09-15-2007, 09:30 PM | #1 |
Member#: 96860
NWIC
Vehicle:2006 STI Black |
What size drill bits should I use?
Hey guys, I'm in the middle of installing my V-Limited Lip and I had a quick question ..
In the manual that came with the lip, they suggested that I use 3mm, 5mm, 9.5mm drill bits. Unfortunately, I don't have any metric drill bits. I have some standard drill bits but I'm not sure which to use. I have a Drill Size Conversion Table and was wondering if I should pick the closest undersized drill and just drill and move in circles to create more diameter. http://www.csgnetwork.com/drillsizeconvert.html<--- Thanks to the guy that gave me that in another topic The hardware that came with the lip were just a small pop rivet, washers, screws, and a fastner that is made for the screw? If you didn't understand the last item, it's basically for the hole that I drill to insert and then insert the screw and washer into the fastener.
09-16-2007, 03:32 AM | #2 |
Member#: 18994
NWIC
Vehicle:06 WRX Wagon White |
09-16-2007, 11:38 AM | #3 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
What size of tires should i get? | rhd | Tire & Wheel | 8 | 04-14-2005 09:35 PM |
What size summer wheels should/could I run? | magillaTheGorilla | Tire & Wheel | 8 | 02-25-2004 11:11 AM |
what size magnaflow i should order? for 1996 impreza 4door sedan 2.2L | imprezaBlue | Engine Management & Tuning | 0 | 07-27-2003 01:51 AM |
What size snow tire should I get? | fstede21 | Brakes, Steering & Suspension | 14 | 11-28-2002 12:33 PM |
What size of tire should i get? | Constantinos | Brakes, Steering & Suspension | 0 | 10-18-2001 10:18 PM |
