08-28-2003, 02:37 AM | #1 |
Member#: 38946
Vehicle:199? 6 diff ones bag o' skittles |
Please help! I need clutch info asap!
I recently purchased a barely used ACT HD clutch for the 2002 wrx and pressure plate for my car.
Unfortunately, the guy that recommended I buy this for my SWAP that has a N/A LEGACY transmission, is now not responding. Yes, I know NOW it won't work. My question is, what part of the clutch kit (the clutch or the pressure plate) makes it function with pull versus a push transmission? Basically, can I just buy a legacy trans compatible part of the clutch kit and keep the other part???? Or do I have to buy a whole new kit? If I can get away with just buying a part of the kit, do I need to buy the clutch or the pressure plate? If I have to buy a whole new kit, can anyone recommend a fairly cost effective source or brand? money is pretty tight right now... THANK YOU, ANYONE THAT CAN HELP I THANK IN ADVANCE!
08-28-2003, 09:11 AM | #2 |
Member#: 24565
Vehicle:2000 V6 STi RA #856 Blue |
You only need a small part to make it work with one or the other. I believe its the bearing in the pressure plate that makes it mate to push or pull. When comparing my buddies to mine(Both have Cusco Super Singe Racing Clutch) that was the only difference. Thats my best guess I will get you a firm answer tomorrow. I am in Japan so that will be in about 16 hours!!
08-28-2003, 10:18 AM | #3 |
Member#: 3467
Vehicle:1998 Dinan3 Bleck |
clutches are either push or pull type and cannot be convert to work with the other. It also depends on the size of the assembly, either 225 or 230, etc. Sorry you got screwed, but the cheapest clutches I've seen are from clutchcityonline. good luck
Help Please! Need download info ASAP!! | somebody else | Political Playground - Chaotic Neutral Edition | 3 | 05-12-2004 01:54 PM |
Please help I need a clutch. | gritzcolin | Transmission (AT/MT) & Driveline | 3 | 01-01-2004 07:08 PM |
please help, I need to fix vandalism asap | majglow | Car Care & Detailing | 14 | 04-11-2003 09:22 PM |
Help! Need Suspension info ASAP! | silverSurfer | Legacy Forum | 4 | 10-16-2001 10:14 PM |
Please Help : Need used RE92's ASAP | WRSport | Bay Area Impreza Club Forum -- BAIC | 3 | 08-29-2001 07:19 PM |
