05-09-2008, 10:10 AM | #1 |
Member#: 120057
Vehicle:2018 WRX (base) 6spd WRB |
Need help trying to figure out how to do this
I bought a vortex generator (shark fin looking thing) off ebay and suprisingly it doesent fit. So what I need to do is get the correct layout of the rear of the roof. Then I will take that template and put it on the back side of the V generator. Then cut the generator to the correct size. But I dont know how to make the template to the exact curve of the roof line, where it meets the top of the back window, so I can tranfer it. Can you guys recommend anything??
05-09-2008, 10:12 AM | #2 |
Member#: 25039
Vehicle:2005 CGM Stage 2 WRX SQC 275 |
What part of it doesn't fit? As far as I know with most of them, they fit better one you start laying it down, or if you use a heat gun and help soften and form it a bit.
05-09-2008, 10:27 AM | #3 |
Member#: 120057
The issue is with the back part of the generator does not match up with the curve of the top of the rear window. Once I get that cut, then I will have to trim the sides to fit, but like I said I need to get the curve of the of the rear part of the roof/upper curve of the top of the rear window. It was an ebay one that I bought for like $15, but I knew going into this that I would have to modify it to fit right
05-09-2008, 10:42 AM | #4 |
Member#: 25039
Ah ok, well good luck with that. Looks like you pretty much have it figured out. Just follow either measure twice cut once or cut less more times then more less times.
05-09-2008, 11:54 AM | #5 |
Member#: 140712
SCIC
Vehicle:2008 WRX STI White |
yea you might try laying it up and scribing a line on it that matches the contour of the roof line.
05-09-2008, 12:24 PM | #6 |
Member#: 92141
Vehicle:2014 GT-NC-PRHT Zeal Red. |
to approximate the curve
get a friend to help get long straight edge. mark it every 2 inches. more if you want to be accurate. put it across back of window where piece will go. get it centered and even by fiddling until both sides measure the same distance from window to straight edge on the two outside edges. once that distance has been established, person 1 can hold the straight edge in place while person 2 takes additional measurements from glass to straightedge at the marked points. (and writes down these distances!) once you are done, the measurements can be transferred to paper, and the curve approximated by 'connecting the dots'. a flexible piece of something (fiberglass rod) is best for this step. kind of like this or, find a really big countour gauge. http://www.modelexpo-online.com/cgi-...TRAN85=N&GENP= |
05-09-2008, 12:56 PM | #7 |
Member#: 117767
RMIC
Vehicle:2014 Audi S4 DP Stage 2 (~420whp) |
05-09-2008, 01:39 PM | #8 | |
Member#: 140712
SCIC
05-09-2008, 01:46 PM | #9 |
Member#: 120057
05-09-2008, 01:54 PM | #10 |
Member#: 25039
05-09-2008, 02:01 PM | #11 |
Member#: 140712
SCIC
it was only 15 bucks ****, i might buy one to fit on the back of my wagon
05-09-2008, 03:48 PM | #12 |
Member#: 120057
Ok, choice 1-spend $200-$300 for one and put it on.
Choice 2- buy the cheap one off ebay=$15, do a little work to it, hmmmmmm sorry I made the wrong choice BTW, I have sourced the material and I am going to make my own wind splitter that will look exactly like the APR one APR=$320+ Mine=material $120 and a little time, priceless. Its cool, some people have a lot of money, but no mechanical skills. You go ahead and spend your money |
05-09-2008, 04:30 PM | #13 |
Member#: 25039
I know I know, just busting your chops though I've seen ebay version fit with no mods needed. I think the one I used to have was a ebay version and I didn't have to mod it so I guess it's hit or miss.
05-09-2008, 07:24 PM | #14 |
Member#: 92141
05-12-2008, 10:25 AM | #15 |
Member#: 120057
Well I installed my vortex generaator this weekend. It looks awesome. Makes the rear end look mean Well worth it. I cant wait to build my custom wind splitter
05-12-2008, 11:47 AM | #16 |
Member#: 140712
SCIC
so where are the damn pics? you cant just go saying you installed it with out showing us some pics do it, do it now
Shane |
05-12-2008, 01:41 PM | #17 |
Member#: 120057
05-12-2008, 04:49 PM | #18 |
Member#: 11205
Vehicle:2015 WRX WRB |
There is always the chance they sent you the wrong one.
When I ordered a CF hood scoop for my 02 they sent me one for a GC-8. Has anyone else installed these without problems or is this common? Maybe you got a universal fit one. |
Similar Threads | ||||
Still trying to figure out what to do about the ECU... | Speedwagon | Legacy Forum | 1 | 11-16-2007 10:00 AM |
1941 (or: "we've got to figure out how to make these smaller") | alacrity024 | Off-Topic | 7 | 10-27-2005 10:24 PM |
Trying to figure out how messed up my finances are, compared to OTs | snvin | Off-Topic | 29 | 09-28-2005 11:17 AM |
trying to figure out how much oil im burning. | BlackoutWRX | Newbies & FAQs | 0 | 07-31-2005 01:50 AM |
Need help trying to figure out how to make a new website (html/flash/java/profit?) | Protege Menace | Off-Topic | 4 | 10-03-2004 11:43 PM |
