:57 AM |
jid2 Track Car - e85 ARMY | jid2 | Member's Car Gallery | 38 | 01-22-2010 10:44 PM |
The Honduran army is the bravest in the world... | wrxcelent | Off-Topic | 36 | 07-07-2009 08:21 AM |
Spacific E85 Tuning thread Here ? | discopotato03 | Engine Management & Tuning | 1 | 09-09-2008 11:01 AM |
Did anyone hear the one about the Italian army and the IRAQI satiation? | Asinine | Off-Topic | 3 | 09-20-2005 07:06 PM |
