10-25-2000, 07:44 PM | #1 |
Member#: 2703
Vehicle:Y2K GC8 Silver forever |
Does it needed to reset the ECU for the following changes?
Hi,
If changing the K&N filter (same size as the stock one) and the Genuine Subaru 2.5RS performance muffler, do I need to reset the ECU? Or is that the ECU will cope with the changes automatically? Thanks
10-25-2000, 07:51 PM | #2 |
Member#: 396
Vehicle:2000 2.5 RS-T 22WannaB |
i would do it just to make sure...heck it doesn't take that much to anyway's
10-25-2000, 08:43 PM | #3 |
Frank Army
Member#: 1457
SWIC
Vehicle:1999 Outback Sport Steel Blue Mica |
It would be a wise investment in your time to reset the ECU when making those changes. This forces the ECU to learn the new items quickly rather than over time.
Can you not reset the ECU and be fine? Absolutely. your call... |
10-26-2000, 11:39 AM | #4 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
I have a MY00 RS. My first mod was to deconstruct the stock intake and add a K&N filter. I didn't reset, instant change in throttle response. Others around here did. Same result.
The exhaust is another story. About 2 months later I added Stromung twin tip and 2.25 mid-pipe. Ran nasty rich! Ran like that for a tank and got crappy mileage. Then, reset the ECU, and it went away immediately and MPG back to normal. My conclusion...reset everytime you make any sort of performance upgrade. It will matter on some more than others, but helps the ECU "learn" faster. |
10-27-2000, 01:10 AM | #5 |
Member#: 2703
Hi,
So if I do the changes but do not reset the ECu, is that the ECU will also learn to adapt the new changes but just slower? Thanks |
10-27-2000, 09:32 AM | #6 |
Member#: 2338
Vehicle:1988 323 GTX black |
Yep, that's the way I understand it.
I have the AMSOIL air filter and a high flow muffler, and I did the resets right after the mods. The mods seemed to help a little(faster throttle response), but I think the extra noise of the exhaust goes further towards the whole driving experience. I also just added an underdrive pulley, but haven't done the reset...don't know if I need to, but it only takes a little while |
Similar Threads | ||||
Reflash to stock...does it need to 'relearn'? | 09rexwagon | AccessPort | 5 | 12-30-2009 05:58 PM |
Forge BOV. How often does it need to be re-greased? | mav1c | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 02-13-2005 04:58 PM |
DO I need to reset my ECU when changing my muffler? | Jfrankon | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 03-28-2003 02:05 PM |
You need to reset your ECU when: | JonnySubaru | Transmission (AT/MT) & Driveline | 2 | 10-14-2002 06:04 PM |
How cold does it need to be... | Idjiit | Brakes, Steering & Suspension | 2 | 12-21-2001 11:36 AM |
