03-11-2005, 01:39 PM | #1 |
Member#: 78337
Vehicle:2005 Baja Turbo Regal Blue Pearl |
Boost and boost gauge problem
Well I installed a boost gage and I am reading about ~12.5 Psi from 3K to 4.5K then it drops to 8.5 Psi the from 4.5k to 6.5K RPM. WTH is going on here, isnt it suppoused to drop at around 6K not 4.5K? Would you guys tell me how your gauge is reading.......Please... Also the gauge is flickering now..... HELPO
03-11-2005, 03:36 PM | #2 |
Member#: 78337
Anyone here has a boost gauge.... and can tell me their boost numbers related to the RPM...
Also why in the world in the gauge flickering? |
03-11-2005, 10:14 PM | #3 |
Member#: 78337
Anyone?????
03-13-2005, 11:22 AM | #4 |
Member#: 38370
TXIC
I'm guessing (emphasis on the guessing) your flickering has to do with a loose connection somewhere.
I'm also guessing the boost tapering is normal with the stock ECU. |
03-13-2005, 06:29 PM | #5 |
Member#: 78337
So you saying I would have to reflash ECU to get rid of the tapering.... SHIAT I dont want to void the warranty...
03-13-2005, 09:08 PM | #6 |
Member#: 38370
TXIC
Maybe try resetting it just so you know you're starting with a blank slate?
03-13-2005, 09:26 PM | #7 |
Member#: 78337
How long do I keep the neg (-) terminal off? .... I have been told that the boost drop is normal in our engines.....
03-13-2005, 10:16 PM | #8 |
Member#: 38370
TXIC
Well you can just disconnect the - terminal, press the brake pedal for ~10 sec to drain the charge or do the Vishnu reset
03-15-2005, 10:13 AM | #9 | |
Member#: 65999
Vehicle:2006 WRX Limited WRB |
i have a boost gauge on my Baja and my only mod is a short ram intake from turbo xs. i'll stomp on it tonight on my way home from work and tell ya what kind of numbers i get |
03-15-2005, 11:56 AM | #10 |
Member#: 78337
SHANK u.... I have been told already that the numbers and boost drop are normal for the EJ255 with the stock config.... and I think I am boosting a lilbit more 12.5 Vs 11.6....
03-16-2005, 10:21 AM | #11 | |
Member#: 65999
i have a 04 turbo auto/ tip and i did a little testing of mine yesterday. i get just about the same results in first gear. 2nd gear is a little different though, i get 12.5lbs untill about 4.5k and then at 5k it's at 11lbs and when i hit 6k it's at about 10lbs and after 6k it falls to 8lbs. |
03-16-2005, 11:52 AM | #12 |
Member#: 78337
Do you have a stock gauge.... Is the car stock??
03-16-2005, 04:03 PM | #13 |
Member#: 65999
i have a autometer boost gauge and my only mod is a turbo xs short ram intake, i had the same numbers with out the intake also.
03-16-2005, 07:46 PM | #14 |
Member#: 78337
Did the short ram make a difference? Does it have a heat shield?
03-16-2005, 09:40 PM | #15 | |
Member#: 65999
the sound the intake is great, the spooling of the turbo and the sucking in of air sounds awesome and no there is so heat shield. |
03-17-2005, 09:04 AM | #16 |
Member#: 78337
How much did it set you back... I been reading that a good cold air would give this engine about 15 to 20 more HP.... (Injen Webpage)
03-20-2005, 11:32 PM | #17 |
Member#: 35495
Vehicle:2015 STi |
the boost tapering is normal. my BT does it and so did my 03 wrx
03-21-2005, 09:16 AM | #18 |
Member#: 78337
Other turbo cars I have driven like a 3000GT didnt taper much at all, it was fixed at 17PSi up to 7000 RPM. So thats why I was wondering....
03-24-2005, 09:03 AM | #19 |
Member#: 44255
Vehicle:2021 Cross Trek Cool Gray Kaki |
Our car has a little turbo on it and running it up to 17lbs is just too much. I read once that 16lbs is about the most it can do before running out of steam.
Tapering is normal and I recal mine spiking up to about 11.5ish and dropping back to about 8.5 when all was stock. A TXS short ram will set you back about $160+. I had one for about a year. Personally I do not care for its mouting design and have switched to an AEM short ram. It has a connector bracket that bolts right to the fender well and is a little more secure. Just so you know we dyno'd my friends fxt with other mods and he hit 256 at the wheels, we then put the txs short ram on and he dyno'd at 266. So he saw a 10hp gain with no new tuning done to his Utec at all. That is about average if you will for the intakes. Some a little higher/lower mind you. I think one of the only ones out right now with a heatshield is the Typhoon from KN. |
03-24-2005, 08:24 PM | #20 |
Member#: 78337
What about a cold air intake? I been reading about those. Anyways I couldnt buy one now since I be in Spain the whole summer to see my granny and I need the money, but I still want to know....
I wasnt referring to the 17PSI as a target boost I was talking about the steady 17PSI up to 7000 RPM pretty much. Is it due to the tiny, but two vs one turbos. I know our cars couldnt hit that hight on the stock turbo. |
Dual 52mm gauge bezel, Defi D Boost and EGT gauge | masterjt | Interior/Dressup/Audio & Security | 5 | 09-16-2006 12:31 AM |
Gauging Interest: GReddy BOOST and EGT Gauges, new | YinUCSD | Private 'For Sale' Classifieds | 7 | 04-12-2005 03:58 PM |
help...wiring autometer lunar series boost and egt gauge for lighting | Jon Cox | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 08-21-2002 02:51 PM |
F/S Socal locals- greddy boost and egt gauges and apexi t/timer | blxmjx | Southern California Impreza Club Forum -- SCIC | 0 | 03-18-2002 07:36 PM |
1 din sized bezel for boost and egt gauge | mcu81 | Interior & Exterior Modification | 2 | 10-31-2001 06:38 PM |
